Everything posted by ProDave
I would hate to buy one then find it falls short when used with solar PV and a burst firing PV dump controller. Is there anyone on this forum that has actually used one and can confirm it reads import and export and correctly "averages" the burst firing of an energy bucket PV dump controller? If I get confirmation it does all that correctly I would buy one, but their website is a little scant on details.
How does it cope with solar PV and a PV diverter? I bought a similar thing, different make very cheap like that one, but found it was totally useless with the PV. for a start it could not tell import from export, so if the PV was exporting it showed as "use" and when the PV diverter was doing it's thing (energy bucket principle so energy going backwards and forwards) it counted that as double. I would like such a device, but it must cope with the PV and the PV diverter properly and I have never found such a device. The closest I have got so far is the energy meter built into my own PV diverter which is an old analogue centre zero meter that shows import and export properly. The only reason I would like such a device is it's portability and nice display.
Is it just me, but I would not dream of going to a neighbour and saying "Oi, your weeds are coming into my garden, sort it out" I would just deal with them in my garden myself. Unless it was JKW
- 15 replies
The Impey wet room shower former that I used has the waste offset in a central circular section that could be rotated, so as you rotated it, the off centre waste position changed. You would be very unlucky indeed if you could not find a position with that where the waste did not line up with one of your gaps. And if it was only slightly off, move the whole tray over slightly and fill in the gap. https://www.impeyshowers.com/Wetroom-floor-formers/Aqua-Dec-EasyFit-Wetroom-Floor-Former/
Is it just me, or should the term "battery" be restricted just to something that stores or produces electricity? This thing described is a THERMAL STORE. Yes, a big night storage heater. It may be heated by electric resistance heating, but the stored energy is taken out as hot water not as electricity, so I believe the term "battery" is wrong for this.
Delays with service quotes from DNO
ProDave replied to Canski's topic in General Self Build & DIY Discussion
Go direct to the individual utilities rather than through an agent. -
If you are wackering it, you need to put it down in thin layers, run the wacker over several times then add a bit more, as @joe90 says a wacker may not be up to the job especially if he did it in thick layers or there is still soft sub soil underneath. It might be worth just leaving it for now and seeing if it settles to a point where it stops sinking further, then lift, re sand and re lay the blocks.
I look forward to the payback time calculations, when you cost the cost of the beer and the chilli, then work out the value of energy produced.
I have done 3 new builds with ASHP's and all that BC wanted was the G3 unvented cylinder comissioning sheet signed by someone they know is qualified. Electrical side of ASHP is covered with the EIC.
I would just squirt some sealant into the crack to try and keep further moisture out and move on. It is not going to fall down any time soon. Don't start any more new jobs, you have plenty to do.
If fuel stops going up, then in a years time it will fall out of the calculation and inflation will fall.
No it won't. This inflation cycle is not driven by the normal over heated economy based on too much consumer spending with borrowed money. This is a world wide crisis due mostly to a war. So if we all go into "survival mode" and stop spending, lots of businesses will go bust but it will not do one jot to bring down the price of fuel, food or raw material.
Just a few random thoughts. If you are buying the house, make SURE it is written into the contract that the FIT will be assigned to you on completion. The actual power generated will depend on lots of things, if there is any shading from trees, your or neighbours roof, even a chimney pot or dormer window can create shading and reduce the output. When you can, look at the inverter in the middle of a sunny day, it will tell you how much power it is generating. And last random thought, has the owner been submitting readings quarterly, or have they been estimated?
I don't pussy foot about with half hearted weed killers. I use Glyphosate based weed killer, currently Gallup XL but every time I need to buy some they have changed the name.
Why do you want a small number of large panels, rather than a larger number of small panels? Why not just find the cheapest way to get the total power you want? Why not match the size of what is there for easthetics? Be careful changing the output of an existing FIT system/
What exactly do they man by dual meter? Do they mean dual rate like E10 or E7?
That raised rail is the track the wheels run on, so they should not be scuffed like that. Has it always been like that? Did that damage happen during install or otherwise during the build or has that happened in use?
You want spring water constantly flowing so a constant flow into a holding tank that is always overflowing back to the source. Then it will probably want some treatment but you won't know until you get it tested. A farm near us has a similar system but the spring is a long way down the hill, so he has a hydraulic ram pump constantly pumping water up to an underground holding tank near the house, and from there a submirsible borehole pump keeps water in an accumulator at pressure for use. He only needed a UV treatment system.
We self use just by timing the ASHP to start it's water heating at 11AM and by using the big appliances, washing machine, tumble dryer and dishwasher one at a time around mid day. Solar PV diverter to send the rest to DHW consumes most of the rest. the ASHP heats the HW tank to 48 degrees leaving plenty of room for excess PV to heat it more. I recon about 1/3 of the PV production goes to the immersion heater. The only time we export is at mid day on a sunny day if nothing else is on and the PV can generate a little more than the immersion heater can absorb even at 100%. In the shoulder seasons I can optimise that further by using a 700W convector heater as an additional dump load, but we don't want that on in the summer so a little gets exported. Ours is east / west split to flatten the mid day curve a bit, but it is hampered by morning and evening shading from trees which has much more effect in the summer when the trees are in leaf. Where I think batteries start to make sense is on a larger system where it would indeed be very hard to self use it all in real time.
I can't see what the fitters could have done wrong unless they twisted the frame when they fitted it? To fit ours, the fitters lifted out the sliding sash to halve the weight to be lifted, fitted the frame with the fixed sash and then put the sliding sash back in. I really can't see anything they could have actually done to make it stiff. Is it a case the stiff one is just larger and more mass to slide? They are heavy, and not a door you would expect your granny to use with ease.
If the issue is voltage drop, then stopping the DNO's cable at the gate and running your cable from there, will not stop the volt drop. If anything it will increase it as your cable is likely to be smaller. I would go back to them to question the technical reason for this? Are they concerned Ze will exceed the maximum limit? If so the solution is not to shorten the run, but to increase the cable size they use. Can you post a plan of what they are proposing? there is usually a site plan showing what they connect and from where with the different size cables they are proposing.
East west split is not unique. Neither is ground mount. building a shed out of the structure I admit is less usual. But a commercially installed E/W split on a roof professionally installed is not unusual. And like any other system, if you can't fix it yourself, you get the installer to fix it for you.
Is this lift and slide? I see no obvious means od adjusting but there is a phone number on a label to request an adjustment guide.
