Roundtuit
Everything posted by Roundtuit
Why not use blocks instead of facing bricks if it can't be seen anyway, and maybe a fillet of mortar to shed water? Alternatively, you might find smooth blue plinth bricks are a lot cheaper than ones that match your facing brick.
Sounds reasonable to get you back in the right place!
- 7 replies
- electricity
- signoff
(and 3 more)
Yes, sharp sand though, dry or semi-dry mix ?
Would my Neighbour need planning permission
Roundtuit replied to Becks1974's topic in Planning Permission
Not sure about the paving etc, but I suspect that removing the hedge would have required permission in a conservation area. I'd have a chat with your council's Conservation Officer. -
Notice of intention to issue Enforcement Action
Roundtuit replied to Susan61's topic in Introduce Yourself
I don't think it works that way when you buy a second hand car, so why should it for a house? (Apologies for off-topic) -
Expanding foam rant...
Roundtuit replied to Carrerahill's topic in General Self Build & DIY Discussion
Judging by a random Safety Data Sheet probably not much different to the foam itself... -
It's not very warm let's light the fire
Roundtuit replied to JohnMo's topic in Stoves, Fires & Fireplaces
Mainly Ash from pollarding a few trees 18 months ago, and some small stuff from a fallen birch. Just about finished the Siberian larch offcuts from cladding 2 yrs ago; made great kindling. -
Nice! 6C outside here. Lit the stove a little while ago, and we're just reaching 26C now. Mrs Roundtuit is complaining its too warm, and the dog's thinking about moving to another room. Me? Shorts and T-shirt and a warm glow from the thought of the electric I'm saving. Better throttle it down a bit now though... -
It looks fine I reckon. I'd try and escalate it within the council, and call their bluff. They'll be hard-pushed to justify any enforcement action given their lack of engagement and error regarding the windows. -
A broker is probably worth while. Not all lenders ask the same questions, so someone who knows the market could save some pain.
Concerns over Flashing between old house and new extension
Roundtuit replied to Freddie Aldred's topic in Flat Roofs
Sorry, but it looks like it's been done in the dark, with chewing gum, by a 4 year old. If they've done that sort of job where you can see it, I'd be concerned about what you can't see. -
Or infrared thermometer. Finding the cold spot could save you a lot of effort. There could be differences across the party wall depending on how next door heat their rooms.
Error code Samsung ASHP
Roundtuit replied to canalsiderenovation's topic in Air Source Heat Pumps (ASHP)
Filter probably needs a clean. I had a flow rate error code this morning (Hitachi code 070); I think now its cold, radiators and ufh zones are opening up and blasting through bits of crap that are still in the system into the little stainless steel gauze filter. 15 minute job to remove and clean filter and all's good. (Check out youtube videos for filter cleaning- could be an easy fix). -
Excess rain water flooding
Roundtuit replied to CARBr6's topic in General Self Build & DIY Discussion
Brush it off, or if the surface is smooth enough, floor squeegee? (foam blade, not solid rubber, are best) -
Widening Fireplace to have more room around log burner
Roundtuit replied to Whitefusion's topic in Stoves, Fires & Fireplaces
And be too high? I know it's a bit of a thing to put the TV on the chimney breast, but it can be too high for optimal viewing comfort.- 27 replies
- fire
- structural engineer
(and 2 more)
Rainwater; I suspect that whatever you can do with your discharge, it won't have a significant effect on the flooding issue if the rest of the street is flowing into the culvert. Sounds like a bigger problem than you can fix, but worth exploring the issue with whoever is responsible for street drainage. Soil pipe; does the soil pipe running to the septic tank exit the house above ground level? If so, could a new pipe be run across the back of the house and drop into the stack on the corner? Not pretty, but way easier.
+1. Mines never been cleaned. Can changes can be a bit messy, but let any excess go off then scrape it off. Same with the nozzle; a quick scrape with a Stanley knife blade before use and all's good! -
Attempting a straw bale, off-grid passive house in Somerset
Roundtuit replied to Smallholder's topic in Introduce Yourself
Best not to confuse hay and straw, but I think you're correct that small bales are now a bit of a niche market. It might pay to get straw baled specially to order, particularly if you can get it locally.- 62 replies
- straw bale
- off-grid
- (and 8 more)
MVHR Installation Issues
Roundtuit replied to Nickw1982's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Sorry you've got these problems, but it looks like they need to start again really, as the warranty won't be valid if its not installed correctly. Have they used that silver flexi duct throughout? Rigid or semi-rigid would be more usual. -
Assuming the screen is hinged to aid access, do you really want to silicone it? Maybe it's fixed a bit too far out? If it was moved back towards the taps a bit, would that help direct the run-off back into the bath rather than over the side?
Poor job. As above, its the sort of job that makes you wish you'd had a crack at it yourself. I'd have a chat with them and discuss your concerns; they're all valid. I'd also want more separation between the vents - can't remember what the recommendation is, but worth checking before you part with any money. (And the plenum should be covered in insulation when they've finished). -
Boiler leaking water drops since January 2021
Roundtuit replied to plumbingo's topic in Boilers & Hot Water Tanks
We'll be living with Covid 19 for the foreseeable future and managing the risks, so I guess you've got to decide if you want a heating engineer to come round and fix your boiler, or come round for dinner, a shower, and a quick scale and polish. -
Correcting a misjudged loft hatch size
Roundtuit replied to climbinggeorge's topic in General Joinery
Maybe I'm just over over-cautious; I be nervous about making sparks inside, but have at it with everything else in the tool box. This why we all keep the knackered chisel and the slightly bent screwdriver ? -
We've got 4 x smallish top-hung velux in our bedroom. I couldn't justify the extra cost for 3g (the rest of the house is 3g), so got the 2g 'comfort' glazing as the best thermal/soundproofing/cost compromise. I've nothing to compare them to, but no regrets 3.5 yrs in.
Doesn't look like there is any thread on the pin other than the the end for the nut, so it should just pull out.
