Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. >>> copy some elements (proportions etc) of the rear elevation OK suggest: (1) make the front gables similar size and proportions to the back ones. This gets rid of the front bays, gives you a bit more space, makes the build easier & cheaper and gets a similar contemporary look to the back. (2) make the front door two parts rather than three, with the door on one side and a similarly spaced window on the other. (3) replace the slopey front porch with a simple flat horizontal number. (4) maybe make the window above the front door into dual inward opening doors with a Juliet balcony for through ventilation. (5) make the front windows similar proportions to the back. (6) maybe make the bathroom windows have a higher cill than the others though as a privacy thing. I'm not a fan either of the slightly asymmetrical back/front gables - I would rather have them the same size (less hassle to build) or a more pronounced asymmetry. That's a matter of taste though.
  2. OK in that case I would just 'follow my nose' matching up the connectors and yellow and green cable/pcb markings (see images below). 7 out of 8 seem pretty obvious - there's probably yellow and green marked on the other sockets on the unit too. The only one I can't figure is the power cable - that might be more obvious to you with them in your hands. Maybe photograph both ends (pcb & unit body connections) of the old set-up. And the new set-up before powering on and post here.
  3. Yeah as an electronics guy … I suggest asking for the whole unit to be replaced. It’s not your fault that they have completely redesigned the pcb with no thought to upward compatibility. The fact they have an ‘upgrade kit’ with all the adapter cables suggests a major design fault and that lots of these units are failing in the field. Or ask for you money back and buy a different brand.
  4. Yeah we have a Stuart Turner dual flow pump (pumps both hot and cold) after the tank for this reason and it works well and has been going for 30 years. Ask the landlord to pay? You would want to ditch the shower pump also then.
  5. It’s your surveyor’s and solicitor’s job to point out potential problems to you, however minor. With their advice, you then make the decision how important those outstanding issues are. By all means get a formal statement from the sellers that the modifications were in the long distant past. Produce that, if needed, in 8 years time when you sell. Otherwise, I would suggest that all house purchase involves some risk (e.g. dodgy neighbours) which you can do little about. *Life* is risky and you can’t remove all risk from your life - even with the best solicitors and insurance. For new houses, NHBC certificates generally only last 10 years (because you can’t guarantee a house for ever, and at some point you have to say ‘this house doesn’t have any major structural problems’). Expecting to cover structural problems after more than 10 years with any house purchase is a little fanciful. Take a view, get the letter from their solicitors, and move on.
  6. Maybe copy some elements (proportions etc) of the rear elevation, which looks to me quite contemporary, to the front elevation - which looks to me quite 1940s/50s? Maybe your architect wanted the front to blend in with the older houses in the street? This is, of course, a perfectly reasonable question to ask your architect.
  7. >>> When you say it's easier going to appeal than applying for planning permission, does this mean you can skip the planning process entirely?? As well as refusals, you need to go at least 8 weeks and then you can also appeal for ‘non-determination’ if the LPA has not made up its mind by then. >>> When you say it's easier going to appeal than applying for planning permission By all means appeal. But … the appeal process is properly slow. I have 2 ongoing and the appeals admin guys took 3 months just to ‘validate’ they had the right docs… Also my analysis (a morning’s worth) suggested that the appeals process gets just as random outcomes as the standard LPA process. I put up a thread on BH that describes what I found. If you want to do your own research you can search the appeals portal yourself and also your local LPA’s portal under ‘appeals’. So, if your own LPA isn’t ***too bad*** I would let this one go through and make your best stab at convincing your LPA your bulld project is a good one. If that doesn’t work, then appeal. You get two chances that way. That assumes you have all the time and money in the world BTW you can add extra docs to the application as you go along - at least my LPA allows it. I added some photo-montages that showed what passers-by could see for instance. Probably best to let the case officer know as well when you add new docs.
  8. Retailers to pay for consumers’ e-waste recycling from 2026 under UK plans… https://www.theguardian.com/environment/2023/dec/28/retailers-to-pay-for-consumers-e-waste-recycling-from-2026-under-uk-plans
  9. An option is just to live with it for a couple of months. Then if you’re still bothered by it, take the leap and get it re-tiled. A bodge in between may still bother you anyway. It all depends on how much it bugs you - but some stuff your brain just tunes out after a while.
  10. >>> i then appealed my original application and won so you can appeal a previous application and if you win build what you originally wanted. @joe90 I was going to use that technique but our delightful LPA CIL people told me that I couldn't move the self-build exemption from one design to the other. Was that a problem in your case? >>> should planning officers take into account previously approved applications as a precedent for their decision? >>> Although it can help, each application is determined on its own merits. That's true but there's also this: Consistency Principle - The principle of consistency within planning decisions requires that a previous decision is capable of being a material consideration in a subsequent similar or related decision (see, for example: Mann LJ in North Wiltshire District Council v Secretary of State for the Environment (1993) 65 P & CR 137 and/or R (Midcounties Co-Operative Limited) v Forest of Dean District Council [2017] EWHC 2050) and/or Baroness Cumberlege v Secretary of State for Communities & Local Government [2017] EWHC 2057).
  11. >>> I have engineering and architect drawings and designs. My next job will be to create my own drawings to use myself or pass on to a joiner to complete the actual work. I’m using a cad program called fusion 360 and I plan to 3D print the design <<< It might be worth checking with the trades concerned that they're really going to follow your detail drawings. I think a lot don't ... and just use whatever 'system' they've used to-date. If you do prepare drawings you'll need to walk through them in detail and get the trades to agree on the detail with you - even then they may make it up as they go along if you're not watching. I think this particularly applies to 'newfangled' practices like insulation continuity / airtightness / insulated pipes / radial circuits etc etc. FWIW I'm using Fusion also - not the best, but passable both for architectural and engineering drawings. You reminded me that I planned on getting a 3D print of our design for review purposes. Fusion also has load analysis and heat analysis which I have played with but not used extensively. You might want to check out J Harris spreadsheet / https://www.ubakus.de/ / the Passivehaus spreadsheets for heat and condensation analysis. Maybe those calcs were done by your architect/engineer already - in which case you should have U value numbers already.
  12. Yeah, I think it's all in there although it's a long read. In practice, I used one of the summaries by stove suppliers e.g. https://www.woodburnerwarehouse.co.uk/building-regulations https://www.stovesonline.co.uk/stove_building_regulations.html https://www.imaginfires.co.uk/blog/log-burner-regulations/ I guess in theory you can't rely on those 100%, but I think I did - it was 4-5 years ago I did mine. Re getting max heat out into the room - I wonder whether a reflective sheet of stainless behind the stove might help?
  13. I think the original Dualit design is a classic - both old-fashioned but also very modern in its repairability. I have one 29 years old and I don’t expect to replace it anytime soon. I’ve replaced the elements twice and the timer once. And this design didn’t require any clever engineering - just that the thing is held together with screw fasteners and also that spare elements and mechanical timer switches are made available. Wouldn’t it be great if more products would last a lifetime and were very simple to repair? I would fill my house with products like that. >>> £200 / 25 years = £8/year >>> My £5 pound one lasted over a year. i’m not a rabid enviromentalist - but just for engineering efficiency I would prefer not to send a dozen or so cheap toasters to landfill.
  14. Some clearance dimensions (hearth sizes etc) are in the BC regs. Some (to combustibles etc) are in the stove manufacturer’s specs for that specific model. If you think about it, it has to be that way as it depends on say what’s going on inside the stove re insulation at the back. Yeah you should really make your BC application up front.
  15. I'm all in favour of ambitious DIY and I did my own BC-signed-off wood burner install. But .... in this case, I would try my best to find both a really good builder and a HETAS-stove person and get them to jointly recommend a way forward. The risk elements are structural re the chimney, fire, carbon monoxide poisoning and smoke infiltration into other rooms. FYI you should find a notice plate (e.g. below) and a CO alarm installed - if not it's a suspect installation. It may not actually be that inefficient a set-up that you have now. So, it may be that 'do nothing' is the best option. You might want to check the stated output for that model and judge whether, say, a fan heater of the same rating would heat any slower. (If you want to be a bit more exact in this judgement allow for the efficiency of the wood stove - that'll be published by the manufacturer and probably be 80% or lower.) Also note that Scandinavians often use a traditional stove design where the stove is deliberately surrounded by bricks or heavy ceramic tiles to smooth the heat output of the stove into the house (see photo below).
  16. FYI there are some standalone ice makers (bars & restaurants use them) - I don’t think I’ve seen one with ice and cold water but my search was fairly casual and a few years ago.
  17. I like the overall design concept. I was just in S of France and reminded of the utility of a shaded courtyard. I know also that it’s v common to use RC domestic structures in S Europe. Supporting a heavy-ish roof slab obviously needs a bit of ‘structure’. What’s your feeling re the need - is it a ‘thermal inertia’ aim? You could, of course, use a much lighter roof structure.
  18. Can you maintain these after they are installed? e.g. when/if the motors fail?
  19. Yeah agree, it’s a big quality of life thing for us, especially in the summer. And we buy much less bottled water because the simple inlet filter makes the water taste good. The ice machine gets clogged about once a year and I give the ice basket a quick shake. I change the filter once every 2 or 3 years. Even then, I can’t taste that the filter is past its best. This is a Samsung ‘American’ fridge about 20 or so years old.
  20. IPA maybe? - the alcohol kind rather than the ale kind.
  21. These are space frame trusses - you do see smaller ones being used e.g. for lighting rigs. Maybe the extra cost is justified in that case by the truss being lighter and thus easier to erect for temporary installations. e.g. https://www.ltt-versand.de/fr/structures-alu/naxpro-truss-black-label/fd-24-noir/24829/naxpro-truss-fd-24-longueur-300-cm-noir
  22. @LSB Possible to tell me which one? I could do with another quote…
  23. See e.g. https://edition.cnn.com/2023/12/16/climate/solution-hot-rocks-renewable-energy-battery/index.html Something we can use 🤣
  24. I’m still very surprised by the mdpe - I have not found specs or guarantees yet (I’ve spent all of 10 mins looking) - but see ‘50-100 year life, 16 bar’ touted around. Apart from uv impact, I’ve never even considered lifetime - the same way that I think of copper pipe, bricks, blocks etc. Do you have any of the pipe that was taken out that could be tested? Maybe it was sub-standard? You may indeed need to sue the installer - at least that would offset the costs of whatever fix is required.
  25. >>> We found and dug up one leak and I believe our installer looped the pipe too tightly and over time it has simply developed a crack on the apex of the curve. Are you assuming that there are equivalent problems all the way down the pipe now? Is it possible the problems are localised and they could simply get a patch fix? p.s. what kind of pipe, MDPE? Also, any idea what pressure it's running at?
