Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. >>> Should I budget for the same again or is it materially different? Hmmm, depends how big a job it was to get your temp supply in. A few people here on BH get the supply into a permanent kiosk somewhere on the property and then get their own sparky to run power to the house at a later date.
  2. Presumably the exposed bits are 12V? Wasn't there a trend for dual naked suspended cables with little 12V lights hanging off them in the mid to late '90s - or am I showing my age?
  3. Re: Details for Passive Houses - just got a battered copy at a discount. There are 39 pages of intro, about 200 pages of 'stack-ups' (see below) and 100 pages of reference material. The main body looks like this. Not overly taken with the book at first sight, but maybe there's some nuggets in there somewhere...
  4. >> so you need more timber say which shortens the effective distance between the bolt and counteracting force at the edge of the track Ooh, very subtle. >>> may sound like a maths exercise but actually it can avoid disappointment Sounds like a great SE tag line Any SE-101 books you can recommend?
  5. >>> But in order to actually be cheaper, especially with the higher up front cost of a HP, then your install does have to better than has perhaps been typical in the industry. Is the logic here 'electricity is 3x price per kW than gas, so you need an average CoP > 3 (to swap out a gas boiler for a HP) and you'll only get that with a very good HP install'?
  6. Well pressing on I think these are the main 'use cases' if you'll pardon that term: (1) (Packaged) Client uses one main company for nearly everything (MBC for instance). Company is principal designer and contractor and has full CDM responsibilities.. Client ('domestic client') may still be expected to "take all reasonable steps to satisfy themselves that the dutyholders are competent..." (2) (Architect & Main Contractor) Client uses a single principal designer and principal contractor. Architect sub-contracts SE etc to third parties. Principals run CDM between them. Client is still 'domestic client'. (3) (Architect & Client Project Manages Sub-Contractors) Client uses a single principal designer but not certain who the principal contractor is - presumably the Client. Who has CDM responsibilities? (4) (Client Designs & Project Manages Sub-Contractors) Client is principal designer & principal contractor - presumably also runs CDM. Actually (4) is my case, so I'm keen to get clarification on that one
  7. Ply or OSB behind the plasterboard in kitchen and anywhere else you expect to hang heavy stuff?
  8. >>> Have you done any manual calculation that include the solar elevation and azimuth? @SteamyTea You've done it again - how come you always have the right calculation at hand - any books to recommenced? Thanks for the link, and no, let me try that though. @Dan F re: Our solution to get the best of both was: - High-g triple-glazed windows (higher solar gain) I'm guessing you mean low G and less gain - or were you deliberately allowing a lot of solar gain and heat through and then using the external blinds where necessary? Also that means either ensuring the windows are closed before using the blinds, or using inward-opening blinds?
  9. >>> Not as if householders only want to walk or travel by bicycle. My LPA think that's their preferred transport method (for the owners of new homes that is, I'm sure they'll still want to use their cars themselves) (:
  10. >>> I have built up a collection of pre-used sockets and switches etc and am now thinking about the best way to give them a spruce up Yeah no problem doing that, but I'm not sure it'll be worth your while by the time you've bought the solvents. It'll get rid of any dis-solvable contaminants but probably won't take off the paint and not the scratches. You can probably put them through the dishwasher (they do that with PCBs using DI or distilled water - from memory, I think the former). You obviously need to leave them to dry out properly.
  11. I’m imagining that brise soleil are most useful for midsummer S facing when the sun is high but allow useful solar gain for the other months when the sun is lower in the other 3 quarters. Outer blinds as an out-and-out sun block whenever needed. Internal blinds for thermal control in winter. My train of thinking is - what’s to stop us having smartish window coverings that control solar gain and heat loss as and when we need it? ‘Windows don’t just have to be dumb bits of glass’. The other thought I was persuing is - maybe we want to balance solar gain so we get useful gain in winter, not too much in summer i.e. there’s some optimum in the middle there somewhere.
  12. Interesting - have an indicative cost and/or a recommendation for TM59 supplier?
  13. Yeah that and the paperwork delay - would be good to see some comparisons of UK with other countries.
  14. >>> I'm having terrible trouble with one of my three Neostat v2's (connected to the old style wiring centre WITHOUT reset buttons) and a Neohub Gen 2. I might just restart the wiring centre (probably a mains switch) then the hub (remove the power lead) and then remove and reinsert the battery to the stat. I once had a problem where the hub got its time confused - something to do with my internet vanishing for a bit I think.
  15. I'm juggling with our windows, part O simple method & PHPP. I'll also go to TM59 if it'll help get what we want. My objective (I think) is to get a set of windows that are OK for heat loss and make the best out of solar gain in the shoulder months while alleviating mid-summer gain. The windows are nearly all West & East with very few North & South. So, I'm currently modelling automated external blinds & low G glass for protection against overheating but allowing us to benefit from positive solar gain when we can. My questions are: + is there a better way to optimise shoulder months by using brise soleil in addition to automated external blinds? + can I realistically reduce heat loss (in PHPP or real-life) by using automated internal thermal blinds as well? + is there are sensible way to include (in PHPP or real-life) a conservatory-type structure in all this?
  16. >>> I've had power jump about 10m from a cable to a crane mast. Good point - worth verifying with the DNO (if you haven't already) whether these or 230V 'low voltage' cables or something more tingling.
  17. Welcome - we always welcome experts There are many on here from lots of different disciplines and they are generally very generous with their knowledge. These two threads (below) summarise the current state of our hive mind on CDM. It would be interesting to see whether you agree... We have a few different build set-ups depending on how much bought-in skill we're each using on our self-builds. Some pointers on how each of those should work and the gotcha's involved would be very welcome.
  18. >>> Omega Seamaster watches, pre-war Leica cameras, Umbrian villas You forgot Riva launches... @sunflower - congrats, there are not many oak frame-style people on here, but there are a few. Me, for one. A couple of drawings / images of the plot for us to be jealous over?
  19. Yeah, not sure, we have not fully optimised our heating schedules yet, but we had an average price on the bill of 24.07p. p.s. this is Octopus's own analysis:
  20. I've just noticed that Octopus give a proper breakdown day-by-day on the bill in 1/2 hour increments, also a monthly average of the daily use (blue line). One page per day. Well done octopus:
  21. >>> Below is a part of one of my designs for a glass balustrade Hi Gus, just to understand - are you saying 'the profile manufacturer has done the calcs on the profile, we just need to ensure the bolts don't fail before the profile does'? Presumably there are there some standard stair loadings that you are using e.g. the 0.57 shear load? Is there some rule of thumb on what is required to be SE calculated and what isn't? ... In principle you could calc the loading for every fastening used in a build, but I guess we don't have the time and energy for that?
  22. >>> Surely working and living in the same place is the most environmentally sound approach? No need to travel. I think it's just that you're sort of slipping between the planning cracks. The rules we have are largely based around simplistic 'use-cases'. So there's residential, there's commercial and there's industrial. It sounds like you're looking for a mix of residential and commercial. Not so much artist or artisan, which are often accommodated within residential (on the basis you won't be doing much of anything to annoy anyone) but a bit more industrial - think fumes, noise etc. Now there are some rules around 'live/work', which I don't pretend to know, but which you might like to investigate. You also may find some cracks between the rules that you can use to your advantage - but you'll need to know what's available to buy and why the rules are in detail. So, either a place with outbuildings you can use carefully so you don't tee anyone off or some kind of farm arrangement where mixed business and residential are the norm or even easier a house and a nearby space in a mixed studio. If you were in Suffolk I might suggest Jet for instance: https://www.oldjet.co.uk/about-old-jet-arts-centre/ In the latter case, you have the added advantage of a community you might enjoy.
  23. System taken over by prehistoric monsters? Weird bug in software?
  24. Yeah, understand the position re London studios - stupid expensive and often not great despite that. And often used as LPA bait until a developer figures they can make a bunch of money. If you buy a place with a biggish garden then you can probably get what you want - maybe over time with a couple of buildings. An even easier route is to buy a place with barns or and existing outbuilding and convert those - probably with no oversight by anyone. Planning departments are fairly OK about artists and artist studios - particularly if it's your livelihood. Good idea though to keep talk of "fumes / contamination / noxious / dangerous things / potential neighbour problems" to a minimum to avoid triggering the locals .
  25. >>> I wonder if these stats have an accelerator (heater/ some AI copy of) that's massaging the sensor to improve response? The whole Heatmiser tech set-up is fairly dumb old-school tech although it does have wireless to the hub and an app - otherwise it's a simple set of desired temperature profiles held in software and a relay in each sensor to switch the load. There are settings for each sensor to control the switching (time between call and non-call changes and temperature difference to ignore) - those stop rapid switching. There's also a frost setting and a setting to allow 'pre-heat' warm up to reach desired temperature in advance of the schedule. That's it. This kind of thing (below)... @Andehh - as the designers suggest it's a HP cold weather / defrost thing - can't you get them in to diagnose and fix? Is your house well insulated? If so, the general advice here on BuildHub is to have your heat pump run consistently for long periods to deliver a more-or-less constant internal temperature rather than have it bounce around trying to fit the 16-21 degree swings that it's programmed for right now. Actually a useful experiment would be to change the profile to a constant 20 or 21 degrees for a day or so and see whether it settles down.
