Carrerahill
    10
Everything posted by Carrerahill
  1. I have my sills sitting outside ready to go in with the block work, they are 215x75-50: http://webtrack.jwgrant.co.uk/ProductDetail.aspx?pg=437&pl1=344&pid=2407 My question is just exactly how the concrete sill and the timber frame opening will work together, I have 50x50mm treated that I was going to frame out the window and door openings with all the way around, however if I do this then I will end up with the sill sitting 115mm out over the block work, so really the sill needs to sit back into the cavity. I was thinking like this: So you can see the block wall and the render on it, the sill will sit overhanging into the 50mm cavity by 40mm, I will put a piece of DPC along the back just in case, then I will add my 50x50 treated to the sides and top (not in sketch), the window then fixes to these and it sits on a stub sill with some brackets holding it to the sill trimmer, sitting on the concrete sill. Does that seem right? I was actually just going to bring the blockwork level with the timber frame opening, close the cavity all the way around and use a PVC sill to sit from the cavity closer out over the block but my brick layer said order concrete sills, there is no detail in my BC drawing for this so I am not sure how to proceed - concrete certainly would be more robust and in-keeping with the rest of the house, but I am not sure how it all goes together now! Photos or details of those of you who have done this or seen it done would be great. Thanks
  2. Can you not pour the walls you want to look like this in concrete with board forms?
  3. Ah, be careful, you are getting mixed up with MCB's - This is an RCD - a fault/danger can exist that will NOT cause any tripping until something, i.e. a human with wet hands touches an exposed live on say a grazed electrical cord. Short circuit protection is quite different.
  4. Let me guess, he ballsed up new colours to an older red, blue and yellow installation?
  5. Jeremy, that is how the Merlin Gerin ones worked, albeit built into the RCD, and I thought many others did too now. Down and dirty testing is often pretty good! The thing with RCD's is that they are essentially a relay, with the coil current coming from a fault imbalance, it is like a light, one stage rifle trigger, it's a hairspring and a small current should create enough of a field to trip the latching relay. If they are not used for long periods and are exposed to damp, i.e. a garage install, damp basement, it is entirely possible the mechanics of it can gum up. Now this is from a theoretical report, but from what you have said it sounds like that could be the mode of failure. It is your experience which makes me generally dislike 18th edition boards.
  6. I didn't know that is how the plug versions work, DIN mounted RCD's such as in our DB's use two methods, either a post coil live and neutral but the test button operates a small additional winding via a resistor on the core opposite the relay winding, thus this creates an imbalance. Merlin Gerin RCD's (the rep used to come in and offer to have designed all our panels on projects and would talk about specs of their kit) used to have a test button with a small resistor to the earth from post coil live, it would dump 20-25mA - whatever it was to earth. They were famed for claiming this made their RCD more robust as it was not relying on a secondary winding to create the imbalance but rather the real circuit was going to detect the imbalance. This also proved the coils were not degraded. Anyway it appears now there are potentially 3 circuit options! I only suggested it as when my wife inadvertently presses the test on the lawnmower it would trip the outside power RCD on the DB and I was always under the impression the cheapo plug RCD's were the resistor to earth option as they are cheaper to make.
  7. If it is a small property then something like this in the kitchen and bathroom would help - basically you just need air changes to get the moisture out, this would do that and retain heat. Wire it into the lighting so she has no choice but to use it. https://www.fastlec.co.uk/hr100r-vent-axia-hr100r-rs-heat-recovery-units.html
  8. Planning documentation can be a bit bamboozling, especially since it is largely written in construction industry language that it's always clear to those not in the game. I would happily explain it to you but, I don't know your exact circumstance and don't want to advise you blindly, you build something, then you end up with issues. My advice would be simple, get a location map of your plot, draw or sketch it out on the plan with dimensions, email it over to planning and ask. They are usually very helpful, might take a week or so for a reply but if they say no, with that email you also have an audit trail.
  9. I now have some membrane! Thanks to both Christine and Jamie for offering, I took Jamie up on his offer, it transpired Jamie and I were only a couple of miles apart when he was at his work so it was logical (if I run out of this stuff Christine, I will be messaging!!) So this afternoon I collected from Jamie a part roll of ProtectTF200. The man was a gent and would not take the money waved in front of his eyes. I owe him one and this forum can be witness to that. Thank you Jamie, and it was nice to meet a fellow forum member in person.
  10. Smart dogs eh! He, was a rescue dog from just outside Edinburgh, he was the kindest most loving animal and behaved so well. Dog's deserve longer lives.
  11. It can be quite handy! Our dog will bring you things, if my wife is in the kitchen and I need matches for the stove for example, she can send him through with them. Or if I am upstairs and she wants to send me something she will give it to him and say take that to dad and he appears all happy with himself. Our border collie could open doors but only if you were not looking. Shut various doors in the house, come back and he would have opened them all en-route to the bed! If he wanted out the a room and you were there he would sit and look at it till you opened it for him. He was not daft.
  12. You need handles so your dog can open doors! All joking aside, a couple of observations from different handle arrangements, handle-less doors can end up quite dirty as people always seem to create a dirty zone around things like light switches etc. The other thing is if you are carying stuff, you can often get an elbow onto an handle push it down and nudge it open, possibly not with the grab handle type. They look smart for sure, probably better in an all adult or teens household.
  13. Torx screws are brilliant. The good positive drive even at slightly jaunty angles is brilliant!
  14. How much of it will you do yourself? That makes all the difference. If you did all of it except say the block work it would cost much less than 8K for what you have described, try about half. Get people in to do every stage and 8K would probably about cover it. Don't know why you would need founds done professionally - apart from the actual concrete bit (because I assume you don't have a concrete plant!) I wouldn't even do founds, just a 8-10inch slab, stick in some re-bar and that would work - give us details of your ground makeup and what level you need the slab to be at. You could rent a diesel mixer and do this in a day but you probably like your back! Sounds reasonable though.
  15. Why I would never buy a house built after about the 1960's - unless it was a self builders and done well.
  16. That's typical really isn't it. Took me basically all day yesterday to put 2 rafters up. OK I have 2 up and I now have my cutting plan so the rest will be easy but a days work 2 rafters! Should have had the whole roof sheeted! Like you, everything conspired against me, daft things like running out of extension cables and sockets and having to run back and forth to the old garage switching between air compressor cable, saw cable, drill cable, cable that temporarily feeds new garage, so each time I got to the new garage to grab a box of screws or wood or something I realised the door would not open and had to go back to the old garage, clamber over the mess, unplug something, plug in the garage supply, go back, open it, get the thing I went for...
  17. I think given the nature of what a shed is, assuming it will just be a small-ish shed I would just be building it, put it somewhere that is not too visible from the road or neighbours and just build it, the only way planning would ever actually know was if they happened to be on your property, or someone reported you. I doubt your neighbours would even suspect a shed to be against your planning and think to complain. A shed is a temporary structure, you could lift it up and move it somewhere if you needed. At the end of the day it is a shed, life is too short to worry and what are they actually going to do to you and if they did say take it down, you take it down for a week and rebuild it somewhere else, I would plant some hedges or tree's or hide it behind something. I do not condone flouting planning, if someone builds a wholly unacceptable building or extension in contravention of planning I would be the first to get annoyed, but, it is a shed! Build it. A friend of mine, who was treated very badly by planning and building control got really fed up with them and just ended all communication with them, he built an extension. It was all done properly but with no planning or warrant - the BCO happened to come round and stood in my friends new kitchen when it was all done telling him he could not do that, my friend just replied that "I just have" (typical farmer) - the BCO man walked out the kitchen door in 2004 and that was the end of that. One day the property will be sold... the extension will have been up for so long I doubt anyone would even think to question it's authenticity.
  18. Basically to test an RCD you need to "leak" some current in a safe manner to ground (i.e. it's going AWOL from the circuit - this could be via a person or animal hence it will trip) this creates an imbalance because current flows one way, but not the other, so it is "lost". A tester can set the "leak" current to a predetermined level to test the responsiveness of an RCD, so a 30mA RCD should trip out within 40ms at 150mA. There should be a test switch on your RCD - this creates a small leak locally and will trip it - if this works, and your sockets work, then it will work as RCD's will work regardless of a good earth - in fact, that is sort of the point of them is to detect remote leaks to earth, i.e. not via the earth cable because a remote leak suggests it is going via someone or something direct to ground - dangerous - wear wellies! Obviously it will also protect against leaks to the ground cable. I had an RCD constantly trip out on a garage circuit, it was because because the circuit, in a low lying electrical wiring connector in a freezer was damp, it was leaking current to earth via the damp. So really all you need is a damp extension cable lying in a puddle and an RCD would trip. Another way to trip them is to use an RCD socket, like the ones used for lawnmowers and things, or even use something like a lawnmower or external extension lead with one built in, hit the test button and it should take the main RCD with it at the distro board etc.
  19. The TBS doesn't need to be in a fancy £600 meter box - you could rattle together a small enclosure from just about anything lying about - it just wants to be solid enough it won't blow away and rainproof. Often a 4x4 fence post, concreted in securely with a piece of plywood screwed to it as a backer and an IP rated enclosure big enough to contain all the bits would be fine. Or get a sheet of ply and knock up a simple box with a door and shed roofing felt over it. Look about, you may even be able to re-purpose something, crying out loud now I think about it for £200 you could get a cheap shed!
  20. Looks pretty good on the face of it, this is just at a glance, but I would try and arrange bathrooms to keep water and waste/soil runs simpler and reduce water noises etc. I hate the noise of waste pipes. I am actually looking at the acoustic Marley stuff at the moment as I just cannot stand that splashing/sloshing noise in walls and ceilings! Master and bed 1 are fine, as they keep water and waste within 1 wall, I would then copy the footprint of bed 1 for bed 2 so that en-suite moves to the left which lets that tie into the master and bed 1 plumbing. Then I would have the laundry directly next to the stairwell, then bed 3 then guest, this would centralise the laundry closer to the stairs and mean only 1 wall of the laundry was next to a bedroom from a noise point of view. Make the plant room a bit bigger.
  21. OK - Between yourself and Jamie it looks like I will be able to get some - I have a friend in Carluke too! Let me work out what I need and what will be the simplest stuff to get hold of and I will be in touch. Big thanks.
  22. Wow so many offers. I too am in Glasgow most days. What stuff have you got there? Thanks
  23. Thank you, I appreciate this, for now I will see if Christine and I can sort something as she cannot be far from me. If it is not the right stuff etc. then I will let you know - I would also feel terrible if you gave me some then ended up short for your gable!
  24. It is for wrapping my timber frame - the bottom stuff looks like the job, is that Protect TF200 Thermo stuff in the bottom image? I cannot be far from you as you say, I have a friend near Lanark too so not sure if that is in your direction? Looks like this may work out if you can spare a little! Thanks
