Gus Potter
    34
Everything posted by Gus Potter
  1. Good point Nick. To add a bit. If you nip down to you local B&Q and look at the floor slab you see what we call tied (call these sawn joints) joints at 4 - 6 m spacing. About every 18m you'll see a movement joint, tends to have metal armour each side with a big bead of mastic. B & Q slabs are mostly ground bearing slabs, no rafts. As an aside when I'm designing pallat racking systems we try as best we can not to sit the legs straddling the primary movement joints. Ok so 140 m sq. Say it was a rectangle 9.5 x 15 m ~ 142m sq. You could probably do this as a ground bearing slab with a few sawn joints or non at all if you up the anticrack mesh density. If well laid and cured.. looked after then with a screed on top then it can work as you point out. I'm cautious as while it worked for you on that site it won't apply to all slabs. You make a good point about intermediate and ring beams. These if not detailed and understood properly can tend to lock the slab edges and say the middle in position. This locking effect increases the shrinkage stress in the slab that cause trouble cracking wise. It's a great job as self building and renovations for example test you skills, for me the more I learn the more I realise how much I don't know! Indeed. We may have a fair bit in common. I was a local building Contractor for 20 years before trucking off to Uni to become a Structural Engineer and Designer. It's almost a natural progression for those of us who enjoy their job. You build stuff following other folks designs, realise you can do better at times, learn, improve and implement.
  2. To add a bit to my last post. Structural raft foundations and ground bearing floor slabs shrink (mostly) and move about. Sometimes we need to split these up if you have a big house. It's quite common to various kinds of joints when designing industrial building slabs as they tend to be big. Optimised design is also looking about how the slab will move and shrink in terms of what we are putting on top of it. For example, we need to think about resting glazing on the slab or near to, positions of walls and so on. No point in having a massive slab movement joint right under your lovely large format kitchen tiles or sensitive glazing. Bigger slabs can move 15 - 20mm, no tile decoupling matt is going to cope with that. True optomisation results from holistic design. But it's hard (impossible?) to plan down to the last detail on a self build. The secret is to build in flexibility / options and that way you generally make overall savings.
  3. Progress! Well done. Here are a few nuances about raft design which I hope helps. When designing these for say a less experienced Client; self builder or someone (say a cabinet maker or mechanic) that want's a small industrial unit I'm always keen to understand and make the Client aware of the potential for selection of builders and how their skill set is reflected in the prices you get back. . I also want to know how experienced the Client is, have you done this before? how much do you want to get involved in the technical design and decisions that underlie the final drawings and specification that I produce. This can have a big impact on the actual cost. Ideally you want to make the job easy enough so more builders can price.. get a bit of competition going. To try and explain briefly. For a reinforced concrete slab to act properly as a raft we need to for example control the thickness... ideally it should be of even thickness...but definitley not too thin in places. The slab can end up being too thin if we don't specify a level tolerance for what is is sitting on. Now if I say on my drawings that the EPS or insulation under the slab needs to be between +0.0 mm and minus 5.0mm then most local builders would think I'm nuts and add on a cost, tell you that your SE is an idiot or worse just not do what you are paying them to do. Let's select a general tolerance of 0.0mm to -15mm for how level the EPS needs to be. This is still quite a big ask when the winter rain and snow is running down your neck! That said we don't want massive low spots as it stops the raft from sliding as the concrete shrinks. If you make it harder for the slab to slide during curing and drying out a bit then this can make the cracks worse. We may want to put a screed on top of the slab with underfloor heating pipes. Here we need to control the how level and flat the top of the slab is. We may say that from a datum no point of the slab is to be more than 5.0mm higher and no more than 10- 15mm lower. If the slab is too high then you run into trouble with the cover on your UF heating pipes, particularly if in the heat of battle on site you need one pipe to cross over the other. Now there are some folk on BH like @nod and @saveasteading that are highly experienced at this and can work to tighter tolerances... but they know their stuff! If you are a novice at this then tighter tolerances are not for you! On paper I can make a raft pretty structurally efficient (I've a tool box of tricks and different design methods) but your chances of building it for reasonable cost as per the specification are probably pretty low unless you have a lot of experience and can adequately supervise (needs experience and time) and monitor the delivery. A properly optimised raft is one that performs structurally, is designed to suit you skill set in terms of access to builders, amount of suprevision, location, finance, surface finishes and so on. The motto is .. keep it simple!
  4. Yes as the plastic introduces a slip plane which destroys the composite action between the masonry above and the lintel. If you bend a beam (also a composite beam.. composite lintel) downwards then there is compression in the top, tension in the bottom. When you balance all the forces within the beam you'll find not least that there are axial shear forces along the length.. the top of the beam is in compression so it shortens.. the bottom is stretching getting longer.. so there must be some axial shear forces in there. If you put a cavity tray in then the longitudinal shear force is not transferred between the brick courses above and the concrete lintel.. add a bit of water to that.. as that is what cavity trays are for and you have a good slip plane. Hope that makes sense? In this case you need a non composite lintel. This is roughly how a composite lintel works.. but you often need sufficient masonry each side to act as bit of a buttress to the imaginary arch to be on the safe side. If you look at the manufacturer data for composite lintels they give you this information on the number of bonded courses of brick you need over the composite lintel to make it work. Many manufactures data tables use a safe working load (SWL) which has the factor of safety (FOS) built in. This is fine for normal day to day stuff but watch out when you go for the longer spans as the deflections could cause other issues with say bifold doors below or sensitive renders. Always check to see if the lintel manufacture shows their loads as the total load or a UDL load (load per metre run of lintel) In the round I often use non composite lintels as the extra cost outweighs the on site risks of bad workmanship, folk making late changes (an enthusiastic heating Enginner coring / slapping holes in the theoretical arch etc) to the design or propping an faffing about.
  5. Good point. I get a few folk a year and look at stuff ourselves where these cracking sites come up. Then you lift the bonnet and find all sorts. Most of the issues with these dilapidated things on small sites lie around servicing it and associated legal burdens. My mind set is like you perhaps.. ok lets go back to the beginning and see where the problems really lie as above. The seller want to sell.. you want to buy! Now here you need a bit of good faith but at the same time you don't want to incurr full on professional fees each time you look at a distressed property. You can get around this by either doing a lot of learning.. and by that I mean a lot or keep someone like me on a retainer, basically phone a friend. I have a couple of Clients who work this way. One is based in Glasgow who does both commercial and residential property development.. and we often chew the fat.. probably 1 in 5 to 10 projects end up getting taken forward to the bidding / financial negotiation stage. Remember one of the many common laws of business.. turnover is vanity.. profit is sanity! What you say is right.. it's about managing the seller's expectations... but not giving away just how you are going to make the project financially viable as some of these folk will just pinch your idea and advertise again using your hard work! It's a mucky business! For all though. Sometimes you see a property with a nice clean title and a friendly seller that is just stuck. Case in point. I worked on one years back where the public road was subsiding into and towards the house that was built lower down the slope. The highways were claiming that the house owner was liable... which basically made the place unsellable. The solution was in effect to use the first floor of the house as part of the stability system to retain the road retaining wall.. kept the highways department happy and that made the project fly. One trick here was to dig out quite a lot of soil and replace it with EPS as this reduced some of the soil loads behind the retaining wall . The off street parking was then built on top of the EPS which also served as great insulation to the semi basement wall. I'll do a sketch sometime for all. To conclude.. usuallly it's a service thing.. but sometimes the project can fly with innovative Enginnering.. which floats my boat! @Jimbobjones Good luck and hope you can do a deal!
  6. Thanks for all the useful comments folks.. will mull it all over... lots to learn!
  7. To add a bit. When we want to build on rock to get going we need to get a feel for how the rock is laid down and it's properties. We start with the compressive strength. That would be if we found a homogenous piece with no cracks, no weathering etc and crushed it in a test rig. Usually that gives a big number. But we need to know this number if we were to bolt a steel column with a thick steel base plate directly to the rock with a bit of grout under it. Here we have a higher localised compressive stress, like under the heel of you shoe. But often rocks have cracks in them. It's not solid rock. The cracks can be filled with other material. What we also need to know is how the cracks are spaced and their approximate width. We also need to know the direction of the cracks and plane. Rock (depending on type) can crack in 3 dimensions so it takes a bit of working out. Think of say leggo blocks. If all the leggo block interfaces are horizontal, vertical, interlocked and nice cubes.. they will carry more weigth. But if the leggo is slanted then they can slide over one another thus will be less able to bear load. If we have wide cracks in the rock filled with say clay/ silt / organic soil then the water gets in and this all acts as a lubricant which lets the blocks of stone slide more easily. When resting a building on sloping rock we need to work out if the rock will peel away / slide towards the open face or not and to make a judgement we need to look at the above not least. If it were to do so it would pull your supporting columns with it. Generally most rocks can take lots of load. Even if they have cracks they are fine so long as we have some confinement. If the rock is reasonably confined against sideways movement it can't go anywhere!
  8. Love this! Watched the video, brilliant, love how direct glazing is explained and the cost element for example. This is the sort of stuff I enjoy, fraught with potential structural problems, reg compliance and legal burdens. In Scotland, not least the Church of Scotland, WRI etc have been selling things like this off and they can go really cheep. Sometimes you can pick them up when folk have bought them off the church say, lost their shirt and have to sell on! If you want to buy something like this you need not just to get all your ducks in a row (lots of research and learning) but also spot the elegant and cost effective design solution. Up front this is often getting the site services and foundations sorted out. There are bargins to be had but research and engineering solutions are the key. To be honest you often need to have an SE on board that also knows about drainage and all the rest that has lots of experience before you put in a bid for these things. You then need a good solicitor to wrap up the deal legally! In terms of cost anything that cantilevers often attracts extra cost. Building straight onto rock.. often a joy. I've done the odd build on rock in Scotland. Often it's not the rock (even some slightly weathered rock.. will often happen with Tuff) but BC and the NHBC that cause an issue as they bang on about frost protection. Often they just need a bit of education about frost heave, how ice crystals grow, their water demand and grouth rate. Don't forget it's just a house you are building which is pretty light weight. Funnily there are lots of houses in the UK built on rock.. extending them can be easy at times once you get your head around the common constraints and convincing BC that you don't often need to dig out the rock to put concrete back in the hole!
  9. Hi all. I've had a bit of a rake about on BH and read around some of the great stuff you have been posting about AI and how that may fit into the self build market, conversion of farm buildings to domestic and building extensions. For me I started out some 40 years ago in construction before we had computers and the internet. Quotations were typed out and sent by post! To provide a bit of context I now work for myself as an SE and Architectural Designer. Prior to that I worked and trained mostly with a cold formed shed steel company that sold a lot of buildings in Australia and the UK. They were the biggest supplier (of CF sheds, some we turned into houses etc) by a long way in the UK. My role there was to develop some the engineering calcs, do a bit of R & D and design raft slabs etc. But the funny thing was that it was almost a software company that sold steel sheds via franchises and this is done via the internet.. a web site. To summarise.. AI I think is just a natural progression that needs to be used as a tool like any other. But I'm struggling to work out where to go next! At the moment my bread and butter income comes from designing extensions, loft conversions, knocking a lot of holes in walls to form open plan spaces. The other part of my portfolio is what I call "whacky and challenging stuff" for want of a better word. This could be anything from an interesting self build, farm building conversion to the odd bit of dispute work say against the NHBC. Now technology we know moves fast and I've been trying to get my head around whether AI is a threat to my income stream say over the next ten to fifteen years.. and then I'll probably hang up my boots. Here is a link to the RIBA where they talk about this: https://www.architecture.com/knowledge-and-resources/knowledge-landing-page/no-turning-back-41-of-architects-now-using-ai?srsltid=AfmBOoqSGRmmzU3V9DcDtLc4hEeimXg3_kxSkilpP1ux1xJ6xEoRjH8O To save anyone but the very keen reading . In summary there are a lot of mixed opinions and some Architects are dabbling with AI. There is some interesting points on design responsiblity, copywrite, who is training the model and providing the data that AI learns from? There is an element of justifiable nerviousness. Another rough quote I saw elsewhere was, AI is not a direct threat to say the Architect / SE in design experience terms but it could make you much less competetive if you don't use it.. like we use excel or word.. which is a strategic business threat. If you go bust then.. Personally I know I have to get my head around this in some form or another if I want to still be in business in say 5 or 10 years time... but where do I focus my learning effort. At the moment I see this panning out as having access to better (cheeper) SE visualisation and Architectural rendering of finishes. This could maybe extended to show how say a traditional cut timber roof works to act as an aid to the contractor when pricing. Funnily I use a pretty high end structural steel and timber detailing package that does all the 3D stuff and produces the fabrication drawings anyway. But it is an SE package and does not do Architectural renders for example. Often I'll add some screenshots to a complicated 2D SE design drawing so folk can see how it fits together. But could AI know just how to pitch and angle a screenshot to capture all the tricky bits that a builder needs to know? I just can't see AI at the moment helping me design a padstone at the end of a beam on an 120 year old stone structure, with 5.0 metre bifolds under with some lateral stability problems. Then you have the temporary works.. propping and so on.. all to be cost effective. But where is can help a lot is in basic visualisation if it is cheep! As a one man band my unique selling point is my experience and the fact that I wear two hats, SE and Architectural designer. This make me competetive financially (one stop shop) as I am able to "see the whole design picture", and this is attractive to some Clients.. but not all! Now scale that up a bit to say a small Architectural practice. Again they have a USP but I think it will be the big outfits that may, as always wil use this first.. which at the moment puts it out of reach of the self builder. I'm tying my ownself in knots here as am just learning! I think AI will be at first low cost but then the software fees will rack up.. and this has to get passed on in some form or another. The question is.. Will it make self building / extending more affordable? Personally I hope that there will always be a need for a designer like me, small and in a niece market. But one hard law of business.. how much do you cost! In ten years time someone may call me an "Artisan Designer".. I hope! Maybe a way of explaining my raw thinking is to refer to Adam Smith, The Wealth of Nations; circa 1776 where he explains the division of labour. AI is in some ways doing this.
  10. Stunning! Your hard work has paid off.
  11. I could have worded that post better. Still pals I hope?
  12. Yes thanks for the offer. xxx
  13. To question (a) correct, (b) first part .. yes they can make the thermal detailing easier depending on what level of insulation you want to achieve. Sometimes it's cheeper and most effective to go for a simple strip found that a local builder can do in their sleep and add a bit of extra insulation elsewhere in the easy places.. this can be called the compensatory design approach to insulation for example. Design is often about making educated compromises on some details so you end up with a better job performing and buildable job at the end of the day. It's surprising what you can get a raft to sit on in terms of ground bearing capacity. I've done some whacky ones with an allowable soil bearing capacity of 30 kPa in soft SAND near the coast... a nice value is normally around 100kPa about ten tonnes a square metre. But that is not all of the story. A low bearing capacity soil can also be a CLAY soil where is swells and shrinks. This makes things more tricky as while the soil may carry the load ok it keeps wanting to move up and down over the seasons. You can do rafts down to quite a depth at times. Down to 1.0m is perfectly doable at times but beyond a 600mm depth of hardcore the NHBC want the fill to be specified and designed by an SE say. Sometimes (you need to be brave and get your sums right) we dig out the heavy soil and replace with insulation and a less dense material so the soil at the base of the excavation does not "know" we have popped a house on top. Here is an opportunity to use say Foamglass Geocell as it is light weight, good bearing capacity and has a quantifiable U value.
  14. Yes. A reason is that on self build you have much more control. Mistakes will get made, people won't turn up on site when the should and so on. The Kore stuff may fit on the draiwng you give them but you'll need to pay for a good site survey. Also say you start digging and you hit a soft spot in the ground.. what do you do.. phone Kore or a friend? Hey, if English is not your first language your get a prize for putting me on the spot! (calling me out) You starting point is to get some base prices from say Kore, and so on. Then run it by your SE and see how you value engineer not just the foundation but also the superstructure. For all we know if you get prices from different folk their interest is not yours! They just want to sell you stuff! A lot of people on BH are their own worst enemies. They want the cheapest price for everything, but in the heat of battle they end up loosing money... as they don't know when to pay for some professional advice. It can be done and you can drive down the build cost a if you take time to identify what you want and then negotiate with builder.
  15. My objective is to save you money. It's not often I start a new topic but here are some of my thoughts. Please excuse the spelling and grammer as I'm a bit dyslexic and off duty from my day job. Bit of narative first to let you know I know my stuff! Over say the last 10 years I've seen a lot of enthusiasm in the self build market for insulated rafts in one form or another. I got into this as an SE and developed the design calculations for the biggest supplier in the UK of cold formed steel industrial buildings, about 750 to 800 descent sized buildings a year. These are lightweight buildings with low floor loadings, like a house.. that sit on a big thick layer of squashy insulation. an insulated raft. I had a loads of fun at Capital Steel Buildings (CSB my employer), Gary Watson, their CEO, his directors in Australia not least put their money (a lot of 500k plus) and faith in me. Gary Watson the CEO who lives in Dalry, Scotland! So this is not some abstract concept for me! He lives just down the road pretty much, stuck his own money behind me and we sold a lot of buildings in the UK. Many thousands! I know a bit about this insulated raft malarky in terms of structural and geotech design! That said if anyone wants to engage with me on the theory then I would be delighted. It is a bit of a dark art, coupled with plastic and yield line theory design. I really push the boat on it but am always safe. Serviceablity needs discussed but I know the maths! For all the corners of a slab tend to be the bits that are hardest to get to work. For any curious SE's lurcking in the background. I took TR34 as a basis and then developed from first principles.. there is no "funny FE " software used! It's all verify able by excel! For all in some ways the design of insulated domestic rafts is very elegant and often cost efective. But get it slightly wrong and you are in trouble! But make no mistake we were doing this stuff in a hard and competetive commercial market probably before Kore rafts etc and Tanners design became more main stream in the self build market. For me I'm delighted that self builders are getting on board with insulated rafts and the whole passive house thing. Aside I wish I knew about this stuff when I did my self build, with hind sight I made some mistakes. Ok here is the rub. There are folk now jumping on the badwagon that I and others developed 15 years ago but they don't actually know what they are doing! Manufacturer's are creating insulated formers that come at a premium cost and claim they are at the cutting edge.. they are not often in terms of buildability! I know this as I as above developed lean desings. These folk are there to sell you insulation and their building system. *Kore etc are there to sell you insulation! *MBC et al are there to sell you timber frame! *You as self builders want to get an SE or Architect at the same price as a washing machine engineer. My advice is to look at simple stupid alterantives that you can get off the shelf! that can be a bit of PIR insulation cut up to avoid waste and perfom the same function. Example: someone pitched up the other day wanting to use a space frame. Someone said oh Kore do a thingy that can support the outer leaf. I think why as an SE can you not just specify a couple of braces in the frame so you don't need that complex outer "thingy" detail? Ask me if interested. Now folks I hope you have found my rant informative or just funny / daft. Design should be fun. The design process.. well if you don't like what I've written then you can rule it out.. Design is often about ruling stuff out and that lets you focus on the things that matter. To finish. As an SE I love, and it is a challenge to explain to a lay person how stuctures work. I have Man bag, in that is ruler. I pull that out to explain how buckling of a beam works. There is a soft rubber and my hard plastic measuring tape. I use these to show how the different layers of an insulated raft work.. the rubber is less stiff than the tape when you put one on top of the other..this lets folk see that the insultation is the critical design layer. The maths are complex but the Client immediately can grasp what we need to do, why and the raw cost implication.
  16. Good thread. But you do know this varies over the day? Stop being wanky and go back to basics! Your taps and flow valves will wear over time.. I piss myself laughing at you all talking about 0.1 bar pressure, static or dynamic..oh and a couple of rough bends in the pipe and it bollocks! I can tell you that your qualitative values are complete pish in terms of long term performance. In a sealed system 0.1 bar can be lost by a mugfull of water weaping from a joint! Yes I'm the philistine.. We have been using direct cylinders for at least 30 years, well I remember it was about that long ago that I fitted one, it is not rocket science.. just needs common sense. My prediction is that your plumber will part company with you. To avoid this identify what you can live with.. start by asking the other members of you family... as good design is for all. I'll say this again. There are folk on BH that are trying to make UFH and a hot water supply into a complex subject. Yes in a big hotel say it matters a bit but for a self build.. get a grip! You are off your heads! I have been into UFH and the like long before most of you were born! @nod are we of the same age? and sometimes the elegance lies in the simplicity, low maintenance and reliability costs! I leart my skills and design skills from the Scandinavians and industrial sector, the UK self build market were late to the UFH game, ICF and insulated rafts. Funnily I was doing a lot of this stuff before the self build market got a foothold. Why! 1/ In one or two years time the valves will get sticky / pumps will wear, the boiler will wear and things will start playing up. You just can't seem to see this folks! 2/ Your average plumber will have no clue how to service all the shite you have installed. 3/ If you sell the house how on earth are you going to run this by a surveyor. I could go on. Keep it simple folks and it will save you money! Maybe test you flow rate on the incoming service pipe. Open the pipe, get a bucket and let it flow free. Time it to get the delivery of a quantity of water. Do this in the middle of the night at 4.0 am, at 7.00 am and at 4.30 pm when the kids come home from school. Do this over a couple of months or so.. the water board get leaks and muck about with the water pressure! Check between winter and summer flow delivery. Then you may realise how your calcs are a not applicable! Is that it? You probaly need to fit another £ 5.00 automatic air vent from screwfix!
  17. Good post. To provide a bit of context. I'm an SE and Architectural Designer. Everyone is trying to cover their arse. It's not that they are bad folk, most are great designers and know their subject.. but the insurer's are going nuts. The fire stuff has major implications. I've spent lots of time negotiating with my SE insurer about what exposure I need for fire safety. @ETC how is that going for you? I'm trying to explain to Buildhub folk how this works.. can you reciprocate? Next you have building control sheading all liability in terms of anything to do with fire. You have bit it of a journey ahead of you. Best thing you can do is post good constructional details on BH. A word of warning.. if you want good advice then post all the info you have. I'm like many other folks on BH here that are willing to give you a bit of pro bono advice. If you make me guess then I will bin you.
  18. This is a bit long winded and a bit of a read! But I hope there plenty nuggets in here for the self builder to chew over. For the budding young person who wants to make a carear in the building trade.. I start with an introduction. 40 years ago I came out of college with an HND in Civil Engineering, went to work for Wimpey and got sacked because I was a prick.. I then went self employed and my first job was tiling a bathroom for a neighbour. I worked out the cost of the material, my time and overheads. I then build a business in Edinburgh and employed a few folk. I met the girl of my dreams and we bought a plot in the Scottish Borders and did a self build. I employed an Architect that used to shove me a lot of work to do my design drawings. I got up every morning and built the house which took me three years now we expected and planned for that so we priced that in. Me working for free but no tax to pay. We lived in the garage and a caravan. Looking back I'm very lucky to have been able to do that, few folk just don't get the chance although many are more than capable. We had no kids, a German Shepard and that was it. To cost it I worked out how much materials I needed by measuring off the drawings and added on a percentage for waste (stock lengths of timber, lorry load deliveries of sand etc) and the mistakes I would make. About 10 -15%. I worked out how long it would take me to build the house, just by myself. I took me three years as above but I was young, fit and had my experience. As I built the house, it was near a road, locals stopped and asked.. see when you finish Gus will you come and build our house. I did that and ended up being one of the biggest employers in the local area. Now to price these jobs I still broke down all the material cost elements, I know how long each building task takes roughly so I can apportion a labour cost to that. I know what the business overheads are; running vans, sick pay, cost for apprentices and staff training, contractor insurance, plant replacement cost and so on are. I used a spread sheet to work all of that out and then apply a profit margin. Now a spread sheet can be a dangerous thing! A mistake could cost you your livelyhood (for self builder.. put you money at risk) and put your employees jobs at risk. I used to do a second qualitative check to make sure I didn't loose my shirt and pants.. which was based on.. for a standard self build the labour cost should be about 1/3 of the base cost. In other words materials are about 2/3 of the cost. This is a good way of getting a good figure of labour material cost ratio as it tends to be inflation proof.. it's used as a qualitative check on the basic envelope and then you add in the big ticket items.. doors, heating etc. All the time you are looking at the different ways and methods of costing. Most are qualitative but even these give you a feel for what looks right and what is not. Next was to look at the square metreage. At that time it was a lot less but say at the moment 2.0k a square metre. Do not use this value yourself, I've picked the number as it is easy but you can again do a check. This is the third check. Now I was a building contractor and I wanted to make some money. Personally I don't gamble, don't but a lottery ticket. I still run a business as an SE / Designer and want to make a profit. The last bit that goes into the price is based on how much profit your want to make, for me now it's often about how interesting the job is and how you hit it off with the Client. I've picked up the odd job on Buildhub, the profit element is often very low but see the enjoyment I've got out of it working and learning from loads of you clever folk here! Jumping forward a couple of decades or more I'm now an SE and Architectural designer. I still use the same rules and techniques when Clients ask me for a budget cost. In some ways because of my background I'm actually doing what a professional Quantity Surveyor (QS) does but in a rough way. Some of the builders I work with use a QS to price all their jobs.. but that comes at a cost. Others adopt old school pricing methods coupled with modern techniques like I do. Some small builders go on the internet and look up what the internet says and add 20 -60% or just double it.. if they get the job then they know there is so much profit there they can afford to figure out how to do it once they have collected your deposit. In terms of pricing self builds, professional fees and contracts. Often I get asked by Clients what kind of contract they need. Now my opening gambit is that you should have an industry recognised contract that it tailored to what you want to do. Could be a minor works, JCT or NEC type. But all these need some element of extra professional input that comes at a cost and that cost can at times be 80% of the original design fee, do you know how much a Clerk of works costs! Simplistically if you want me to do this then I am responsible for your money and authorising payment on your behalf. If I cock up you have a perfectly clear run to to sue me for your losses. To be clear If I authorise a payment to the Contractor you have to pretty much cough up like it or not! Now this is a Self Build site. Most folk do their own deal with a builder. For many it works out well, there are a few casualties but that is the risk you run folks. I'll stop here but Build Hub is a great place to learn. I learn all the time!
  19. Agree. I neglected to think about an in situ slab, sorry about that. That is probably beyond the realms of reasonable investigation as you say. Now for all. From time to time we encounter buried asbestos. One great place to find it is obviously on industrial sites but also in and around farm buildings.. steading conversions are a good example. Made ground is common and also things farmers call a dead hole..to put dead animals in. Now often we find old asbestos cement roofing sheets, broken up in the ground. The first thing to do is to ask.. how well compacted is it? The stuff does not rot away, cause ground gas so can we just leave it in situ, isolate and build over the top? As an SE if it has sufficient ground brearing capacity then what is the problem? In other words we can just treat it as some form of compacted inert material. There are plenty precedents for leaving contaminated ground on site and isolating it but you need a convincing and logical arguement to do so.. A good way of stopping asbestos getting airborne is to keep it wet. Hence if mixed with clay soil with a high water table.. all good news. On big contaminated sites we look at the risk to local communities of carting the stuff away ( dust etc escaping from the lorries say ) on public roads cf leaving it in situ. The same principles can be referenced to convince say BC that you are doing the right thing by containing contamination on site. I make reference to a job I did recently but I only found out as the designer after they had spent a pile of cash digging the stuff out. For all if you find asbestos stop work.. don't panic as this can often make things worse, think and make a plan, seek professional advice even if just to reassure.
  20. Yup.. just happened to a Client of mine, simple extension on a listed building that had been extended in circa 1960's and then altered again. Asbestos roof cladding found buiried under the extension foot print. This is a risk. Do you pay for a more indepth site investigation (would have uncovered it) or take you chances? As an aside I've a project on where I'm taking down part of an old extension / conservatory and retaining the foundations and floor.. about a 25k saving. The thing has moved a bit so have settlement tell tales on it.. story for another day. It has a felt roof and I've seen the original specification. There is mention of a roof felt called "Astos".. the clue lie in the name. It's low risk but does contain asbestos thus needs to be dealt with and the risks managed. Inevitabley there is extra cost but this is non negotiable for safety reasons.
  21. One more to go by the looks of things. @CemCet I'm sure there will be folk happy to do a follow up interview. For all. Gathering raw and real life data can be exceptionally difficult at times for a researcher / someone studying for a masters or doing a thesis. A lot of the manufacture's for exampleclam up when you ask for the numbers behind say their load span tables.. commercial confidentiality and so on. You start with your subject.. get enthused, funding in place and acceptance onto the course and then find that there are an awful lot of uncharitable folk in the real world.
  22. That's a cracking pad! I've done a few of these over the years, hope this helps a bit. a) SIPS. Too tricky and you invetitably make changes as you uncover and discover more about the old structure as you go. The secret is to have an adaptable / flexible design. b) IFC. My own view.. not suited for this application. The problems will start in the ground and work their way up not just structurally and dimensionally but in terms of insulation, condensation risk, detailing and finding a contractor that can get their head around even some of that. c) Stick building (some can be structural some non structural timber panels) is ideally suited to this. Often you want vaulted areas of roof.. that suits a cut roof with the odd steel. Elsewhere you can use standard prefabricated trusses, can be standard finks or attic trusses. I can't see any problem getting a stick build signed off in Scotland as this is the sort of stuff we do a lot of. @saveasteading knows plenty about this, has hands on practical design experience and a great eye for keeping costs under control. As an aside.. see on your rear elevation there is a slight arch over the two cart doors. This is fascinating.. how does it stay up? Well one way is that you have a good bit of masonry butressing them each side. Have a look at this and appreciate the art. Keep this in mind.. if you mess with this too much you could introduce unwanted cost and movement in the masonry. Keep us posted when you can.
  23. One secret of self building is to work out where level and dimensional tolerances really matter and where they don't. You want to keep you options open in terms of what your local trades can deliver. Looser tolerances can drive down the build cost. Work on 65mm for now and your life will be a bit easier. Beam and block joists have a camber due to the prestressing but the camber is not even! The precast folk cast the joists on a long line and cut them to size after curing. The prestress in the cast line varies from end to end so some joists have diferent levels of prestress and thus different amount of cambers.
  24. To be blunt you both (wife and you) seem to know what you are talking about. But there is no mention of getting a cost aware SE involved that has 30 -40 years experience of knocking Architects into shape. Forget the QS idea. and don't even try to take the Architect on in terms of their design delivery drawing wise and so on. To win this you'll have to show they have been negligant. Your Architect will want to get the job done..they don't want you reporting on social media... maybe they just need a guiding hand. You too probably need a bit of tough love and some impartial advice that a good SE with a wide range of Architectural Design experience can provide. Don't forget folks that SE's get to look a Architectural designs all the time.. we kind of know what works, how details can look good, what is expensive and not buildable at practical cost. You mention that the costs rocket at stage 4. The blame for this lies with the Architect unless you have moved the goal posts? . This is a small project and needs to be treated in a different way, particularly on a project like yours. That said don't fall out with folk until you have exhausted all the avenues. So long as you are still talking to each other a compromise can often be reached.
  25. Fair comment and accepted. For the avoidance of doubt my core qualification is my Masters Degree in Civil Engineering. I specialise in Structural Engineering but have now wondered ( it's a natural progression for me) into the Architectural design side. The key here is the word "Civil". My underlying responsibility lies to the public first and foremost.. not the Client who may be paying my fee. Now like many other Civil Engineers @saveasteadingwho may say design a dam we have to carry a burden of responsibility. If we get it wrong we can kill lots of folk. This moral, not least, responsibility comes with the job. To be frank sometimes the job keeps me awake at night! Have I got it right, have I done something daft that could fall down and kill folk? The job I do is massivley creative and rewarding but there is a price to pay for the privalge. I think engineering should be fun.. it becomes particularly rewarding when you have the skills to design from first principles.. which my education has taught me to do. What makes it even more fun is when you sit down with a self builder and value engineer their build / get initial prices from builders and get involved in the finance side of things. For me I then get to see all of the picture and feel part of the design team. But yes the internet is faceless and sometimes humour does not transfer. I'm a bit deaf and lip read a bit so know all about that! Fair enough. Your approach is pragmatic in that you know you need to manage the loadings. Hope the Wolf Design guide gives you some food for thought. Be careful if you want to muck with the roof bracing.. you may be tempted to alter this?
