Roys
Everything posted by Roys
John, you are welcome to borrow mine, I believe I am just round the corner from you, I am between Stranraer and Port Patrick and will be not far from my door next week. Not used it for a while but from memory think I just used a 12mm ish nothing fancy rope on it.
Precast Concrete Stairs or metal?
Roys replied to CalvinHobbes's topic in General Construction Issues
Personal choice but I like metal, less bulky plus I like the industrial look. -
No hydrants within a couple of miles of me, my water is pumped from my own well. Fairly certain but don’t quote me that as part of the planning for the 4 properties in this area we each had to have a pond for fire fighting purposes.
3 phase electric supply from 3 same phase cables?
Roys replied to WWilts's topic in Electrics - Other
Oh this is an interesting one. Dave certainly has the best idea of asking the charger manufacturer, looking at your block diagram 3 phases IN phase would appear to be OK but it it is only an assumption and need confirmation from manufacturer. Please tell us what they say. -
Temporary power to static caravan
Roys replied to DragsterDriver's topic in General Self Build & DIY Discussion
Do you have a friendly neighbour that you can run an extension cable from, make it worth their while and give them a few quid, generators are a last resort. -
Woops there goes another one..... ! Nearly
Roys replied to ToughButterCup's topic in Tools & Equipment
I like to do a “high 4 1/2” with my nephew as we have both lost half a finger, me when I was 12 with an axe splitting wood for kindling, him when he was about 8 when a door closed on him at the hinges at a sports centre. My grandad had lost all the fingers on his left hand when he was 15 in a guillotine accident at a foundry, stopped him getting called up to go to WW2. -
The angle grinder cut edges on my roof are hidden as they are either under the ridge tile or under the slate gable edge trim, I also used slate and 1/2 so that the alternative row ends had a larger slate as I didn’t want the wee 1/2 cut slates. Scottish roof so it was nailed directly onto sarking boards with a breathable membrane.
When I did mine, I used a 9” angle grinder with a diamond disk, hot knife through butter.
I use a Clarke BPT 1200SS booster pump, this sucks the water up 2m from a well and then pumps it up at at a guess 6m to a loft header tank, it has a pressurised bladder in it as well so the pump is not switching on and off all the time. Works by sensing the pressure in the line, from memory pump switches on at 0.5 bar and off at 2.5 bar but don’t quote me on that. Works very well and I think it would be more suitable for your needs.
Have you had someone staying that doesn’t know about not putting female sanitary products or wet wipes down the loo?
I still have a big question on how the electrical infrastructure will support all the extra load from heat pumps, electric heating and EV car charging when he try to get rid of gas boilers and petrol cars. The supply cable coming into the street ain’t very big and our spinning reserve of generation ain’t big either. Yip houses with good insulation is vital but as stated a lot of the housing stock is around the pre and post war era and can only be improved so far. What do we do at night when the wind ain’t blowing and so there is no solar PV and we have mined all the limited supply of Lithium for our batteries. The interconnectors to Europe are working at full tilt and importing leccy possibly generated by coal anyway. Can’t help thinking there is a lot of green wash getting painted about by politicians trying to vote score without thinking things through. Lets get our housing stock sorted, properly assess the environmental impact of people like me that will be encouraged/forced into scrapping a perfectly good ICE car for a Lithium battery car, encourage less babies by stopping family allowance at two kids. I can go on but I don’t want to sidetrack us too much.
Kitchen Cabinet Sockets - Surface or Flush mount?
Roys replied to wozza's topic in Electrics - Kitchen & Bathroom
I usually surface mount on the side of the cabinet, because as stated above the backs on a lot of units is thin. -
Give it a year or so and the building will be down on its own accord anyway, ? This looks like a fantastic project.
I bought a roll of code 4, 2 years ago, told to go and just take it from the pallet, oh how I laughed when I thought they had stuck it down, they hadn’t, it was just a lot heavier than I thought it was going to be, if my memory is correct I think it was 40kg.
Advise required around new roof - not straight!
Roys replied to Ryan G's topic in Roofing, Tiling & Slating
Mmmm not sure, would have to look into that but I’m afraid it’s quite far down my priority list unless wife decides otherwise ? -
Wish my roof kicked up at the ends, I have black streaks down the white washed gable ends because there is no kick up. -
Sounds like a great build, I spend more time in my workshop than I do in the house. Where roughly are you in Scotland, no need to say if you don’t want to. Good luck
Sounds like you have a decent builder there, good luck with the rest of the work.
During 1st fix I ran a good quality coax and a cat5e from under the stairs to each bedroom and living room, and just a cat5e to the rest of the rooms. The Virgin bloke was happy that he didn’t need to run any cables, although the first thing he did was meter my coax to see if there was any signal loss either by cable damage or low quality cable.
Make it 6, Flashing kit is part of window.
Screening Ideas to Block Chronic Curtain-Twitchers
Roys replied to harry_angel's topic in Landscaping, Decking & Patios
I can only imagine how horrible it must be to have horrible neighbours, guess I have been and still very lucky to have good neighbours who look out for each other and help each other. What makes this thread even sadder to me is the OP is building a house, putting money, time, effort and probably his soul into this building, and by the sounds of it there is going to be a toxic relationship between him and these neighbours, definitely not a good situation for the present or the future. -
There is an advantage to curtain twitchers in that they are keeping an eye on your place, give them your phone number and ask them to phone you if you see anything suspicious. We all keep an eye on each other’s place where I am, quite reassuring. -
I’m no detective but a wild guess would be Angus in Scotland ? clue is under his avatar. Of course that could be a red herring and I might have jumped to the wrong conclusion.??
Trial pit for structural engineer but hit shallow bedrock??
Roys replied to Greenmonster's topic in Foundations
Can’t say what you should, do but when I got my workshop foundation trench dug I hit bed rock at about 800mm on one corner of the build, stretching about 3 m out in both directions. BC made be get an engineers report, the engineer told me it was pointless pecking out solid rock but I did have to put rebar in at the transitions between soil and rock. It was 15 years ago so things might have changed since then including my memory. Good luck -
When I bought my land 15 years ago there was no Wayleave in Place so trees were starting to get very close to the 11KV line, I immediately contacted the network Wayleave dept who sent me an agreement to sign, which had the rates they pay you per pole and per stay wire. I signed and then they came on an inspected, Couple of months later there was a fair bit of activity with a pole getting changed and tree / branch clearing work. Yes the soft ground was chewed up but it heals with 2 or 3 months. It also helps prevent my neighbours and I getting power cuts. Now they just have a guy walking the cable route every 5 years and then a follow up visit by a 3 man gang for a day chainsawing and clearing, not much, to hardly any ground damage on these follow up visits. Bonus is, I get a small cheque from them every May.
