crispy_wafer
Everything posted by crispy_wafer
Ta, i’ve put some ducting in and run a sensor to each of the bathrooms. If the time ever comes I ought be able to pull it through with a new wire attached… I only needed a couple of small mats so heating load wont be too much, and as it happens I’ve gone for a 150 in the highly insulated room, and 200 in the other one, but thats only because the vendor has run out of the 150 the mats in the m2 I wanted…
Hi All, couple of quick q's, Is warmstar still the go to as far as tried and tested UFH mats is concerned please? For installing in a bathroom, onto xps board over caberdeck, how would I determine what Wattage p/m2 to go for? Tiles or LVT will be the final floor finish.
Are these numbers ball park please?
crispy_wafer replied to Post and beam's topic in New House & Structural Warranties
Site insurance - just in the process of renewing mine for another 24 months... 1200 ish. hoping to be finished in 12 (he says) but it's useful to have for hired in equipment. Values vary on reinstatement costs, public liability amount, how much for your own tools, site huts etc. -
Planning permission for new sewage treatment plant?
crispy_wafer replied to jumbletons's topic in Waste & Sewerage
Exactly what we stated on our replacement dwelling, BCO not particularly bothered, only that it was required distance from property. If I was staying in the bungalow and swapping out the septic tank, I'd just crack on and do it. -
oh, ok, that'd make life a bit easier. Ta.
Hi All, My plan is to install pre hung doors after plaster and mist coat. I'm just starting to put the odd sheet or two of plasterboard on walls. Would putting in temporary door linings be a reasonable idea? It's a small'ish cost (£20 ea or so from the BM) that I can deal with (11 doorways) to help with plasterboarding and then for the skim coat round doorways?
If you already have the PIR on site, then as you say, it’s the condensation risk that’s the key. However…. If you come to sell the PIR you may turn a good profit on FB marketplace, I did when I over ordered and sold off a couple of sheets individually, Joe Public don’t use merchants and are very used to wickes/B&Q pricing I found.
I’m another that wouldn’t put batteries inside a dwelling, likewise an electric car in a garage attached to a dwelling. The fear of batteries combusting have got to me I’m afraid. For what it’s worth, my plant room is a cupboard… 1.2m * 1.5m. Just houses a cylinder, plumbing distribution manifolds and controllers for poo tank, Ashp and solar on a wall, it’s a compromise on size, but works. MVHR is in the loft as that was the best location logistically for routing the pipe work to where it needed to be, with the supply and extract at each corner of a gable. UFH manifolds are under stairs in a pretty central location.
I don’t have the words to ease the wallet pain, however you’ve now got a really good excuse for the house not finished thread…. Someone else will need to bring the biscuits and cakes for now though.
if your soil pipes run perpendicular to the joists work out the maximum length of soil pipe into your equation as you’ll need to account for fall.
Cat6a cable everywhere, um, now what?
crispy_wafer replied to Tom's topic in Networks, AV, Security & Automation
Both, probably! your router will only have a small number of switchports. To put it as simply as possible, at one end of the cat6 you’ll have your endpoints (tv, Xbox, etc etc) at the other end in your comms cabinet you’d commonly have a patch panel, from this panel you’ll use patch leads into a multiport switch, you’d connect the switch to your 4g/5g router. It’s possible to do without the patch panel and crimp rj45 plugs and connect these straight to the switch, but it’s not something that I’d do… -
Flexi connector pipes or not
crispy_wafer replied to mk1_man's topic in Air Source Heat Pumps (ASHP)
Was of the understanding the flexi hoses are for vibration damping, and the softening transmission of the fan noise through the rigid copper. I could be completely wrong though. 🤔 -
origin do some Ally ones. Must admit I do like the look of metal frame doors without timber door casings and architraves.
would it be some kind of flow regulator?
I've got the SO4CG, it's a reasonable bit of kit for the money. Aftersales/service sorted me out a warranty replacement when I dropped it and it went out of whack...
torx wafer screws for fibre cement cladding - Google Search anything of any use on there? haha - beaten to it
You've got a really difficult job to appraise without eyeballing it. Get a quote for the fitter to sort, then decide if it's worth the fretting. With my rental, though tbh I'm completely hands off in terms of management, my usual response is 'How much!!!' followed by another 10 minutes later of 'proceed'. Keeps the tax bill down is the only saving grace...
Hired a nifty 120 t'other weekend to take down some Ash trees adjacent to a road, Cost from my local farm shop/hire place £120 for a single day (Saturday).
Recommendation - private treatment plant
crispy_wafer replied to Lincolnshire Ian's topic in Waste & Sewerage
+1 on the rewatec solido smart, as once the initial capital is dealt with has lower running costs, which was more important to me. But there's loads of different ones to suit. Shallow dig/deep dig, submarine shaped, conical shaped. Installers probably have their goto brands. -
yep you are right, i guess I should have mentioned at DPC in my post
Speak to your building inspector, I was under the impression they are not always required.
Design load question for my build
crispy_wafer replied to Post and beam's topic in Electrics - Other
I'd ask for 3.ph then list out heat pump, air con, 3 ovens, hob and car chargers... Then get octopus or your choice of electricity supplier to give you a 3ph meter. You can still choose to use a single phase if that's how it pans out.
