Dave Jones
Everything posted by Dave Jones
what is the cost of aerogel and where buy it out of interest ?
- 11 replies
- i beam
- insulation
(and 3 more)
how much more expensive than traditional brick/block is ICF ? 2, 3 4 x more ? A site has come up locally which we may buy to help kids build a starter home. Render isn't an option due to planning so will have to be brick/slip external skin but all other options are on the table. Rules out timber frame as too expensive, if ICF comes in cheaper than brick and block would take a look. I guess the immediate savings are insulation, lintels and time ?
drop some steel in the trench where the stump was to give it a bit of help.
with the government pushing hard to decarbonise house building, sorting the concrete would be a massive step. https://www.popularmechanics.com/science/green-tech/a40785162/microalgae-carbon-neutral-cement/
New build design - thoughts welcome!
Dave Jones replied to AppleDown's topic in New House & Self Build Design
unimaginative design for such a nice plot. -
Replicating window cills in-situ
Dave Jones replied to jayc89's topic in Bricklaying, Blockwork & Mortar
photos please. -
Concrete screw length for installing Upvc windows.
Dave Jones replied to Discoeye's topic in Windows & Glazing
yes, shoddy practice fixing them outside the thermal insulation. Now they have to do it properly there isn't any brick left to drill into by butchering the frame. Max 30mm. -
ashp ASHP - how much ???!!???
Dave Jones replied to Robert Clark's topic in Air Source Heat Pumps (ASHP)
heat pump £4k, say £4k for rads. City Plumbing Plumber is 250/300 a day so would need to be onsite for months or else they are royally ripping you off. -
Unauthorised deviation from extension plans
Dave Jones replied to Jimbo123's topic in House Extensions & Conservatories
They haven't followed the drawing end of conversation. What happens if/when planning enforcement come a knockin ? When it comes time to sell and you are asked to legally state you have complied with the planning permission etc ? Depends if the footings they poured are wide enough to rebuild on. Much drama if they are not. If they cant follow a plan I'd wager they will probably walk away at that point. Take a tape measure and go measure the 2 diagonals to make sure what they have done is square. -
you may want to add stools at either end to take the brickwork and an upstand to take a stub cill, like this -
dont butcher the frames use straps, can plug and screw then. -
we call that a cranked roof. Very common in plymouth! It's allways the first area black mould comes a visiting. 25/50mm celotex on the crank ill help a lot, its tricky sliding it behind the tiles but worth the effort.
you have a scumbag neighbor. Stop all appeasement it wont work as you have found out and just crack on.
Fan Coil Units for use with a (cooling) ASHP
Dave Jones replied to ProDave's topic in Air Source Heat Pumps (ASHP)
for sure. need to get one and see if the valve can be tinkered with... -
yes clear the site of everything you legally can.
Is Devon bonkers or just drier than the rest of the UK?
Dave Jones replied to Adsibob's topic in England
perhaps soakaways should be banned allowing more water to be sent down the drains to be stored, alleviating the hosepipe bans! -
Global warming is in fact entirely natural and has already peaked
Dave Jones replied to ProDave's topic in Boffin's Corner
problem with the whole subject, the peddlers of climate change are also the wokerati. So if it grunts and squeals its likely a pig. One things for sure, jack $hit we can do about it with china operating more coal fired power stations than we have McDonalds.
