Wil
Everything posted by Wil
We should have installed air conditioning… now what?
Wil replied to Adsibob's topic in Other Heating Systems
If that’s the mixing valve, then sending it cold water when it’s expecting hot just means it will fully open and not mix any of the return from the UFH manifold. This is fine as the higher temp return water will just go back to your ASHP/ chiller. If it’s the lowest temp setting to get the manifold circulation pump to engage, that would be strange and definitely a problem for this idea. If you have room stats, you may need to set them excessively high in order to get those zones to open if the temperature in the zone you’re trying to cool is already high. -
I had a Solic, then got my Tesla batteries. Couldn’t get them to play nicely together, so took the Solic out of circuit and now use a ‘smart relay’ to close the contact on the immersion when the batteries are nearly full and the sun is shining. This mean batteries take solar priority and then once nearly full, the immersion takes full whack until the solar input drops (say below threshold of the house). The Batteries allow for sun dropping behind a cloud and also allow the immersion to take full 3kW even if solar only producing 1kW. Then set a low limit on the batteries when it drops the immersion again. It’s a bit of a bodge and would be far better to get the Solic to ‘see’ the battery- something like Christiano has done but I couldn’t work it out!!
Yep, that’s generally how I’ve done it. Although tbf I’ve only done the rooms I’ve refurbed so far. A centralised switching position would be a far stronger call if you’re starting from scratch. Especially with the newer Ethernet devices.
Or you can put the Shelly up in the ceiling void behind the fitting if there’s not enough room in the back box…
Advice on heat pump for under floor heating only
Wil replied to Ceridunn's topic in Introduce Yourself
Mine’s a Cool Energy unit with some lovely labelled terminals in the outdoor unit. I just googled Samsung 8kW R32 Monobloc and got this manual from Midsummer: https://midsummerwholesale.co.uk/pdfs/samsung-ae050rxydeg-eu-manual.pdf No idea if it’s the same as yours but it seems to imply a low flow error is on the controller. Do you have a central heating pump at all? Or are you expecting the pump in the monobloc to do all of the flow in the house? Turning the heating pump on to ‘pull’ a bit of water through in line with the heat pump water pump would also help get the flow going. I can’t see any obvious terminals to short but the control section of the manual tells you how to interrogate the display to see what the pump is up to. If you’re not confident stepping through the manual, might be time for a heating engineer Callout. Good luck! -
Does that apply to all DNOs? Do the Wild Western Thieves come under this as our T/X is well under powered? (Western Power)
Diversity. Don’t add up all your loads and assume the worst case is all on at the same time- apply diversity to each load. And then an overall diversity factor of 0.7 to the total to allow for you over-egging the first set of diversity 🙂
On my HP I had to short the flow sensor for initial commissioning to get it running and bubbles out of the system. Since then and removing the short, it’s been fine. Or post the make and model and someone will fairly quickly tell you if it has a pump… -
@OmnibuswomanThe panels look a little expensive at £176 pretax and £500 for ancillaries seems a bit steep depending on how far from the panels the inverter will be. Check the items on ITS website for direct costs). The only thing with in-roof GSE system is that only certain panels will fit- the bigger 400W+ panels are 1900 tall compared to 1700 tall which knocks the idea of having fewer panels for greater output. Not sure if there are many panels >365W that fit, or are at a decent £/W rate, but happy to be corrected.
I’ve got an EZ-VIZ DB1. It works natively with the Hikvision CCTV system I have. Has been pretty decent even if I did have to extend the wifi down the drive to cope with it. Subscription available but has a SD Card and records direct to the NVR I already had for local control and no subscriptions.
Thanks, Cool Energy sent me an anode with my stainless steel tank so I installed it.. might just be wasting my electricity but it has a little control box which indicates as and when it wears out. Sorry for thread hijack.
Our of interest, what’s the issue with sacrificial anodes as I have one in my UVC?
Watch out for stone walls too.. I have loads of APs thanks to lack of signal between rooms. 128MB won’t last 2 mins with constant recording and most ‘motion detection’ misses critical events IMHO. has the UDR got a USB port for an external hard drive?
No way of telling with a Solic without monitoring the energy consumption. I use a combination of Shelly stuff for this. ‘When solar production is >500W and export is >100W wait 10seconds, check again, then change over to secondary load if still true.’
Fan Coil Units for use with a (cooling) ASHP
Wil replied to ProDave's topic in Air Source Heat Pumps (ASHP)
I have one of the Cool Energy Reverso units. Since curing the fan imbalance issue which was driving me nuts, it’s been great. However it has no valve on it, so when the heating pump is running, hot water flows through it and it acts as a basic radiator at all times. As the room it’s in will never get too hot, this isn’t an issue, but some sort of electronic valve would probably have made more sense. A simple electronic actuator and a TRV body would sort it out for less than 70! -
Large workshop, very cold, mulling over what might work
Wil replied to Roger440's topic in General Alternative Energy Issues
We have a commercial tin roof we did as your mate said and just laid fibre insulation over then another layer of tin over the whole lot. Would increase the roof height by 300mm or so though. Lucky you having a non-asbestos one. I have a similar looking (slightly smaller) shed covered in asbestos 😞 -
There’s a whole section of electrical building design dedicated to this. Based on the rolling sphere method usually but can be directly assessed for more vulnerable buildings. Always interesting designing LPS schemes for ammo dumps. Or AA missile batteries on tall buildings in South Korea. It’s a whole section of risks multiplied together to give a final risk factor. If you live on top of a hill with no surrounding trees or buildings, you may be at a slightly elevated risk level. But it’s usually designed for prevention of loss of life rather than property as any direct strike is going to melt whatever conduction measures you have and probably make a big hole in the roof anyway. Check your insurance doesn’t omit it as an ‘act of god’ but I don’t think I’ve ever seen an LPS for a private resi scheme.
Is that an asbestos roof? Careful if you’re messing with it! -
Another one for a Solic, has been excellent and paid for itself in a year. Although I’ve now disconnected it as it was fighting and draining my batteries. And the batteries allow me to use the immersion at full whack for an hour and let the solar ‘make it up’ over the course of the day. When I add some more PV on another phase I’ll definitely put it back in so I don’t need to bother discharging the batts.
I need to make alterations to a similar one- I’ll have your metal roofing if it’s in good nick. Once you work out how to take it down yourself (suggestions above infinitely sensible), let me know, it’s on my to-do list!!
Sorry, missed this Hugh. Even if they didn’t take the PCB the engineers will only replace the compressors and PCBs together as they’re ‘matched at the factory’. Seems like a good way of wringing more cash out of a corporate customer… ^ Just to be clear, the units/ compressors that failed had nothing to do with CE and are related to my day job…
It was away for 2- 3 weeks with what turned out to be a loose connector causing arcing and the overcurrent on the compressor (?). I had looked at the compressor connections and couldn’t see this, but to be fair I hadn’t pulled it apart for fear of voiding warranties. It’s a shame that it couldn’t have been diagnosed on site as it would have saved everyone time and hassle, but it was picked up, fixed and returned to me so no complaints there. I think this is the issue for them that they’re selling like hotcakes (and seems like a genuinely good product) but don’t have the staff coverage to get out and support self installers. I suspect if I’d had it installed for me I’d have been referred to my installer at the outset. I don’t know how many official installers they have but I did ask if one was available before sending the HP back to Grimsby. It’s back in and running happily since. I guess when the temperature drops and it actually gets some real use we’ll see how it goes. Overall still positive about the units and their addition to my home.
I use the Solic 200 (or did until I got the power walls). I just put a couple of Shelly 1 Relays on the various immersions and just switch them in or out depending on which part of the tank/ tanks needed heating. You’d need a dedicated circuit to feed your storage heaters, then you could choose to fill them all one at a time or all together (the dumb resistance heaters just share the supply from the Solic). Means you only need the one Solic and it throttles it’s supply to 3.6kW max apparently. Now it’s simpler to bypass the Solic and just do 1 hour hits on the Immersion using a Shelly 1PM to act as remote switch. If the solar isn’t quite enough the batteries make up the shortfall and the solar can take it’s time to fill the batts instead. When I get some more solar I might swap the Solic and immersions onto another phase but at the moment it just steals from the batteries.
“He who has a herd of cows to produce the biogas, usually has a field on which to spread the remains” - Ancient bloke proverb by me.
This over and over again. Go on, ask me how I know… Or more how my ex-landlord knows…
