Wil
Everything posted by Wil
From the Salus website: first bullet point would appear to be a problem for you. A WORLD FIRST IN UNDERFLOOR HEATING TEMPERATURE CIRCUIT BALANCING & ENERGY SAVING Each Actuator has two temperature sensors which are clipped onto the flow & return pipes (one on each) of the circuit to be controlled. The Auto Balancing Actuator will measure the temperature sensors and adjust the valve position to maintain a constant 7°C temperature differential between the emitter flow and return pipes. Not compatible with Heatmiser thermostats Very Low Power, less than 0.5W Fast actuator opening and closing times typically 30 seconds....
- 57 replies
- underfloor heating
- ufh
And how long for on average? a 1500W computer UPS should hold 320W for half an hour or so? Is the sewage treatment the only critical item you'd like to keep on? If you went down the critical route you could split some other supplies like fridge/freezer or possibly just put a 5*kVA genset in to cover all house loads (obviously it would need to be sized for actual load). I think most people find it's rarely worth it for the genset, but depends on how often you have the issue.
Given the size of the property, what's the size of the heat pump? a 20kW heat pump will be using 5kW of electricity on full steam and if you run it with all the doors open (as per pics), it could easily be doing that. A HP is more efficient than chucking direct electric at the problem, but not if just left on. I'm tracking my consumption and our 5 bed farmhouse is currently averaging around 30kWh a day without any heating on! But we do charge an electric vehicle most nights which accounts for a decent chunk of that. Immersion for water and electric cooking account for most of the rest. The instantaneous and daily readings (particularly when it peaks and troughs) would be really helpful to understand where you're using the energy. Edit- sorry I meant to ask- does the business/ retreat form a separate meter from the house or is it all one property?
Yes, my apologies, got carried away when I saw the price and total thread hijack. Thanks for the answer though, I'll have to look into whether there's some sort of controller that could bring these in and out depending on demand.
Is there any reason for me not to buy two of these instead of a 22kW GSHP and run them in parallel in a high heat requirement situation?
Thanks PeterStarck, I think I read your postings on it. Yours was newbuild and designed with Icynene in mind though right? I'm concerned about the application to an old existing building. It certainly sounds like a great option, even if only used as posh cold roof insulation to ensure all the air leakage is stopped there. So many different things to think about, but for now, it's going and getting the keys tomorrow that'll keep me up tonight..
Thanks Peter, I have 3phase available, so not limited to single except on the complications of using solar to offset it. Will probably end up with 3 single phase solar arrays though so again can offset daytime heat pump use to a degree. 14kW doesn't sound like it'd cover my peak losses though? I was looking GSHP over ASHP only due to capacity/ efficiency for the size I'd need. I do have a friendly MCS certified installer and digging holes to put pipe in shouldn't be too much of an issue. HP = Heat Pump Cylinder right? Where does this differ from a UVC cylinder? (will google shortly). Out of interest, why 400lt? Is that to give cover for the recovery time using a ASHP? There's a large airing cupboard in the bathroom so a DHW tank in the middle of the house isn't an issue. Appreciate this is a heating conversation but is Icynene a reasonable idea for insulating and sealing up a leaky old building? Looking for breathable and minimum impact on depth, but afraid of a sticky mess requiring a new roof!
thanks Miek, I have calls in with Kensa and ThermalEarth to discuss GSHP options, so will see what they have to say. I did wonder if my lack of air tightness would preclude a ASHP option, or I may need two in series. Good point on the replenishment of the water needed. There is a pond at the property too but I'm not sure it's big enough and I haven't seen what it looks like in summer to see if there's any water in it all year round. I suppose there's no reason to completely scrap the oil burner and this could be used as 'top up' on any lower temp heat sources. But it can't have long left in it being at least 15 years old.
Ain't that the truth ?ton of energy indeed, hence the desire to combine sources. Yes, you're right in trying to get the ceiling airtight. The cold roof is indeed cold and when I stuck my head up there in February, the howling gale almost took it off. It does have impermeable felt under the roof tiles, but appears to have some fairly major daylight gaps which may need dealing with swiftly. Particularly as I'd like to put the heating manifolds up there and any other plant in place of the large pair of cold water/ expansion tanks currently occupying it. The worst offenders are likely the light fittings and pipe penetrations between the 'warm' house and cold loft. Peter- Slaving the UVC off a thermal store sounds interesting- effectively the ASHP feeds both and when the UVC is satisfied it runs into the TS? In the summer, just run the ASHP into the cooling manifold for the fan convectors? As mentioned I'd have plenty of room to divert solar into immersion heaters for either TS or UVC. Possibly some solar HW to pre-heat the TS or do the UVC in summer? Or is that just overcomplicating things? It feels like Solar HW would always have somewhere to put the heat! One other point- the current owner mentioned an abandoned well outside the backdoor which her late husband had been considering for some sort of water-water heat pump, but had never gotten around to. Is this so niche it's unlikely to be an option? Thanks
Internal features are coving details and multiple wall angles/ returns that would mean internal studwork frames being very complicated and eating a lot of the space. Also means every skirting board, picture rail and socket/ switch need redone. Given it's a farmhouse- in the summer it's likely to live with the back door open most of the time, so mainly winter heat losses to deal with.
Thanks all for the replies so far. I have a reasonable line in CAPEX available for the right solution (this one is going to be a forever home- no really- that's not what I said about the current house, but this one is). So realistically OPEX more of a consideration within reason. GSHPs look good for the RHI to cover install costs. We will have our existing place available til it sells, but realistically will be moving over fairly soon, so piecemeal improvements rather than a complete refurb. The rooms I'd consider UFH are currently unheated and have much lower floors for some reason already, so there's easily 100-150mm of space for insulation and UFH by just going directly onto the existing floor coverings. You're right about the heat loss being high though. I'd certainly look to deal with some of the leakage via chimneys where we're not using them for woodburners. no issue with blocking them up as needed, but it feels unlikely the whole place will reach decent air tightness without major work. DHW through a UVC is a good call (except I'll need a person with quals to install it) I wonder if a thermal store for collecting various heating systems and a separate UVC for DHW is overkill? I could go down the pellet boiler route, but for the horror stories around blocked augers etc. I'd rather go a gasification boiler with some of the wood we have available on site? Then again, I'd prefer to use some sort of heat pump covered by PV/ economy tariffs to have a system that didn't need feeding and meets the WAF. Could I 'stack' ASHPs or have an upstairs/ downstairs arrangement?
Hi all, I've been lurking for a while as our potential dream of a move to a smallholding has done the hokey-cokey with banks, kids and CV19 all throwing various spanners in the works, but it looks like we're really on this time and should be collecting the keys soon. The farmhouse is a beautiful stone building, but has an EPC energy rating somewhere off the bottom of the chart. It may have got a point for effort. EWI would ruin the setting, IWI would ruin the features. It has secondary glazing throughout but plenty of chimneys etc so air tightness is probably fairly poor. I've had a stab at Jeremy's heat loss calculator but it all seems to depend on the MVHR and air changes which I don't yet know. I set air changes to 1 and MVHR to 100% efficient (there isn't one- yet) and came out with a heat loss of 16.5kW. (2 ACH and 0% efficient gives 27kW total heat loss. It's ~310m2, heated by an ancient oil burner with radiators throughout. The EPC says space heating of 52,430kWh (!) with 2109kWh to be reduced by loft insulation and a 22kWh reduction for solid wall insulation (unlikely to be able to achieve), Water heating 3240kWh. There are some currently unheated rooms and the potential for woodburners for room point heating. My intent would be to do all of the loft insulation possible, then install UFH in the unheated rooms and manifolds to fan convectors throughout to replace the radiators. But how to get heat into the house and do hot water? I was originally convinced that a GSHP (there's room) with some solar HW and solar PV (there's a lot of roof space for solar of any type in a good SSW orientation) all feeding into a large thermal store or two. But having read all of the posts here on 'don't do GSHP just go ASHP' and 'get a sunamp' not a thermal store, it's all gotten a bit confusing. There's a decent sized single garage that would do as a plantroom although technically outside the thermal line of the house. 3phase electricity is available, but not sure of capacity yet. For DHW, there's currently a bathroom (small immersion-heated, open vented HW tank) and en-suite (hateful electric shower)and we'd probably add another en-suite at some stage. We're a family of 4 but relatively regularly have a full house stuffed with people, so I'd definitely want capacity and response time on the DHW side. Showers are usually in the morning pre-work/ school before the sun's up. So, over to you- what on earth do I do to keep the kiddies warm (except move them into one of the chicken sheds)... Many thanks in advance... W
Hi, We have a 222F in our current leaky Georgian house (35kW version). It's been excellent for the last 9 years. Occasionally needs the expansion tank re-pressurised and had a couple of PRV faults, but these are likely to be to do with the ancient plumbing it was connected to. They're obviously massive, but has kept us warm and wet successfully. We do only have the one shower and bath so not sure how it would cope with a second bathroom connected. W
