Everything posted by PeterW
Looks impressive ! No mention of a BBA or certification though that I can see ..? Would be very interested to see it in practice.
House Cooling ideas
PeterW replied to mike2016's topic in Energy Efficient & Sustainable Design Concepts
Just had about 20 minutes or near biblical rain ..!! It’s now like the tropics and 95% humidity ..... -
A timber framed garage clad and insulated will be just as cheap as an office with a triple bifold door though that’s a fifth of the size. If it’s scales on price then you’re in for £18k at my reckoning - that gets a very nicely built “double garage” that could be internally converted to office space and potentially give you both garage and office. And it’s pointless going with a lawful development certificate as you will be wasting money as that is clearly removing your PD.
In search of a bathroom wall unit...
PeterW replied to Ferdinand's topic in Bathrooms, Ensuites & Wetrooms
It’s because it’s made of HDF or water resistant chipboard. This stuff is 3 or 4 times the price of ordinary MDF and the edges are usually acrylic sealed. You may find ordinary cabinets will blow quite quickly if they are in a warm and humid environment like a bathroom. First picture is a piece of moisture resistant chipboard from a bathroom cabinet, second is from a kitchen cabinet. You can see the difference in the gaps between the chips and also the density of the material. -
I wouldn’t even bother - the double sided has got it anyway and the lap is more than enough. Make sure you pour the concrete on the upper piece first and it will hold the lap down
That looks to have removed your permitted development rights. 8mx6m is building control territory and you would need to show it was moveable to class as a caravan anyway. If you have permission for a garage of this size why not go back for a variation on this ..?? Or basically build a double garage with fake doors ..?? Barn doors with windows behind would make it more secure anyway.
Good point by @Russell griffiths - not sure what the minimum bearing is though on a posi under tension on the top chord.
Help with kitchen renovation/ 1st house.
PeterW replied to zoothorn's topic in Bathrooms, Ensuites & Wetrooms
Extension boxes or longer screws will sort those. -
Is the timber straight to start with..?? Turn it 4 sides and see if the gap changes -
How old is the house and how much is a “big gap”..?? TBH I wouldn’t level out with what you are doing - battens back to the wall, insulation in the gaps then board on. You won’t see the bottom anyway. -
I hate leaves and open gullies so this is the solution I’ve used previously - it’s a standard closed gully top that has a basket within to catch the bigger rubbish as it drops down (also hedgehogs in the gutters) but there is a socket cut to size in the top plate and then the down pipe fits into this. It means the downpipe is supported at its base and there is no open gully
You can get nail guns for fitting metalwork that fire twist nails but they are eye watering to buy and hire. Decent hammer, nail pouch and fit the metalwork from the bottom upwards ..... when you’ve got a bracket in your hand you’ll realise what that means !!
So you don’t think scrum masters are managers then..??
Thats a very broad - and probably incorrect - statement ..! A lot of self builders want to pursue building what they want in a time period that meets cash flow and delivers the value they want. If you think bells and whistles is the sole domain of the self builder, you’ve not been in many show homes recently for the volume house builders. Have a read through the blogs and posts of the likes of @ProDave @Crofter @Cpd @PeterStarck and others - these are classic examples of self builders who have delivered value for themselves and they are far from high tech bells and whistles builds. They are what many would love to aspire to - beautifully delivered houses that meet their requirements.
@Cpd that’s a really tidy job !
- 35 replies
- standing seam roof
- corrugated roof
(and 3 more)
Beamcalculation.co.uk But £200 isn’t a lot tbh
Face fix rely only on the strength of the nails. Top fix are quite slim anyway and you won’t notice the flanges under the edge of Egger board anyway. They are much stronger imho
Please can whomever decides to try agile with a build invite me to their first sprint kick off ... I’ll even pay my own travel as to watch a brickie and a labourer with a set of sprint cards is going to be worth every penny ..!! ?
Never seen one made with treated ..! So if it’s an option I’m not sure unless they ones I’ve had have been done with something clear ..
Take the units out and refit. Quicker and simpler and better finish. -
Fixing POSIs to a wall plate (rim joist)
PeterW replied to ToughButterCup's topic in Floor Structures
You can add strong backs if you want - pretty easy to do. -
depends on the value of the plot to start with ! Founds value is pretty much the value of what goes in the ground tbh from experience. Its only when you get superstructure up you seem to get value add
Foul sewer, Anglian water shrugs its shoulders
PeterW replied to Dreadnaught's topic in Waste & Sewerage
Just connect to it. It will be a private sewer and Anglian won't care anyway until there is an issue. Not the first time I've heard of them not wanting to know about connections either !! -
ASHP 101, how does a reversible heat pump work?
PeterW replied to Dreadnaught's topic in Air Source Heat Pumps (ASHP)
This is of use too https://www.egshpa.com/ground-loop-sizing/ -
Just found a use for that spare UFH pipe ? How much do you think it would need @JSHarris in terms of a loop ..??
