Everything posted by Onoff
What we've done: Me - bespoke galv track with a nom 20mm dia top profile. From here: http://www.barrier-components.co.uk/gate-hardware/sliding-gate-hardware/sliding-gate-rails.html Good site for other stuff too and handy for me to collect! Fixed with Fischer st/st hammer in anchors. My mate's - I got a length of 20mm galv round bar. Made a jig and drilled and tapped M8 or M10 (can't remember) holes thru about every foot or so. Screwed in short lengths of st/st studs with nuts on the end and set this in a concrete strip. BiL - I got a length of 20mm galv round bar. He welded on 1"x1/4" flat bars about 6" long and screwed to his concrete strip.
Purely out of interest but my BiL made his sliding gate out of old wrought iron railings welded together, attaching a pair of off the shelf rollers (runs on 20mm round bar) and an off the shelf rack for the pinion drive. Same rollers and rack as in my pics. EDIT: Actually he went for the plastic rack whereas I went for the steel one.
Discount Offers of the Week
Onoff replied to Ferdinand's topic in General Self Build & DIY Discussion
Some of those Lidl screwdriver sets seem to be made from really good steel and you can pick up a bargain though I think prices are creeping up. The odd thing is cr@p mind. -
I thought that but you can get a bare Makita for like £60. Not worth the grief of another incompatible battery type imo. -
Have a look at my photostream of my (can you believe still unfinished) sliding gate: https://flic.kr/s/aHsjYQgVgE My mate John's sliding gate, we actually used my parts for his and then when his kit came thru he gave me the parts used. I got the idea for his curved enclosure from the Burj Al Arab hotel in Dubai. I supplied the Unistrut, steel sections, made the shafts and rollers and gave him the leccy enclosure and glands etc and advised on the layout etc. He did the welding and most of the wiring: http://s1071.photobucket.com/user/johnnaughton/library/Sliding Gates All three sliding gate kits from Easygates. http://easygates.co.uk/liftmaster-sly-electric-gate-opener.asp All 3 of us have the 500kg 230V kit. Been in and working for years (except mine) They do a 24V version. Google "12v diy sliding gate" EDIT: That reminds me I still haven't made him his Knightrider LEDs to inset in the block paved drive! Keep hoping my boy will do it with a PICAXE chip. I bought it ages ago. Like father like...
£37 all in for a 180Nm 20V impact driver with 3yr g'tee makes you think. Why 20V though? Think they had some 16V stuff a while back too. Not that it matters as one brand doesn't fit another. Only Parkside tool I have is the corded multitool and tbh I can't fault it. -
All the linked fridges are too small! I envisage a 5L keg as the centrepiece (says drink within 4 days) surrounded by other bottles and cans. As for why a glass front I just like the idea of coming home to see that as I walk in the door. (Years ago it was SWMBO! Favouring @Construction Channel's idea of "foam". 4 Starrett cut holes in the door to get nice round corners then join them up with the nibbler. File the edges and paint. Inlay a DG panel and weight it down from behind. Then foam the gap. Will have to look at the door construction. I know as soon as I start she's going to say "It's too good to cut up!" Tbh it really is. Btw I've just discovered "Trooper" developed by Bruce Dickinson of Iron Maiden.
A kitchen had a previous fireplace with alcoves either side. To square the room off they had gone straight across the front of the chimney stack with thick chipboard and not a stud in sight. Access behind was a bitch. It was a 2G socket with a couple of 20A DP switches on a one gang. I couldn't use a 2+1 box as the Volex accessories had bigger faceplates than usual. Screwed to the rear of the chip via folded lids.
- 25 replies
- swtich hole
- electric
(and 2 more)
DG unit is no problem. Would it be insulated enough compared to the original fridge door? It's the "frame" I'd need to inset the unit into the door I'm struggling to figure how. Ian Malcolm: Your scientists were so preoccupied with whether they could, they didn't stop to think if they should.
I rest my case!
- 25 replies
- swtich hole
- electric
(and 2 more)
Ballsaching task having to find them afterwards imo. If you're really unlucky some animal will find them with the ball end of a hammer and roughly hack out the rectangle. Needs care taken or you'll finish up with an oversize hole and will have to hope the faceplate covers it or use finger plates. If the plasterboard is set too far forward you might need box extnders like these: https://www.ukelectricalsupplies.com/search.htm?search=Metal+extension+box
- 25 replies
- swtich hole
- electric
(and 2 more)
What make of fittings did you go with in the end?
- 25 replies
- swtich hole
- electric
(and 2 more)
Probably being silly again but... In Sainsburys and was tempted by a 5L keg (a toss up between Hobgoblin and Old Speckled Hen). Reality hit and I realised that I'd want it constantly cold so it'd need to live in the fridge. There's no way madam would entertain this as it would take up so much space. Now I've recently been given a Bosch integrated fridge. I remember in the old days you could get window kits for the side of your van. Can you get say a DG window that could be set into a 'normal" fridge door.
So what gets poured on site? Assumed they came pre poured and you lay them like normal blocks with mortar between? And then why do you need shuttering? Alles ist nicht klar!
Ahem! There's always one idiotic question... What got poured? I'm seeing what looks like stacked up concrete blocks ready to be laid with foam insulation inside them... I'm fundamentally not understanding this though it looks really good.
Yep it works and in fairly frequent use if you don't mind a bath in a building site! It's alright but can't tell if the slightly erratic flow is down to the cheap Bristan tap set or what's feeding it. Mile long run with a 25gal tank (above the 1st floor ceiling) feeding the cold to the bath (ground floor) and providing the head to the hot water cylinder (above the ground floor ceiling). Capacity just isn't really there and runs out quickly and gets airlocked. Bath is so big for a start. Yeah I know, TS / UVC / oil combi... At least I managed to find some tiles that look like marine ply & plasterboard!
Any quicker it'd have to have been inflatable! I must admit ICF was one of those terms and techniques amongst the many on here I'd kept meaning to investigate. These pictures make it much easier. Is there additional insulation added inside/outside. I assume there's some sort of cold bridging consideration through the "block" bit of the insulated blocks?
Standard 2 hole tap centres. Screws onto standard 3/4" BSP tails: This is the original link where I got them from: http://m.ebay.co.uk/itm/222134448329?_mwBanner=1 Cassellie is the brand. BEF001 the part number. Cheaper here than what I paid: http://m.ebay.co.uk/itm/Quick-Release-Fast-Fit-Bath-Tap-Kit-Bath-Taps-Shower-Mixers-Filler-Pillar-Tap-/361976121452?hash=item544775486c%3Ag%3AAEMAAOSwPh5ZN-Ai&_trkparms=pageci%3A63ace5f0-53b9-11e7-9d6c-74dbd180469f%7Cparentrq%3Ab881d8c915c0aa4895c9ffd2fffd39cd%7Ciid%3A2
Absolute revelation about wet wipes from @Nickfromwales way back when. Used CT1 (him again ) in the garden the other day to fix the old stable gutter. Only had white, gutter is black. All cleaned off with Wilko ones I think.
The lorry curtains coming on: Made the edges pretty: Got to find some trim to keep the edges secure. Found a length of square gutter and figured it must be UV proof. A mission to cut using an old, cheapo (Champion brand?) 18V circular saw. Could have done with a finer toothed blade tbh. Will affix with st/st penny washers and screws. Not sure 30mm strips are wide enough?
i was sweating buckets and dithering over REDRILLING my bath holes. Because the taps are against the wall and forever more inaccessible without taking the bath out (which I have allowed for tbh) I found a "quick release" kit but it needs slightly larger than normal holes. My magic Starrett in a Starrett invention to the rescue: You can just see the Allen grub screw that locks the tap into the groove in the fixed boss: 18mm marine ply with lashings of Sikaflex and a st/st two hole plate I made from a door kick plate: I wanted this Vado set but was overruled:
See...if you'd have done a blog I'd have known that! Seriously though it looks great and huge. That patio set looks lost.
Erm...same architect next door?
Stinging nettles are fantastic to eat. Pick the tops (with gloves ), boil and serve with butter and pepper. You won't get a stung mouth honest! Bees will take pollen from weeds to so it's all beneficial wherever it comes from.
The trouble is that if you seal yourself off completely from the allergen you might actually make your reaction worse when exposed to it. Try the honey trick, and yes EAT it! Have a look here for London honey: http://www.lbka.org.uk I'm now wondering if I could make some mead with it!
