Everything posted by Onoff
Keep the bathroom around 10degC and this is not an issue.
Welcome. Think you might be our first American member?
Hmm...when I wanted to introduce a bleach shot tube it was shot down! ?
It's warming up via the rads but takes a while. Doesn't help some of the single pipe system runs, uninsulated, under the (again uninsulated), suspended floor which is vented to the outside via the air bricks. All cools down quick too.
Relax and find something to bite down on! ? Sitting here under a blanket in the (freezing) lounge, fantasizing about ripping up the suspended floor, screed rails and pumped concrete!
Erm...scrape with a sharp blade?
One bonus of WAGOs are they're maintenance free when compared to screw type terminals.
Not a bad "starter" kit as an intro into the world of WAGOs: https://www.screwfix.com/p/wago-basic-installer-box-75pcs/48808? 221s are similar but lower profile lever connectors. There's push fit types too. Watch a few videos to get a feel for them.
Hope it's not CCA, (copper clad aluminium). It's sh!t.
Just PVA any plastic conduit if you want to fill over it.
This is my socket box cutter, sure I paid a lot less but it was years ago. YouTube it for videos in use. https://www.screwfix.com/p/armeg-ebs-back-box-wall-chasing-installation-kit-7-pcs/67733? I'm about to lend that and the chaser(s) to a mate, will take pics before I do.
One of my chasers is that well known make "James Andrew's" and the other Einhell ? My back box cutter kit is Armeg
If you neatly cut all the boxes into the wall and chase between them then fit conduit then rewiring is easy. (Could even do in singles). Be careful on the depth of the boxes on the internal walls, you might be drifting into Part A if the walls are thin. Go EASY cutting the boxes! What are the walls made of? Brick, breeze, lightweight block etc? No need to to go up from a socket, into the loft, along and back down. Just come down to the first socket then go horizontal between sockets. Less cable required. A wall chaser is easy but can be VERY dusty without proper extraction kit. Google "NICEIC safe zone diagram" look for the diagram top right. Keep switches, sockets, in the "zones". Lots of info too on that sparkyfacts link.
Stage 1 Is Very Nearly Complete :)
Onoff replied to Construction Channel's topic in General Self Build & DIY Discussion
You try it! ? -
Do Screwfix still sell the No Nonsense stuff? I think not. You might get it cheap in B&Q on clearance: https://www.trade-point.co.uk/departments/no-nonsense-heating-inhibitor-500ml/53670_TP.prd#
From 5 Dec at Lidl: https://www.lidl.co.uk/en/p/happy-home/vonhause-3-blade-stove-fan/p27919
& the weight of course as we will be asked if we mention it to our other halves! -
Faye's looks thank God! ? -
Proving Faye does all the hard work! Congrats to you both! ? -
I see, just a little bent bar screwed to the ceiling. Is it?
These might help you understand: p4.pdf p5.pdf p6.pdf
You could replace the current fittings with some WAGO blocks. They'll lie nice and flat in your new fitting I suspect. Pic of the new fitting's base plate pls.
@PeterStarck, ref your question on the other thread. Fag packet sketch at the start here shows my musings to have a buffer tank (central to the house), fed from the oil boiler. Use that for any new UFH circuits to keep separate from the filthy old single pipe system here.
Is that a 2CV? You'd have got £25 ea for those rims even rusty.
