Everything posted by Onoff
Used one of these, a 500mm B&Q flexi. In the words of he who must be obeyed. "A bit more than hand tight is usually ample. Say 1/2 turn or so". It's easily accessible through the back of the (still unfinished ? ) cupboard:
I remember similar concerns! Thinking the "gap" between bath and wet room corner would be tight. Tbh I was more concerned you would feel off balance when crossing the very corner of the wet room corner where it's laid to falls. In reality you don't even notice it. With hindsight I'd have gone steeper on the falls. Having that OSB there and it looks like an immovable object as the wet room corner did for me. Once done you'll wonder what the fuss was about.
I chamfered the bath corner as well as sinking the bath. Also the sides rake inward. Works really well.
Temporary heat source for UFH: Willis heaters
Onoff commented on oranjeboom's blog entry in Kentish RenoExtension
Do we know it's that?- 159 comments
- willis heater
- ufh
Ref Method 101# in Table 4D5 applies assuming his insulation is thicker than 100mm. Then 4mm is rated at only 22A. Would need to up to a 6mm.- 159 comments
- willis heater
- ufh
You could run both off of one breaker at the cu then one "big" cable and split at the heaters. Or give each it's own breaker or rcbo and "small" cable. Personally I'd separate them for complete control. What length of cable run approx and how will it be installed? Clipped direct, under insulation etc.- 159 comments
- willis heater
- ufh
Depends on the club policy I guess!
Take a pic of the trannie up the pole if there is one.
Surprised my name didn't come up as in too poor to buy a Tesla! ?
460V centre tapped to earth. Phases are 180 rather than 120 deg apart. So centre tap is neutral. Like a big site tranny. The incomer is just a standard 3P one. Might make it a bit easier if you were into making phase converters for machinery! I'm working with HV boys tomorrow so will ask them over tea why this is done.
I keep my working area spotless...go figure.
Rural I bet. Not split phase is it? 460V between phases but still 230V L-N, L-E.
If you had OCD you'd get a f**king broom & Hoover out! ? Glad I didn't go white grout on the floor.
The Wolseley, black, solvent weld: 36mm OD - (1 1/4" ID) 43mm OD - (1 1/2" ID) 56mm OD - (2" ID)
I think the model S is much more a knicker dropper in terms of looks that the 3. The S to me says low slung coupe. The 3 is a bit more squat ans family compact looking. Only my opinion, don't get me wrong I'd happily have either! Maybe Tesla should think about slide in drive trains and power packs for other makes...
Tesla just need to make their cars look sexy now! ?
No offence taken, you know me! What do you mean? Everything was pretty well considered tbh and done for a reason. As @ProDave will attest to, "50mm" doesn't necessarily mean the same thing with all makes of fitting especially on eBay. Mixing solvent weld and compression can be a mare. The Geberit wall drain waste was some weird, nominally 50mm bit of mdpe then the black solvent weld a bit different size wise. The 50mm can be inside diameter or outside. Got all my waste from the local Plumb Centre: https://www.wolseley.co.uk I didn't move without @Nickfromwalessay so!
Bath waste here is 50mm solvent. I've an accessible flexi waste from the trap onto solvent waste: The bath waste is 50mm solvent weld in the slab. There's a T coming up and the basin goes into that in 32mm solvent via a reducer. Anti siphon trap on the basin so the bath emptying doesn't make ths basin trap gurgle. Shower / wall drain waste goes from the mdpe waste on the Geberit wall drain to 50mm solvent via a compression coupler. Deep shit if that ever leaks!
Brown is for underground really. I'd use black or grey solvent weld 110mm. I made a mistake fitting brown pipe into the grey solvent fitting in the pics above. Ended up using gap filling solvent cement at the join. What glued white plastic? All my waste from bath, basin, shower is black solvent weld. I'd go solvent weld boss onto the side of the 110mm for wastes.
There was a thing yesterday (The Independent I think) suggesting Tesla is driving the German economy towards recession. Such is the German economy reliant on it's big car producers. Buyers are shifting in such droves to Tesla it's having a knock on effect. Pretty much it's a case of upping their game or falling by the wayside in the face of a more in demand product.
Isn't the elbow in your pics the one that came with the frame? Certainly something similar has come with the 3 frames I've bought: All with the kit: In the end and I can't remember why, I went with a 90F/110M elbow @PeterStarck kindly gave me:
Maybe these if you need to extend the pipe without making the slab/beam hole too much bigger: Geberit 366.887.16.1 Hdpe Straight Connector £21.48 Tax included Geberit 366.887.16.1 HDPE Straight Connector 90mm - 90mm Ring seal socket Or Geberit 367.887.16.1 Hdpe Straight Connector £21.48 Tax included Geberit 367.887.16.1 HDPE Straight Connector 90mm - 110mm Ring seal socket As used with Geberit WC frames
Erm... that black elbow isn't glueable type pvc (I don't think). It's HDPE. The elbow goes into an adapter that comes with the Geberit then that push fits into a 110mm female. The 3 black fittings are all Geberit:
You can bring the elbow back / forward in a few configurations depending where you clip into the blue frame and whereabouts you clip around the fitting.
I hope you Hoover up all that debris underneath...
