Everything posted by Onoff
Driven by where it sat on the pedestal. Then sat it on a stool roughly the right height just to get a feel. Aim was to have the fixing bolts dead centre along the 6x2. It really is solider than a solid thing. There's a bit here about it too:
My sink screws to the bfo 6x2 screwed in horizontal: Then the sink fixings (bought seperate from S'fix) that have a bolt thread one end and a woodscrew the other end into that 6x2: If I hadn't have had a pedestal I'd have overboarded with 1/2" marine ply rather than 1/2" mrpb.
Not mine, I've been asked. Anyone changed the brushes on a Bosch GSR 18 VE 2-LI? Looks like there's 4 brushes from the pics. You can lift up the brush spring with a hooked paperclip but the brush doesn't slide out. (Much easier on a Makita!)
+1 on aerialsandtv. I went with a specific Band A Yagi here in the end. Vastly superior to the "WB", wideband tat you get from the DIY sheds. If you're in a weak or fringe area I'd go band specific everytime. Just check what your transmitter puts out. Mind I've made a few aerials along the way. My favourite is the corner reflector/ trough antenna. Still got 2 neighbours running on these that I made, one in sheet ali and one in galv mesh. Can integrate well on a gable end with just the top and bottom "wings" and dipole visible. Windage can be a problem. The ones I've done are horizontally polarized to suit the transmitter. I'm unfortunate being at the lowest elevation of all of us. My Yagi is on a pole about 100' from the house if not more.
SBS do a 2x12 (so 22-way) and it's only 279mm wide: PRICES 2019 - JULY.pdf
House naming..need inspiration
Onoff replied to SuperJohnG's topic in General Self Build & DIY Discussion
Dungeness Nuclear Power Station it is then! (Just one of the honeymoon highlights ?). -
Something based on an anagram of all your names? -
Thinking Nevahdun here. SWMBO vetoed Gőttwood... -
Try an app like this? Chuck in a few pertinent names relative to the location and see what comes up: https://www.name-generator.org.uk/house/ Maybe not it seems to ask for a bit too much info? -
Normally, with flat tiles, I'd say tile first then fit the profile as you'll only need to worry about a few points being sealed up i.e the screw holes. As for textured tiles... @Nickfromwales will be along shortly! ? How textured are we talking about? Guess if you do butt the tiles to the profile, with the profile in effect in a channel then it's a job for copious CT1 and baby wipes. Doubly important to tank the wall too methinks.
This is a good read ref @Barney12''s gutter detail:
You know it makes sense! ? At least you'll know where you are with one system, i.e all wireless.
I skimmed my mrpb wall and ceiling. @nod, what say you?
To muffle the screams.
? Used boxes of the metal ones over the years. Stuck in my head they were steel for some mad reason. Good shout on winding the "wrong" screw in first. Metal curly wurlies it is then! (Still smiling here that they're ali). I generally I must admit drill a hole first in the pb to minimise damage/bulging as they screw in. -
Ta both. I use the metal self drill ones a lot I should have perhaps said. Was only thinking plastic as it won't ever rust and streak down the wall. Sometimes think too you ideally need to use the screw that comes with them? Not overly keen that the mirror screws aren't stainless. This mirror needs to go on now simply to keep madam quiet but come off again later as I've a demister pad to go on the back. Thinking maybe these, if they don't work I can change to the metal curly wurlies. -
SWMBO wants me to fit a mirror for some reason! On this white wall central to the basin. It'll cover that 1G back box: Plastered wall, 1/2" moisture resistant plasterboard on 50mm battens and infilled with PIR. It'll be one of these screws: But what "plugs" to use? 8 gauge screws in each case which I think equates to just over a 4mm screw. I was thinking these but use the mirror screws above, instead. Says suits "4.5x35" screws. ? -
QUWS2W is a Quinetic IP67 2 gang switch which can control dimmer receivers.
It was 50mm Celotex I had issue with being too thick.
Ref my comment? Yep. Bfo pump lorry turned up. Thinking about it the lorry parked on another neighbours drive and my neighbour dumpered the mix to his place.
Found a place down here that'll do pumped for I think it was £90/CuM. Neighbour had it. No minimum either. Mad to even consider self mixing at that price.
Some Wickes 50mm I had was awful. +55mm at the edges. The 100mm bought at the same time was fine.
Don’t pay your trades up till they have finished
Onoff replied to nod's topic in Floor Tiles & Tiling
Can't remember what I paid for my tiles, £8 or was it £17/m2? Just remember they were expensive. ? -
I should add I was very careful to protect my finished floor with sheets of Correx temporary protection boards.
