Onoff
    206
Everything posted by Onoff
  1. Fits a treat. Printed with 0.3mm layers for speed: Also the Duratool multitool appears to run sweet off of the Makita Li-ion battery.
  2. The laser is the constant.
  3. I've a Surrey flange in the top of my tank...any good?
  4. Even you could do it! ?
  5. Shouldn't sweat it for a few mm. (A concrete poker would level it out pretty good). Cheap laser level is good for pegging out. https://www.amazon.co.uk/Tilswall-Self-Leveling-Horizontal-Vertical-Magnetic/dp/B08LN644WG/ref=sr_1_24?dchild=1&keywords=cotron+laser&qid=1614541501&sr=8-24 Soon be but a distant memory when you're sitting in there!
  6. I'm not as think as you drunk I am btw... Repeated the test this morning in the bathroom and it's nominally 1m before the basin tap gets even warm then 1m15s until hot. Up in the loft I have these pipes dropping down. Hot comes a fair distance from the cylinder in 22mm then drops to 15mm. To get quicker hot is it "just" a case of putting a T in then a pump back (to where?). Triggered by an occupancy switch? There'll still of course be a short dead leg from here the couple of metres down inside the wall to the basin / bath: Can anyone recommend a cheap pump? Edit: I do feel as I'm being somewhat cajoled into this...
  7. Just printing the test piece to insert in the Duratool base. Hollowed out to save on material / time. Designed in AutoCAD by me. Sliced in Cura by the lad. The .stl opened in Fusion by the lad to generate these pretty renders. I'll round the edges off and graft it to the Makita bit later on:
  8. When you're older and 4 stone heavier? I used to be able to crawl along the triangle formed by our front eaves to access the loft where all the cables go down into the cu along with various pipes that run down there. There's a fair chance now I'd get stuck and have a clutcher!
  9. A lovely zootesque word there! ?
  10. Saying that the joist depth as well maybe?
  11. Borehole in your case I imagine?
  12. Did you do it "officially", as in by deed poll etc? ("Tess Blythe just knew she and John Tickle would never wed").
  13. Compost pile coupled with some small scale hydro?
  14. GS38?
  15. Pity I don't have a battery to try it on! ?
  16. Would anyone have one of these 18V Duratool batteries? I'm after finding out the polarity, i.e which side is + and which is -. Cheers
  17. Duratool multitool, ripe for conversion to Makita power. The Makita battery actually slides part way in. If there was a bit more meat in the tool base I could have maybe modded that. As it stands I'll have to figure an adapter. Fire up the Vernier George!
  18. I don't always do it...and draw the line at noggins...
  19. I still pilot. I'm a bit weird though as I cut through housings in the sole plate and header and slot the studs into that...then add glue and screw.
  20. Depends on what I'm fixing. I always pilot drill in whatever. I don't always countersink. I might not countersink in softwood if using say Goldscrews but always will in ply, hardwood, melamine.
  21. I've re-read this thread and you appear to have had one electrician and THREE plumbers on the job but the plumbing pictures show it looking unfinished? What are you doing to get through so many plumbers, you're not Zoot in disguise are you? ? (I still can't fathom "potable hot" btw).
  22. Can you dig under and swap it out? ? https://www.constructionspecifier.com/comparing-polystyrenes-looking-at-the-differences-between-eps-and-xps/3/
  23. Wait until a filter housing next to your crown jewels disintegrates at the same pressure. Then it sounds like a 6'5" bloke screaming for his Mum & praying nothing vital's been hit. Ask me how I know! ?
  24. Ref Salus, our very own @Jeremy Harriswas using (and rating highly) Salus gear if I remember correctly. He was no mug either.
