Everything posted by Onoff
Best spec for high pressure hot water to multiple outlets?
Onoff replied to sendu's topic in Boilers & Hot Water Tanks
The hot water is on timed. Basically this: I however added 2 2-port valves to zone upstairs and downstairs CH. -
Right, circumfrence measured around the insulation is nom 1500mm. Height from the floor to top of insulation nom 1055mm. Thinking then it's a 180L cylinder. -
I'll have to measure it and get back to you. -
Yes, it's the take off to the shower pump. -
Fits a treat. Printed with 0.3mm layers for speed: Also the Duratool multitool appears to run sweet off of the Makita Li-ion battery.
The laser is the constant.
I've a Surrey flange in the top of my tank...any good? -
Shouldn't sweat it for a few mm. (A concrete poker would level it out pretty good). Cheap laser level is good for pegging out. https://www.amazon.co.uk/Tilswall-Self-Leveling-Horizontal-Vertical-Magnetic/dp/B08LN644WG/ref=sr_1_24?dchild=1&keywords=cotron+laser&qid=1614541501&sr=8-24 Soon be but a distant memory when you're sitting in there!
I'm not as think as you drunk I am btw... Repeated the test this morning in the bathroom and it's nominally 1m before the basin tap gets even warm then 1m15s until hot. Up in the loft I have these pipes dropping down. Hot comes a fair distance from the cylinder in 22mm then drops to 15mm. To get quicker hot is it "just" a case of putting a T in then a pump back (to where?). Triggered by an occupancy switch? There'll still of course be a short dead leg from here the couple of metres down inside the wall to the basin / bath: Can anyone recommend a cheap pump? Edit: I do feel as I'm being somewhat cajoled into this... -
Just printing the test piece to insert in the Duratool base. Hollowed out to save on material / time. Designed in AutoCAD by me. Sliced in Cura by the lad. The .stl opened in Fusion by the lad to generate these pretty renders. I'll round the edges off and graft it to the Makita bit later on:
A lovely zootesque word there! ?
Saying that the joist depth as well maybe?
Borehole in your case I imagine?
Through Cavity Mailbox.....Recommendations?
Onoff replied to Rob99's topic in General Construction Issues
Did you do it "officially", as in by deed poll etc? ("Tess Blythe just knew she and John Tickle would never wed"). -
Compost pile coupled with some small scale hydro?
Pity I don't have a battery to try it on! ?
Would anyone have one of these 18V Duratool batteries? I'm after finding out the polarity, i.e which side is + and which is -. Cheers
Duratool multitool, ripe for conversion to Makita power. The Makita battery actually slides part way in. If there was a bit more meat in the tool base I could have maybe modded that. As it stands I'll have to figure an adapter. Fire up the Vernier George!
