Everything posted by Simplysimon
@Frod cortina the full length one on left of opening will become a trimming joist and needs to be doubled up or changed for larger sectional size, the short one across the opening will become a trimmer and have the same treatment as trimming. joist hanger required, the other option would be a tusk tenon to preserve the look and age of property.
How to put in fascia for slating without blockwork?
Simplysimon replied to Tin Soldier's topic in Roofing, Tiling & Slating
@Tin Soldier, unless you are intending to put any fascia up in pvc, don't bother. it will just be another thing to maintain, i'm not putting up a fascia. agree with the cold bridge detail, needs sorted. -
@Nickfromwales SSW and WSW no shading, btw this is your fault for suggesting SA+PV instead of ASHP ? @mike2016 don't have an EV car but may do so in the future so will put in the necessary wiring. i'm just trying to find out more info and options and hadn't thought of battery storage, more complications......
- 35 replies
- monocrystalline
- polycrystalline
(and 3 more)
hi all, starting to consider pv panels, wasn't going to bother but now starting to think about it. i had thought that monocrystalline was the best due to % efficiency but am finding that amorphous is better in low light. these are also cheaper and the returns don't seem much different when compared to the purchase costs. i'm not bothered about getting them fitted to get the FiT and would try to use as much as possible of the generation. i did search for monocrystalline but only got two results, therefore could those with more knowledge please advise? i would like to go for 8KW if i'm allowed as looking at sunamp and future proofing with car charging point.
- 35 replies
- monocrystalline
- polycrystalline
(and 3 more)
don't see the problem, should be able to clean the graffiti off with a suitable solvent.
that's them, with three years warranty as well due to aldi.
made to BS 1363 and from SMJ electrical
i'll check for BS and anything else next time i'm at plot.
well they did get cheaper, went to half price! so i went to all the local aldi and bought all i could find. ended up with 80 double sockets ? 75p per double socket, result.
Basic thicky question re. connecting to site hut.
Simplysimon replied to vivienz's topic in Electrics - Other
just curious as to whether anyone has got them and refused and the suppliers response as we wouldn't want one either -
are you going to allow them to fit a smart meter? -
won't mention the one in the last post then no doubt that'll come back to bite me in the future
- 21 replies
- patio doors
- sliders
(and 2 more)
insulation below steel column
Simplysimon replied to Simplysimon's topic in RSJs, Lintels & Steelwork
thanks all. i'll probably just wrap and cover in osb. -
evening all, anyone have ideas as to the type and size of insulation which should be placed below columns to be a thermal break? cheers
surely you're fitting velux to sarking as opposed to velux to battens? there should be instructions for fitting to sarking
tadpoles, food for the ones with legs!
- 367 replies
- ireland
- timber frame
not aluminium, thought about crittal?
cat 5 cable, which one
Simplysimon replied to Simplysimon's topic in Networks, AV, Security & Automation
aaahhh yes, thanks nick- 15 replies
- cat 5
- data cable
hi all, was in maplin for a connector and saw cat 5 cable for sale. there were different ones, does it matter which one i buy and are they interconnectable? 100m for £30 a good buy? cheers
- 15 replies
- cat 5
- data cable
Extending 1m beyond party wall.
Simplysimon replied to oldskoolflash's topic in House Extensions & Conservatories
iirc we didn't......... -
Slating a roof or two: 1, learning resources
Simplysimon replied to ToughButterCup's topic in Roofing, Tiling & Slating
@PeterStarck, did you use their pv as well?- 18 replies
up here i wasn't allowed the founds to encroach -
no part of your build is allowed to encroach onto your neighbours, this includes the foundations. once the founds are in you will need to be back from party wall for your wall.
