I think what you put around your timberframe is down to the final finish. If you want brick then use brick if you want stone then use stone if you want render, then blocks with render, not a silly board that you render onto if its timber cladding then that can be fixed direct with battens
Ok. Hadn’t thought of frost.
You can get a plasterboard bead to create the shadow gap.
- 9 replies
- door casing
- frame
ICF and airtightness
Russell griffiths replied to bissoejosh's topic in Insulated Concrete Formwork (ICF)
cavity closer system for nudura. Tape the inside and outside and I cannot see a lot getting through there. -
Why would a brick slip need to meet a British standard.
self build.....where to start.....
Russell griffiths replied to Amateur bob's topic in Introduce Yourself
Nope just full pp. topo survey flood risk survey contaminated land survey architect planning consultant ecology survey landscape designers, photos you can spend it real quick if you try. -
I thought a pre app was about £500 if your not prepared to do that I think you should walk away now. My planning application cost £14,600. Why would a building company do an application for you. -
I used a door as a jig on my last place placed between the jambs with packers, then screwed to the door lift the whole lot in place, and fix, when all screwed in remove the door and put it into the next frame. Is that what you mean.
- 9 replies
- door casing
- frame
This all depends on the make of icf, mine is all eps, including all cavity closers i know some other makes are as porous as a weetabix. You pay your money and take your choice. -
The only membrane I will be using is on my ceiling internally, it will cover the entire ceiling and be taped to the walls at wall plate level. Obviously all windows will be taped to the window jambs. I have used nudura i know it can be a very different situation with other manufacturers. No external membrane needed either. -
Why are you building this house??? you seam to be adjusting it to meet a budget, does this mean you will end up with something you don’t like better to build something you want and finish it later, get a shell up and move in why build a simple square box if it’s not what you want. Unless that hat is your building to ultimately sell on in which case you still need to see that accountant. -
I thought someone had already suggested YOU NEED TO TALK TO A GOOD ACCOUNTANT. -
Fit the door, fit door stops using a small packer to allow for paint thickness, 1.5mm?? That might sound a lot but think of 5 coats over time. Remove door, decorators caulk all gaps, smooth off with finger, get priming, 3) throw that book away or you will still be at it next week.
Cable threading tool repair.
Russell griffiths replied to Russell griffiths's topic in Tools & Equipment
I new one of you would know. Thanks @JSHarris ?? -
So spotted this local to be so had to grab it, but I think the end is missing, I think it should have a metal swivel eye thing. Anybody know if you can get spares, or what would you fabricate to go on the end. @Onoff @JSHarris @PeterW
You shouldn’t have it coming straight through a foundation, needs a duct to prevent damage and different movement in materials, but it doesn’t need to be 110mm. 32mm pipe in a 50-60mm duct or 25mm pipe in some 45mm duct. No need for 110mm.
Metal gutter recommendations
Russell griffiths replied to Russell griffiths's topic in Building Materials
Thanks @Moira Niedzwiecka That’s how ours will be cedar facia and soffit. Looks great cheers. -
Facia and soffit in cedar. 240Lm of facia 95m square soffit. That’s without the uv stain on it. -
Most of it is only single storey @Mr Punter plastic is just not an option, I wish it was ive just spent £5000 on facia and soffit. My wallet has never felt so empty. -
I can’t believe you cut those blocks around those bricks. Nearly spat my tea on the laptop.
Hi all looking for recommendations for a square box profile metal gutter, in a grey colour, not natural galvanise had an eye watering quote of £1200 for lindhab anybody got any ideas. Cheers russ.
Utility room: water and electricity together?
Russell griffiths replied to oldkettle's topic in New House & Self Build Design
Would there be some kind of regs about distance @ProDave,like you can’t have a hand in the sink and touch the consumer unit. -
Air Source Heat Pump vs Oil Boiler
Russell griffiths replied to paulc313's topic in Air Source Heat Pumps (ASHP)
How about a mixture of systems, could you use the oil boiler for hot water and Ashp for ufh. Would your opinions alter on the oil boiler if you already had one. We we have a 3 year old oil boiler sitting on a pallet from the old place we knocked down, it has been on my mind to ask these questions for months. -
If you need to work it all out it’s not as simple as you think. Your whole ground floor floor will need insulation under it no matter what system you choose, so you may as well put it under a slab instead of on top of your floor system. Strip foundations sound cheap, but probably no cheaper, And even if you go for a strip foundation, why a raised floor, cheaper to just have a ground bearing floor, suspended floors are not cheap. How many square metres are you talking about, and what is your budget @JSHarris built a quality home on an insulated slab on a very reasonable budget, have a read of his blog.
