Toilet seat hinges and fittings
Russell griffiths replied to Pocster's topic in Bathrooms, Ensuites & Wetrooms
Don’t bother go and get a quick lift off lid complete lid brackets the whole lot £17 just not worth messing about. -
Bloody hell how quick do want it to stop, my petrol ones run on a lot longer than that. Get the the flip flops on and stop worrying
As stated earlier flip flops are easier just shake you foot regularly.
Why is so much plumbing stuff such utter rubbish?
Russell griffiths replied to ProDave's topic in Boilers & Hot Water Tanks
I keep having the same problem with electronic stuff, 3-4 years and bang gone. I wonder what what the law is with fit for purpose regs, it might only have a 1 year warranty, but would you not expect something to last longer than 2 years. Maybe we should start pestering the stockist to actually find where this tat is made. -
I have a couple like this, I’m going around in a minute to do some testing, just brewing up a good test log. ????
All I will add is that PPE, should not be a substitute for having your brain turned ON imagine being in OZ and using a saw with flip flops on, it should give you the thought to keep the saw away from your feet, so just because you have a good pair of boots on don’t get complacent that you can swing it about like a sword. The majority of accidents are caused by poor work position or body placement, you should be in a position that you cannot physically contact your body if you make a cock up. I notice this all all the time with these diy YouTube vids with an 8 stone girl holding a circular saw, they just haven’t got the arm strength to stop a kick back hitting them straight in the groin area, which is one of the most cut areas with a circular saw, better to re position so the saw is to your side and cannot make contact with you in the event of a kickback. Same with a chainsaw. With a chainsaw one one of the biggest cut areas on the body is the back of the left hand, it is physically impossible to cut your left hand if you have both hands on the handles, the damage is done when a log moves so the operator decides to hold it still with his left hand and bingo, he’s cut his left hand. I would say another very dangerous task is cutting wood on a log pile, while you are cutting one log you do not notice that the tip of the bar comes into contact with another log resulting in kickback. Far better to lift every log log onto a saw horse and cut individual logs rather than plunging into a big pile.
I was sort of thinking that, the furthest wc will be used the most with bathroom attached, so lots of flow through the other chambers. I did upload a pic @JFDIY but it’s vanished i think I’m ok now, suddenly had a bout of overthinking.
So reading another post on drainage has got me thinking i have 4 WC all along a long 20m drainage run now it would be lovely to have them all on the main bottom section of the chamber base but I cannot see how this is possible, obviously the furthest away from the treatment plant will be on the main low run but the other 3 are going to have to come in at a side branch from the higher level. This just means the side poop will drop and splat im wondering about changing my chamber bases for level invert ones so there is no drop splat occurring. Im going to look at how the others on site work I’m not sure there is enough evidence of the drop splat theory to worry about. But i I can get 3 level inverts for under £100 so I’m happy to buy some instead of the standard ones I have.
Inspection chamber placement
Russell griffiths replied to Russell griffiths's topic in Waste & Sewerage
That sort of sounds like what he said @PeterW. I might do a sketch, he runs a large company and normally does big developments so maybe thinking a bit big. -
When I had my foul drainage drawings done I was talking to the drainage guy and he mentioned a method he preferred and now for the life of me I cannot picture what he was talking about. What he mentioned was having the ic sort of off line so not in the main run, I just cannot picture this anybody any ideas. @PeterW
Positive placement nail gun for all those hangers.
A Energy Rated unvented cylinder
Russell griffiths replied to Robert Clark's topic in Boilers & Hot Water Tanks
Blue peters finest there. ?? -
Towel rails on DHW recirculation?
Russell griffiths replied to Dan F's topic in Other Heating Systems
a lad I knew a few years ago did this on a couple of houses he built, no idea if it worked but he liked the idea. -
I did wonder the same, with all the insulation off cuts I have left, why could you not build a cupboard within a cupboard, so box the cylinder into the corner of the plant room. -
Which wood material to use for Sliding Door
Russell griffiths replied to overdrev's topic in General Flooring
You can buy mdf panels now with the grooves already routered. So you could laminate two bits of 12mm to make a 25mm thick door. -
That house you have pictured looks like it has a timber floor, don’t get to focused on one build method until you have a good look at your plot, I was going to use an insulated slab but found the height difference on my plot made it a bit prohibited. Lots on here have done nice houses to a reasonably sensible budget with timber floor and frame.
As long as it’s an insulated slab, not just a raft as the slab is warm unlike a raft straight onto the ground that would be cold. I dont think you even need the dpc, as that is under the insulated slab already.
Yes walls left short and a metal tie into the trusses, or blocks of timber either side of the wall, but definitely not fixed tight. I think it was to do with the bottom chord of the truss deflecting in high wind loads.
If you overhang what happens if they move and the new neighbour wants to build the same extension as you, they would want you gutter and facia taking back onto your own land. I have dealt with this this a few times in London and it doesn’t make for good neighbourly relations, I would say you need to keep every bit of your extension over your land. Most i I came across with this problem did a re-design and had a parapet wall on that side so a vertical face to the wall with no sticky out soffits
Sort of, if you use a passive slab you don’t use the ring of blocks. More savings. I would go for a metal sheet roof, lots on here used them.
Recommendations for tape and finish plaster
Russell griffiths replied to Drew1000's topic in Plastering & Rendering
A lot of the new products can be used for all stages, setting tape and finishing. My last place the lads used two different products as they liked that they where different colours top coat had a light yellow tint so it was easy to spot what had been top coated. -
Have you thought of shaker style this way you can have a lighter weight centre panel and heavy gauge styles. All mdf. -
Do you need a family bathroom?
Russell griffiths replied to Tom's topic in New House & Self Build Design
How ridiculous ?? -
We don’t have a family bathroom 3 bedrooms all with en-suites then a small cloak room. Im not sure what @ProDave means by accessible bathroom, as far as I’m aware in England I need to supply an accessible toilet not a full bathroom. Can someone confirm this before I loose more sleep
