If it was my workshop I would stick down some vinyl tiles on top, easy to sweep, nicer to stand on for long periods.
Modern Agricultural Barn conversion. Anybody done one?
Russell griffiths replied to Roger440's topic in Barn Conversions
This is a new plot with planning for a modern family home, I cannot see any reason why you cannot have 140m workshop with 140m studio flat above it, if it has full planning for residential than it would surely only be a formality to only have a part of it for living. -
I think you just need to move out a bit more I bought a few years ago a two bed bungalow with room in the back garden for a workshop that would be approx 18m wide and 12 m deep, is that not big enough. -
1. Get some waterproof pva woodwork glue. 2. get a big pile of fine sawdust from sanding wood. 3. mix it into a paste, push into gaps. 4. leave to harden then sand flat. 5. Send beer tokens to me. ??
If this is a workshop he will probably want the fire board wouldn’t he.
Of foul drains and sweet BCOs
Russell griffiths replied to ToughButterCup's topic in Waste & Sewerage
The last ic in the pics why are you entering on a side branch and not on the main run is there another pipe on the main run I cannot see if you are trying to turn 90degrees you would normally rotate the ic so you stick to the main run using two 45 to make back to 90 but you know this, so there must be more to that pic. -
MBC foundation question. Do I need that much Type 1?
Russell griffiths replied to rufusmacdoofus's topic in Foundations
Day aggregates -
Have you looked at crushed limestone, a few quarries around by you do limestone again you need to check with structural engineer. -
Did you ask for mot type 1 or crushed concrete type1 i would get a price and spec for everything available from anywhere, then contact the structural engineer and ask what is and what isn’t appropriate. -
Robins quarry -
Tuning cavity width for Flemish Bond
Russell griffiths replied to MortarThePoint's topic in Brick & Block
That would happen whether it be double brick or single they change course as they go around the corner.- 28 replies
As long as you are using corner blocks and don’t keep moving the line back and forth.- 28 replies
My mate in oz has one of the best workshop/ houses I’ve ever seen, we are both into old American cars hotrods 1950’s Cadillacs that sort of thing. What he has is is a huge industrial barn type building sizes just for an idea. 36m long and 12m wide at one end 12mx12m he has converted it into a two bedroom apartment, downstairs laundry boot room, spare bedroom, upstairs kitchen diner and main bed and en-suite. Next to this he he has removed the roof from the next 12m section to give him a 12x12 courtyard garden then at the other end he has a 12x12 workshop, 4 post ramps, Indian motorcycle, 52 caddy modal a coupe, heaven. -
Perps, the vertical joint between the bricks. As @Brickie said this is crucial to it looking good a good bricky will use his level to put a small vertical pencil mark to show where the next header will drop in place if you look at most of the modern brickwork look up at a tall wall and it will make you feel drunk as they wander all over the show.- 28 replies
C,mon I need cheering up. -
Has type 1 been specified by the structural engineer, why not ask if there is a different type of stone that will do the same job i believe each site has different requirements for what goes under the raft. Are mbc not installing this before the slab? have they not given you a specification as to compaction quality if if I was putting a slab on ground prepared by another person I would be very specific as to how I wanted it. If you do end up doing it the stone should be compacted in layers, normally something like 100-150mm at a time and I would use the biggest vibratory roller I could get on site. -
Ours was about £75 hour, all in they had about £4000 from us, worth every penny in my case.
The journey so far...
Russell griffiths commented on Thorfun's blog entry in West Sussex Forever Home
Swimming pools in England seem like a good idea at the time, but in reality only get used for two weeks a year. Do some careful planning with tree removal, once they are gone it is very hard to replace something that was 40-50 years old even the fruit trees, I’ve got 12 acres of land and wish we had more old trees, most of ours are only 30-40 years old and haven’t got the character yet. -
Lovely looking plot, anymore pictures. -
On another note mr @jamieled do you have any more pics of that cladding please.
You don’t need to cast anything in place. If it is block n beam just core drill the holes as and when you need them, up until the point you screed upstairs you will be able to see the beams so easy to just drill where you need the services instead of trying to get it right and being a bit off, you will probably find screening upstairs will be a long way down the list of jobs so lots of time to get services in the right place.
There is an old saying @zoothorn would you rather be right or happy, move on go and buy a couple of new sheets and some glue, get the floor down and don’t even bother the builder. £40 is not worth the stress.
You need to leave an expansion gap at the end of the cut sheet so cut that set 10mm short then offer it up at an angle going up the wall glue your joints and slide the offcut down the wall and into the groove use a timber wedge between wall and off cut smash it in to tighten the gap. Bingo use second offcut to start second row.
