Nestor
Everything posted by Nestor
Some friends bought a new build on an estate and offered a rather awkward parcel of land adjoining the curtilage which they purchased. Detached and end of cul de sac. They have just secured planning for large double garage and accommodation above. No guarantees but if the price is right, go for it.
Dealing with condensation…
Nestor replied to HughF's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Thanks for the reply. I do appreciate MVHR in the new build, do some MVHR systems have a heater to boost the heat recovery supply? -
Regarding MVHR even with heat recovery, during the recent low temperatures the incoming supply is about 16c which is then constantly lowering the internal room temperature which then requires more UFH input. Wondering if it is worth switching the unit off during these periods or is this a limitation of MVHR. -
What is the thickness of the boards and width between the joists, I used 22mm Caberdek at 400 centres and noggins not necessary. Glued and screwed.
VAT reclaim delays
Nestor replied to Oldsteel's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Update. Received letter from National DIY VAT Team yesterday, outlining they have received my documents and now hope to deal with the claim in 6 weeks. That took 5 months! -
VAT reclaim delays
Not received a reference number before I made this call last week. First contact since I posted back in August. -
How deep is your hallway coat cupboard/wardrobe?
Nestor replied to Adsibob's topic in New House & Self Build Design
550mm is probably the minimum. Coat hanger width is average 450mm. -
VAT reclaim delays
Sent my Vat return in August 2022. Rang them last week and after a 45 minute hold, spoke to a human who said an Advisor would call back at a specific time on Friday which they did. Apparently they are just processing late July 2022. Potentially another 4-6 weeks. -
HDD check required! 😉
If you are interested in growing both trees and agricultural / horticultural crops on the same piece of land have a look at the link below. https://www.agroforestry.co.uk We planted a thousand trees as soon as we moved onto our plot 12 years ago with a subsidy from Woodland Trust. Avoid the BBC.
joists - fixing to Nudura and blockwork
Nestor replied to Tom's topic in General Self Build & DIY Discussion
I used 22mm Caberdek P5 with D4 glue and screws. -
Hi Tom, would you be able to share a drawing or photograph of the above detail. -
This is the solution. Our local farmer had scissor lift and tele handler and helped remove large steel frame Agri shed for us. Then digger to remove existing concrete pad before starting to level the site.
I appreciate cost is a factor. The Spax fixings are 20 pence each and I used the Tongue Tite fixings at 5 pence each from Toolstation.
Nope, and baffles, partitions, ceiling hatch and 21 fake hip rafters. The existing roof space had no insulation or even felt under the tiles. Lessons learnt if I have to do it all again.
We had a Brown long eared bat maternity roost in our existing dwelling. 2m minimum height was required and like for like was requested for the space so built a 12m x 6m garage, planning showed no interest in the size of the new garage which was a win. The underside of the roof had to be lined with bitumen F1 felt and entrance and exit points at each gable end. The south facing roof had to be filled with cement between the battens under the metal roof to retain the heat and a heater inside! Try for the garden office roof space.
London flat renovation - Am I being totally ripped off?
Nestor replied to Hattie's topic in House Extensions & Conservatories
In Lambeth CPZ it is £23.10 per trade vehicle per day.- 23 replies
- flat
- conversion
(and 7 more)
