Nestor
    6
Everything posted by Nestor
  1. I am currently laying 100sqm of Porcelain 20mmx900mmx600mm at home, quite a challenge as a self builder., not a professional. Mostly level, some walling and steps. If this was my problem I would try core drilling through the lower rectangular tiles at the base of the wall and continue through the brick retaining wall. If the tiles break, remove them, drill retaining wall, clean hole through new tile and fix. It looks very smart in the photo.
  2. I started tiling first and made the Niche fit between whole tiles, used Hardie backer board and some tanking. Takes some planning but no cut tiles. Should work with your Metro tile size.
  3. Yes, the first floor built on top of ground floor. Two timber stud spine walls on the ground floor to support the joists, GF was 13m x 7m. The first floor timber joists were 44mm x 220mm x 4400mm + some glulams. Vapour barrier behind the OSB, Pavatherm on the outside then batten, counter batten and cedar cladding.
  4. As you might be on a stick build journey, I have included my wall / roof build drawing (Hand drawn) and a few photos. About 275sqm, took a while to get weather tight but very much the most satisfying part of my self build and it is square! Wall : Roof details-1..pdf
  5. @JohnnyB Thanks for the links and advice. Looking into this.
  6. Local recommended joiner / carpenter. Plenty of clients down here in South Devon who have the funds, not me. Looking at using Ikea cabinets with custom cut doors etc. About a 1/3 rd of the original price so far. New drawing using Ikea below. @AliG Wow, mind blown. You have skills....love it.
  7. I use Sketchup (Trimble) as a free version, though limited is available.
  8. @Bozza I do not doubt the quality and skill of the craftsmanship involved. We are near the end of the journey, broke ground in 2017 and moved in 3 years later. I have done most of the build except electrics, skimming and window fitting ( which was very poor ) so it is hard to justify spending over 10% of our total budget on two built in wardrobes. My build about £850/sqm. I have the tools and space but time is the issue as getting grief from you know who. I will start the drawings.....
  9. Did they supply you with drawings after they had measured up? I had vertical and horizontal section drawings.
  10. Thanks @AliG@Russdl. I think I meant cabinetry not carpentry in the title.
  11. @AliG Can anyone recommend a cutting service ideally using plywood, I can provide accurate drawings. We are planning on some built in cupboards and drawers in 2 bedrooms but a recent quote (30K) means an alternative will be required. Any ideas appreciated. Example enclosed.
  12. I had 9m3 of pumped Anhydrite, £2600 in 2018, 177sqm coverage at 50mm. £15.00sqm. Took about 3 hours.
  13. @Tom @sharpener GreenGenUK fitted my Ecodan in 2019, all good so far. I have the RHI which is very similar to the grant amount.
  14. My BCO would not budge and had to rent a calibrated unit from Sun Rentals. The BCO then accepted my own report but this was an unusual case compared to most on the forum.
  15. Hi @Novice Becky Not an expert but I think the condensation must be very high in the cold loft during winter months. I would insulate the silencers first and any obvious areas before you re-insulate the entire system. But the unit itself is very exposed to the cold.
  16. So all the VCD 's are in the loft which enables you to turn the blade manually, no air can get in. Would insulate these as well as both ducting silencers.
  17. I used a Steico reveal board https://www.mikewye.co.uk/product/steico-reveal-board/ but these were fitted before the windows against the timber frame and not used as a final layer for plastering.
  18. Thanks @Novice Becky for the layout. I installed a Vent Axia with manifolds suppling each room individually, hence not seen a VCD. Going to ask a stupid question but is the VCD on the extract or supply in the loft area? I can only add as above the internal insulated condensate drain.
  19. Can you identify what the arrow is pointing to, looks like a vent and what temperature is the attic during a cold spell?
  20. Hi Russell, I used the Tata Colourcoat Urban, self install. Paid about £25 - 30sqm in 2018 so that GreenCoat is a good price. What was the installation process like?
  21. Thanks Dave, I did spot lots of panels on both roofs. You can simply add more panels to increase the rating.
  22. This is the EPC for the above property, just curious how you get a rating of 120? Look like panel heaters on a wall in the kitchen and landing.
  23. I have been using https://www.protilertools.co.uk/product/ultra-tile-fix-proflex-spes-standard-set-flexible-s1-adhesive-white-20kg for a wet room. Only a self builder but excellent adhesion and ease of use.
  24. Genie for the lift and kwikstage for the pour.
  25. Correct, though you are not supposed to notice.
