Everything posted by Conor
I've looked in to this a lot as well... Come to the conclusion that a small monbloc ASHP with underfloor heating loops is the most cost effective (assuming gas price rises in near future) and lowest carbon emitting system. You should get your peak heating load figure from your SAP and go from there.
We're budgeting £1k/m² but in reality I'm aiming for £750-£800/m². I think with the low quarry material costs and labour here in NI, and me working part time and being PM, this is achievable.
I did a study (n=1), and in a typical 20min rush hour commute, having the start stop activated in our Eos increased indicated range by 5-7mpg, or 15%. It now really pisses me off when the start stop doesn't kick in sometimes ) battery voltage I think). The smoking bans are a similar story... Minimal reduction in respiratory disease risk, but we can all agree world is better off with the ban.
Change your 150mm floor slab to 100mm and stick in another 50mm insulation. Nominal cost difference but you'll save a load on reduced heat loss. We're on a tight budget for a similar sized house, focusing spending on insulation and thermal envelope. I'm happy enough to have a basic IKEA kitchen in exchange for minimal heating needs.
Ecology Building Society - application process and pricing
Conor replied to Conor's topic in Self Build Mortgages
Yes, sorry, SAP. Min is B85. I also wrote a project description - they want an idea of the overall project "eco" credentials. I focused on reuse of materials from the demolition, and my planned zero to landfill waste policy. -
For us, about an inch thick stack. Latest CC statements. 3 month's pay slips 3 month's bank statements for all accounts Proof of deposit Detialed costing for project (combo of QS estimates, quotes, all signed off by architect) Proof of address and identity (utility bills, passport) Current mortgage balance and 2 years of original statements. You'll find that will be universal for all mortgage companies. -
@darringo just started! Documents went in a couple weeks ago. Following up on one or two missing documents at the minute. So far experience has been positive. They are very thorough and detialed. They actually rang my coany to check that I work there... You get allocated a dedicated agent, so you have a direct line of communication. -
Also like the fact that it's a small house built on a reasonable budget. Not the usual multi million pound gargantuans that are usually revered and win awards (remember that rediculous hotel complex like "home" in Kent that won home of the year a couple years back?)
Who was the ICF company? Kore have included a quote for services from Tanner's for the EPS raft.
Perfect. I'll use my architects preferred engineer to oversee and check the manufacturer's calculations. She'll be coming out next month to do the soil samples anyway. As I'm an engineer (not an SE tho) and project manager, I should be able to manage any changes or conflicts effectively...
Hi. We're building using a passive raft foundation, ICF walls, concrete decking system for intermediate floors and an EPS panel system for the roofs. For each of those elements, each supplier has offered engineering services to do calculations etc. Normally I'd prefer a single SE to do all of this... But a lot of these are novel and proprietary systems and I'm not sure I could find an SE that is competent for all of these items. My local SE firm has never done ICF before... Anybody done similar, and what did you do?
That's good value. We would have charged £225 per half day on site.
Sorry, a local company here in NI, CES quarry products.. I know our concrete and quarry material costs are a fair bit cheaper here than in GB. Yeah, Kore will be doing structural design, definelty required if you're doing something other than a pure timber construction. I see base prep being key... I think I'll be retaining my ground works company to help with this. You're right about setting out.... Surveyor for setting out all corners is key. Luckily for me that's my background.
Has anybody tried the QuickBase pile foundation system?
Conor replied to howplum's topic in Foundations
On paper, it should be better value compared to traditional system. Largely due to less excavation, simpler excavation (no marking out of trenches), no rising walls, no secondary screed, smaller concrete volume. You're putting more money in to the formwork tho. But it makes eveything else simpler. -
I've costed up insulated raft for our 100m² footprint comes out at about £35m² largely DIY. Obviously if going for a MC, you would double this. -
I fully intend on installing my own Kore raft. And I'll be doing the pour as well... Self compacting concrete. Very little shovelling, moving, floating or tampering to do. It behaves more like a screed. Look up some videos. I think I will talk the concrete guy into being there tho... Cost wise, self compacting is £80/m³ vs £60/m³ for standard c35. But a lot cheaper then me getting a crew in for a day.
mains water - how to bring it in and up through slab
Conor replied to MarkH's topic in General Plumbing
You'd be right. If we need to encase PE pipes, we normally insert in to a steel sleeve or wrap in a plastic liner before pouring. In a domestic situation, bring the pipe up through a pvc pipe. -
Unfortunately I've been working in Dublin this week and not had a chance to speak to him... Will be speaking to him this weekend tho as I need his input on my proposed vent locations.
- 100 replies
- mvhr vents
- filter
My neighbour that installs MVHR systems insists on a coarse filter before the 2.5 filter. Massively increases the life of the filter, but more importantly delays the pressure drop as the filter clogs.
- 100 replies
- 2
- mvhr vents
- filter
Similar here but I'm choosing not to use a main contractor. I'm planing to build the ICF forms myself, then get a contractor in just to to the alignment and pour for each story. I'm the. Ordering the floor slabs as a supply and fit, and wil be using a small builder I know well to do all the internal carpentry. As long as you get the design details right and communicate them to your contractors then it comes down to the work ethic and skill of the workers.
Making savings by simplifying layout (most of work surface on island) and few units by moving storage in to pantry. Will likely fit it myself.
If it were me, I'd be taking £1k off the kitchen/bathroom budget and getting the best windows you can afford. Fabric first. Actually, that's what we are doing to get the standard of bi-folds we want, kitchen budget, down from £10k to £7.5k. kitchen is easier to replace than a window system in 10 years time.
Where would you put one sqm of extra space?
Conor replied to Ferdinand's topic in New House & Self Build Design
Super king all the way.
