BotusBuild
Everything posted by BotusBuild
As I know where my units are going I am not running pipes under them. In the islands we will have an extractor unit for the hob and that will no doubt create heat under the island. So, shrug, WTF. Low flow temps , it'll likely make no difference if you run pipe or don't
Advice on how water heating
BotusBuild replied to flanagaj's topic in General Self Build & DIY Discussion
We have a timer and override switch on the immersion, switched off completely right now. I guess this is the same thing in essence. -
We wanted 300, but the installer would only put in a 250. May change it sometime down the line after we've lived with it a couple of years and had a couple of family gatherings. All to do with the fxxking MCS calcs -
With an unvented cylinder (UVC) the flow/pressure is related to the pressure of the mains and size of the pipework. Also with a UVC you don't need water above 50 for showering, washing etc. (otherwise you'll just scald yourself, or use lots of cold to mix it down). Using an ASHP to go any higher than 50ish and you'll just be running it VERY inefficiently. -
Can the DNO cutout be located inside?
BotusBuild replied to WisteriaMews's topic in Consumer Units, RCDs, MCBOs
Ours is inside the plant room because that is where I put the duct as Nick said above -
Pass on the delivery details provided to the delivery driver. If I give you a What3Words address there is a damn good reason - postcode will put you in a 2.5 mile radius of the actual location
I feel your pain My local timber merchant allowed me to sort through the pile to select - in fact he helped and rejected pieces I was OK with 😁 Bolt them together as soon as you get them onsite, as they warp as they dry out. I would start with the two larger overlaps first and then do the middle overlap last. With the larger overlaps do the two pairs of bolts at each end of the overlap and work inwards (I presume you are putting in more than just two pairs of bolts on each overlap).
Spain/Portugal blackout
BotusBuild replied to Beelbeebub's topic in General Alternative Energy Issues
The £130/MWh is the thing that makes Hinkley a white elephant IMHO -
My standard answer for nearly 5 years to the question "When will you be finished?" was "2 years". It was my signature on here for about 3 years also. You will see I recently changed my signature and also my answer to the above question. Still no commitment, but a tiny bit more positive perhaps 🙂. Anyone interested in have some T-shirts made up with the question and first answer?
My earlier point about electricity-gas price link should perhaps have been clarified to state that the UK would then not be hit so hard by changes in the gas wholesale price. My argument is all academic because it would take this country too long to actually get a decent nuclear base load in place. Hinckley C was initially proposed in 1981, announced in 2010 with nuclear licence granted in 2012 - current project completion 2031. So 50 (expletive) years. Madness. -
We should have more nuclear and less gas as the base load in our grid. This will lessen the burden on bills of the electrcity-gas price link (which is a pants situation anyway). Investment in nuclear as well as solar and wind is what is required -
Saw this on FaceAche. Interesting explanation. https://www.facebook.com/share/16bjH3NyKQ/
That happens when travelling at 90 at meeting tractor 🤣 Othe things happen to the driver as well 😂
And difficult to stop. There is a version the Kia Niro like this and they didn't update the brakes (enough). The Howdens rep says he has to be very careful driving in the country lanes
Add 2x4 to the side of the top and bottom chord of the posi joists from underneath. These are the parts that do the work, generally the top one in compression, bottom one in tension. Some have used a metal strip on the bottom chord instead of extra wood
We'll make the effort Susie. SWMBO currently on bed rest for 2 weeks until mid May so after that is good for us. 1st week of June is kitchen fitting week. Any other time is currently good for us, probably weekend works best
Hey! New here, looking to do a self build around MK
BotusBuild replied to BHACHA16's topic in Introduce Yourself
Our local distributor came out on day 1 and helped get first couple of rows in place. That's when we learnt and the remainder of the first week we cracked on with the rest. Off the top of my head so these are rough numbers, we spent about £10-11k on concrete and pumps, about £3k (?) on rebar (retaining wall so more than normal required) and the Nudura was about £18k. We hired the props to support the walls for about £1200. All in, about £34k for insulated, air tight, and essentially waterproof walls ready to be rendered or clad outside and plasterboarded inside. -
JoH, What you have does not have an A/C function. Summer bypass will continue to do the air exchanges, so drawing air from outside to in, and vice versa, so as it cools down in the evenings it'll remove the heat build up from the day. You're better off turning it off completely in heat we have at present and drawing curtains and blinds to keep the sunshine out. There may be a way of introducing a cooling coil into the ducting, but that is major retrofit and may not be that effective anyway. We are all having to adapt to the conditions being caused the changes to or climate. If you want air conditioning in the flat for the handful of days each year when it currently required you'll need to install a specific unit. OR, hang a bag of ice in front of a standard fan
Looks like the water meter bills will be lower as well after they impose hosepipe bans 🙂
Here is a blog entry about the ICF install -
Stone, but it's the same basis as the brick slips. You can tile, so you can do this. Saved me over £8k doing it myself (not just what you see here) -
Nope 🙂 After I wrote the above, I remembered your comments about internal stuff, and thought "he'll do a grand job". I think you'll be surprised about how much you can do depending on what build method you use. We did ICF so only needed someone to pour a lot of concrete 🙂 In addition we had a steelworker, window fitters, plasterers and ASHP installers. You'll be fine -
To back up what Mike said above, we are 270m2, and doing as much of the build ourselves as possible (so far subbed out about £20K in labour costs, excluding professional fees). We are currently projected to build at a cost of £1300-£1400 per sq m. We are not using costly internal fittings, although once we have sold our current house, we may replace a few things later on. The more you sub out, the higher that figure goes, and the more high-end (Costly) materials you use, the same - we could easily have been above £2,000 per sq m. Don't be put off by this, just make sure you cut your cloth according to what you can afford.
