BotusBuild
Everything posted by BotusBuild
Openreach taking the proverbial for tree lopping
BotusBuild replied to BotusBuild's topic in Electrics - Other
Update: OR visited us on Monday and connected the cable from the pole next door to our new pole and down into the trench. The cable went into an OR supplied duct in the trench, and the end got left by the external box that Kelly Group had already installed (see above). Then, they found out that the cable at the top of pole next door was not connected to anything - you couldn't make this up. The guy went to the junction box (about 1/2 mile away) and sure enough there's a bundle of cables in there not spliced in. So, we are now waiting for the splicing team. FFS.- 16 replies
- tree lopping
- openreach
(and 2 more)
Openreach new fibre connection
BotusBuild replied to flanagaj's topic in General Self Build & DIY Discussion
OR just put our fibre cable in from one pole to the new pole, down into a trench we dug to the house and the external box. From the bottom of the pole they installed a small ducting (~15mm external diameter, black with a yellow trace) in the trench through which the fibre is fed. We were told we can fill the trench now. -
Installing skirting boards in first room. Cut and ready to fix. CT1 seems like overkill and may be difficult to remove (if that became necessary). So, which glue? Or sealant? Or silicone? And would you screw in as well, if so what screws? Something that is hidden would be requested 😁
What is the floorers reasoning for not using a leveller? Looking at the drawings, I would go that way; pre-seal the gaps around the sides of the area to be levelled to stop the leveller running away (a mistake I made) with tape or your favoured sealant (allowing it to set off), then apply leveller. Apply flooring. There'll be an expert along soon 😉
When doing first fix, I pulled aerial cable to 3 bedrooms, a lounge and one other room - so we have 5 end points into which a receiver/TV can be attached. All these cables run back to the plant room. I can run aerial cable through pre-fitted ducting from outside to the plant room also. (Pocster's already hating this planning ahead and preparation 🙂 ) From what I have gleaned from interweb searches, it is not possible to install one satellite dish, send the signal to a splitter to feed those 5 points and allow each individual TV to be able to freely watch whatever they want. Or even 2 TV's come to that, through a splitter. Suggestions I have read include a 4 "port" LNB on the dish and running 2 cable to each receiver/TV, installing multiple dishes (but this isn't some diplomatic mission or transmission station), or something called Unicable. We're likely to only have 2 TV's to be honest, the bedroom points being for future inhabitants should they desire them. So, anyone got a setup with one dish, and multiple receivers? What splitter/switch are you using?
I'm going to step back as I can't figure out the relationship between those two diagrams. I'm finding it hard to visualise. For others help the answers to the following may help - 1. Are the ground beams pieces of steel? 2. How many ground beams? 3. Does the slab sit on the ground beams? Or, are the ground beams embedded in the 250mm slab? 4. Is the SE aware of your requirement to put the UFH in the 250mm slab? He may design differently if he knows this. Sorry I can't help further at the moment
I may have missed something here. I'm assuming the ground beams (the dashed bits?) will be poured at the same time as the raft - they would just be thicker than the rest of the slab, say 350 instead of 250mm deep. If so, then just lay your pipes as you have described, although I tied ours to the top mesh, before you pour the concrete.
Grey water via bore hole or storage tank.
BotusBuild replied to MikeSharp01's topic in General Plumbing
Ah, memories of an all-night party on the beach while a student at Cardiff Uni back in the 80s. -
So, EE are working on this. Well they have "contracted" Openreach to install FTTP, but they have already sent the router. So far, OR have installed a telegraph pole and sent someone from Kelly Group to install the boxes outside and inside the house with a piece of optical fibre between them via conduit I had installed during the build for this purpose. We have dug the trench from the base of the new pole to the house, and are now waiting for OR to realise they have not connected from the pole where the fibre already is to the new pole and then to the house via our trench and into the external box. Watching the new pole start to rot and get vandalised by woodpeckers in the meantime.- 16 replies
- tree lopping
- openreach
(and 2 more)
Summary if you dont want to read it all - contact EE to request new broadband, let them deal with Openreach. I applied to the broadband supplier, Plusnet first but then switched to EE. Both were told it is a new build. I provided postal and What3Words addresses. In both instances, an Openreach dork(s) came out to survey which in both cases involved me telling them where the relevant pole was already, where they needed to install a new pole, where they would be putting the box on the outside, and the inside, which conduit they would use, and I would trench from the base of the new pole to the house. Plusnet wanted to pass on over £1100 of Openreach install fees, so I took some advise from the site and applied to EE instead who are covering the Openreach fees. I will be paying the £20-something per month for 2 years for broadband. See this thread for more details https://forum.buildhub.org.uk/topic/44113-openreach-taking-the-proverbial-for-tree-lopping/ -
More detail required. Are plans already approved? They should stipulate, but you say red brick, timber and glass. Is that what you want, or is that what's on the plans? Is the plot 270m2, or is the proposed house 270m2? Any pictures of proposed building to share. Can you share anonomised plan drawings (no names, no addresses)?
How many double check valves are too many?
BotusBuild replied to Super_Paulie's topic in General Plumbing
Keep the u bend and elbows in one cupboard AFAIC. Neater and will therefore annoy certain people 😀 -
Definitely comes out of their lounge, so not a kitchen extractor. Take your point about they may not have fitted the woodburner, but it's been there for 18 months already, so they could be challenging some of our procrastinators here on t'hub 🙂
Just done a short walk around and found the flue for the gas boiler is elsewhere, so I think this is definitely a chimney for a woodburner, and not a flue as in the subject. My mother, who lives next door k new the previous owners and this chimney comes out of their living room. I think a message to the local council will be forthcoming from a "concerned passer by". I also noticed cracks in the brickwork around the strap support, so you right, Nick, a shit job.
Help with wiring LED mirror in zone 2
BotusBuild replied to Beau's topic in Electrics - Kitchen & Bathroom
I just did this - took a spur from a socket in an adjoining bedroom, to a fused switch in the vanity unit under the sink, then fed the wire up to a blank plated box behind the mirror. -
In which case, we won't complain on behalf of my mother as he is a nasty piece of work and the fumes may help get rid of him 🙂. That ladder could have been mounted lower as well. 😁
Is this flue breaking the law? I thought they had to end above the roof line. (Please move if in wrong forum)
Get a qualified electrician and extend the ring main.
Week 8 - And pause... or not.
BotusBuild commented on Benpointer's blog entry in Contemporary build in north Dorset
That is looking very nice indeed and I can imagine why you are so pleased -
Susie, Nick is right (as always) and I was on my way back to suggest same thing as that is what I ended up using as well. The push fit boss in your last post will do the same thing as what nick suggested.
We're not all arsonists 😀 Reminds me. I must burn that pile of rubbish pallets
That soil pipe suggestion i made is daft @Susie. Start with the swept T but just do a straight line to somwhere close to the basin and the shower with no other bends. Doh, what was I on last night? A show, a basin and a washing machine into that manifold should be far enough away from the toilet pan. Probability of all three being used at the same time i would think is small(ish) so I would use one
Susie, What about inserting a swept T in the existing soil pipe and then extending the soil pipe through the 180mm insulation following the red line in the edited photo. Then run your basin and shower waste following the approximated blue lines? Your waste pipes from the plant room could also come through the stud wall into this soil pipe of course. Then you can go down to 32 or 40mm waste pipe for each "appliance"
