BotusBuild
    10
Everything posted by BotusBuild
  1. Now doubt then that it will end up being owned by some foreign state fund or pension fund, because UK equivalents will be too short sighted to consider investing
  2. We started as weekend and holiday time builders as I was still working. We're now weekday builders and the switch was strange. The 6am morning 🀣 Yep, that's a self build thing. And power tools (angle grinder v manual cutter) are your friend. They will save those joints πŸ˜‰
  3. I plan to use the external Soudal SWS sealant
  4. Aren't the actual 'bulbs' or strips standard items. If only πŸ˜€ Not all luminaires have bulb that can be changed without literally taking the whole thing apart and possibly even getting out your soldering iron. PITA
  5. +1 use the right sealant and clean up the finger wipes at the same time
  6. You've all got it wrong. You attach an anchor to the seabed
  7. That's the plan πŸ™‚ Probably go for 10-20% spares of whatever we fit.
  8. Our current product of interest is LED downlights - colour, wattage, dimmable, tilt angle, diameter, replaceable bulbs, opening size, module or direct wiring. Who knows if some of the manufacturers will be around in 5 years when no doubt one or more will need replacing, and the thought of having different looking downlights in the same area just leaves me cold
  9. Far too modern for me 😁. And I have a "thing" about BMW (long story)
  10. Why I love driving the MGB GT, and always with a smile on my face, which cannot be said of my modern daily drivers (apart from the Saab 93 I used to own)
  11. Its great when things start to take shape to your plans. Keep going, its well worth the effort in the end. This all reminds me of our start, and also that I need to do a blog entry πŸ™‚
  12. He sounds like a trade person that takes pride in his work and will want to resolve this. Don't feel bad. Taping maybe the answer but let the plasterer deem what is necessary
  13. Fire appliance access could be a planning issue, but can be overcome by having a mist or spray system fitted to final build
  14. You can add images here πŸ™‚ With a freestanding bath, the main differences are that the waste pipe will likely need to go under the floor "to hide it", and your hot a cold water will connect to what I call a "stand pipe" tap. So, it all depends on what has happened with your first fix plumbing - where do the hot, cold and waste pipes currently end? Are there near where you want to locate your freestanding bath, or would they need moving somewhere else?
  15. Now you've guinea pigged it, I know how I'm doing mine 😁
  16. Ahh, blue air days. Had a few of those pulling cables in my early work life
  17. Is the 25mm a physical space limit? I find that very difficult to believe
  18. If just a shell then install as much cabling as you can, and then conduits with draw strings with long radius bends wherever you think you might need cables in future. However, just pull as much cable as you can now, even if you don't use it straight away. Just keep lots of notes/photos of where the cables end
  19. 🀣 The way i would do it - Minimum two pieces. Lower piece [fit first] goes on the lower horizontal, up the lower vertical, and along the midline horizontal. The second piece overlaps on the midline horizontal, goes up the upper vertical and then over the top.
  20. I've put conduits in to run extra cables from plant room on ground floor to roof level for things like solar and aerial cabling. All have draw chords ready to pull cable
  21. Spinny, The pipes will most likely all be push fit. It might be a fight to get them apart, depending on how your builders fixed them in the ground (hopefully they didn't set in concrete). If you do get them apart check the rubber seals are not damaged before trying to re-use them - if they are, then easier to replace the whole fitting fo peace of mind. You will likely need to do some pipe cutting to be able to move the trap/gulley closer to the Y-branch. Lots of measuring and checking and imagery in your head as to how it will all fit back together. Take you time with the refitting and it will all slot into place. Don't beat yourself up if you end up having to recut pipes a couple of times
  22. Three things that might help: 1. Some photos of what you have currently (the as built situation) 2. An index of what those numbers in the diagrams are (for example 8. Insulation) 3. An indication of precisely which pieces you are expecting to get fabricated
  23. Err, yeah. Asking for recommendations before making a choice πŸ™‚
  24. Are the bulbs replaceable in those?
