BotusBuild
    10
Everything posted by BotusBuild
  1. Thanks, I know, but this'll be a nice stopgap, building control passing solution, until the primary access is built 🙂
  2. Thanks. Looks like I'm going for a ramp on the inside of the door, and I now have a cunning plan to make it part of a piece of furniture that will be in the hallway, so we can have it in place as and when needed e.g. when the BCO comes to visit 🙂. I'll try and remember to post piccies when its done (don't hold any breathes) This becomes our second disable access 😉 Thanks everyone
  3. Thanks @nod The outside of the door will be fine. I have a plan for that. The bit I'm concerned about is on the inside of the door, which is what the pictures are of.
  4. Click LVT, although if we need a landing step, we could incorporate a mat well, or do it with a slate top that matches the porch area outside
  5. Currently the internal area of the front door involves a 49mm step down (not including the 20mm or so of the door frame). I've read relevant BR and still not clear if this is OK. So Q1, is it OK? If not then I propose a step inside the door that goes an appropriate distance from the door as a "landing" area. Something like this Q2. Would something like that satisfy BR (if it is required)?
  6. 4" thick with 30mm stones? I think you'll see a lot of gaps (spy holes) between the stones. This maybe the effect your after of course but if not then go up to 6" as that should eliminate most "spy holes"
  7. The double end hooked wires are going to need to be plentiful i think, probable at most 200mm apart to stop bulging. Maybe a good idea to alternate the spacing of the hooks to also reduce chances of bulging. Trying 4-600mm depth to start with.
  8. Will do for the last 10 🙂
  9. A quick follow up and another door lining question. All the door linings I bought were kits and the headrail had grooves cut in it for the legs/jambs to fit into, which I ended up having to reposition because of the opening widths. Could I just buy planed timber and make up linings? Yes, probably. Do I need the grooves in the headrail?
  10. Don't forget going over budget
  11. You've got the idea - adding to the thread with the start of a myriad of ideas 😅
  12. I just found a lovely use of a zip tie. Couldn't get the bottom screw of the pipe clip in ....
  13. Which require a nut on the other end? Is there another type? I don't want to have to get to the "hidden" side of the glulam beam
  14. Brilliant, that'll do the job
  15. Is he a PM who you have given QC responsibility to as well? If so, 1) get rid and replace if you must have a PM Or 2) renegotiate price to remove QC responsibility and carry on doing it your self If you haven't given them QC responsibility I can understand lack of visits to site.
  16. I don't have any, but treating it as if a first floor balcony
  17. FYI - the glulam beam is wood, of course, 300 x 150 mm, 6m long. On the now hidden side are some web joist every 400mm. And various wires, vent ducting and insulation. Murphy will have placed a joist in the way of at ones set of screws, nuts etc 😁
  18. Yes. Only problem is have with that is having to remove the ceiling the other side of the glulam beam to put the M10 nut and a washer into 🙂 Now looking for M10 tube inserts of a suitable length ((50mm?) for the glulam beam.
  19. We're looking for reasonably priced versions of this style of balustrade (clear, not frosted). It will be fitted to the glulam beam in the following pic Anyone know of anyone, preferably in the South West, but willing to source elsewhere if delivery is reasonable.
  20. As you are in flats, I would say doing something to the concrete floor to lower it is a no-no. So, I think you are limited to a riser kit, and use a shallow waste trap like this https://www.screwfix.com/p/flomasta-space-saving-shower-waste-white-90mm/513jn?ref=SFAppShare You can cut the waste pipe as you describe, just measure very carefully, offering up the replacement waste trap to check for location. I've just done this myself - attach trap to tray, put a couple of blobs of silicone (or similar) on the bottom of the trap, place the tray carefully into place and allow the trap to touch the floor. Lift it all out again, and you a should see where the silicone touched, showing you where the trap will be. Now take the trap off the tray and work out where that pipe needs to be cut.
  21. I had 3 x 180mm holes drilled, about the same length. IIRC it was about £250. Whatever size you think you need drilled add 10mm, then foam the gaps after fitting the pipe. Don't ask why I know.
