scottishjohn
did you even look https://www.ebay.co.uk/sch/i.html?_nkw=standing+seam+roofing
here you go http://www.metalsolutions.uk.com/home.htm
decent tin snips my guess you might need 3 types --straight +l/h cut +r/h cut duck bill pliers --maybe panel gripping shaped mole grips and remove the locking bar https://www.ebay.co.uk/itm/NEW-5PC-TRADESMAN-TROWEL-SET-CONSTRUCTION-HAND-TOOLS-BUILDING-SOFT-GRIP-HANDLE/302969987144?hash=item468a6b2048:g:~LcAAOSwNYtb-D45:rk:11:pf:0 cheap i know --but can,t find duck bill on its own a site that does metal roofing tools https://www.ebay.co.uk/itm/CRANKED-180-mm-DECK-SEAMING-PLIERS-TONGS-FOLDERS-ROOFING-TINSMITH/401701040496?hash=item5d873f7170:g:92cAAOSwK9ZcWJEb:rk:3:pf:1&frcectupt=true goggle the world --someone has it somewhhere
Alternative to plastering a ceiling???
scottishjohn replied to Dub Thing's topic in Garages & Workshops
my guess is his trusses will be too far apart for plasterboard ,and he won,t want to strap it at right spacing, judging how he wants to do it cheap, and its a shed anyway so OSB will take bigger spans than plasterboard without sagging in a couple of years time. -
I would --but thats just me- those extra edge noggins might be handy for attaching air barrier to as well
this site will send you a PDF file showing all in your area for £54 inc vat Site Investigation Services (UK) Limited Abden House, 6 Linton Court, Kinghorn, Fife, KY3 9YH Tel: 0333 123 1223 Mob: 07912 506 505 or please visit us at www.siteinvest.co.uk Registered in England and Wales No. 6511672 - 80 Baddow Road, Chelmsford, CM2 7PJ
Spacing between gutter brackets
scottishjohn replied to vivienz's topic in Rainwater, Guttering & SuDS
which on most builds will mean a down pipe at each corner of the building with be fine,maybe an extra one in the middle someone will have a roof area calculator /gutter size spread sheet. If they have would a handy post as a "sticky" -
Basement - ICF vs Shuttered Reinforced Concrete
scottishjohn replied to Red Kite's topic in Basements
and how much each are those pieces ? before you tell me i know now no self builder could afford them or use them to build a basement with them . ICF will do anything you need for a domestic build at affordable prices -
Ive used Tbar when doing a jumbo gyproc steel framed wall come to think of it got a load left hidden under old van body in garage compound .lol
sourced in UK? was not aware you could special order drywall at those sizes
Airtight membrane / Vapour Control Layer
scottishjohn replied to bissoejosh's topic in Building Materials
not hard to find just goggle https://www.amazon.co.uk/Air-Tightness-Tape-Gerband-Hermetic-60mm/dp/B0767JBMR6/ref=sr_1_2?ie=UTF8&qid=1549654230&sr=8-2&keywords=gerband -
If you doing a near passiv self build ,why skimp on plasterboard -use 15 mm though out --will just improve sound proofing and insulation value. you spend 10k on an insulated slab then penny pinch on plasterboard --no sense to me.
more thickness to put screws in edges and unless you on std 8ft ceilings you going to have some joints anyway . if doing a proper finish coat it don,t matter anyway tapered edges were made to allow just filling joints and sanding --for cheapness . a proper plaster job should not need any sanding when finished if he polished it correctly and square edges won,t phase a REAL plasterer at all,
yanks have 12ft or 16ft sheets x 4ft wide.
will probably be mandatory in some parts of uk for BC take a look at VELOX system maybe. and yes --again will be mandatory in some parts of uk . and a perimeter french drain as well that's like a durex warranty-- too late when you need to claim on it and so much will depend on your ground conditions and water table again check Velox and also isotex system --both do them and you use rebar from walls to tie it in . using std shuttering --you got pay to rent it -then remove it --seems a waste compared to an ICF system to me if you want to use poly type go look at Isodom 2000. loads to chose from -
just a thought. has this waste pipe got a u trap in it? or something --not just a direct open connection so no smell from drains can percolate back up ?
- 44 replies
- wet room
- dimensions
a non building professional approach dpc top and bottom of the sleeper wall you are building between your beam and block floor and the foundation slab below ,presuming that slab is capable of taking the transferred load from above and pack it tight so you don,t point load beam and block floor could be rubbish --you decide --just my ramblings
Anybody using Velox ?
scottishjohn replied to Tim Alsop's topic in Insulated Concrete Formwork (ICF)
after some more talking to plasters another suggestion came up --which could be quite good bury all electrics totally in wall then, as the woodcrete walls are flat anyway glue and screw drywall directly to walls -- not really dot +dab --but hard up to wall ,as you can screw directly to woodcrete + the plasterboard glue then apply simple but thinner 2 coat plaster finish . cost of doing base coat i have been told by 3 different people with be about same price as plasterboard,,but no chance of problems with wet plaster adhesion ,as some feel the woodcrete could suck all the life out of the first coat cos its very absorbant so could need some sort of sealing to be super sure of good adhesion and correct drying cycle . now it will cut cost down as I will be fitting all the plasterboard,except metal corners --most plasters like to do that them selves +just simple plastering job for the professional -
Ideal wet room design from slab pour on wards
scottishjohn replied to scottishjohn's topic in Bathrooms, Ensuites & Wetrooms
40mm enough to get all drain connections etc happy without lots of grief, certainly don,t need 40mm of slope and did you lower UFH piping in those areas ? -
checking victoria plumb they seem to range from £600 -£5k if you really want to be silly -
well you won,t get overheating as alot complain bout with big windows
not impressed how they seem to make big deal of a 2 years no crack warranty -- like my pebble dash on my current house has been there 30 years and is fine --no mesh just sand and cement . so juts how much better are these fancy renders --makes you wonder -
all I am suprised at the need for mesh on a rough woodcrete block -- woodcrete will have as much if not more grip than brick or block work . maybe its the way i read your post i read it as though the mesh was needed because of type of block as an extra to normal rendering ? -
durisol and any woodcrete block are so rough they are perfect surface for rendering simple "scratch coat" to seal it up , no way will it need extra mesh over what any other surface would need to apply a render to I have not priced outside render as i am probably going for cladding or stone /brick slips that could be normal price for modern type of render here you go http://www.ukimperial.co.uk/K-rend-cost-price -
just a thought but I have seen same problem when gutter is fitted to tight to end of slates and a bit low ,so when water comes off roof in downpour it nearly shoots over the outer edge . some roofs are built with a different shallower angle for last couple of slates or even just the last slate to slow it down the water for that reason . there is a name for it ,but i can,t remember it at this time .old age
