scottishjohn
What boiler to go with Solar thermal and wood burner
scottishjohn replied to geoffdg's topic in Solar Thermal (ST)
from my experience with 40 tubes I think really you need to run at least 2 tanks ,so anytime there is sun that can give 30+ it can dump it in to a tank --cos if your main tank is already hotter ,the solar just sits then be able to direct it to UFH or DHW as required.-ue plater heat exchanger maybe --not actually interfere with ufh water circuit directly Iran my underfloor as a test in february on this hosue ona sunny day --direct from panels at 25c If that was a modern type of slab and good passiv type house -- storage is always problem with solar --you need alot of it and to be able to keep it at dif temps levels ,to get what heat when you can --so retro fit always going to be a problem. or do like i saw a house in switerzland 2 storey typical tall steep angled roof --one complete gable end was a tank so you would have nearly 30ft to stratify the temps -- they do have very clear sunny days even in winter ,which would help very much as it would be being topped up and in summer whole tank would get hot eventually my guess about 15000litre tank not a retro fit job ,unless you got a gable with no windows. lol but I just wonder with very low energy modern houses if it might be possible to do --- 97 replies
- solar thermal
- wood burner
maybe it recovers quicker than some think ? not sure what the difference is between the 2 descriptions --both store hot water,both are insulated i,m sure someone will enlighten us my last one had solar coil ufh coil in middle and dhw at top and the i fitted blender on outside to mix mains hot and cold to get desired temp and not just use all the hot water which would then need alot of cold adding at the tap- 97 replies
- solar thermal
- wood burner
why do you assume I don,t know that maybe you need to find a more co-operative EPC man ,then you get max payment- 97 replies
- solar thermal
- wood burner
thats the beauty of buying good quality tank 270 litre i think I don ,t need to know and as i have the solar type unit i can heat dhw for free 80% of the year . and it has an immersion element as well which it uses when it decides to . I,m happy with the system - i don,t have mains gas ,so it was the best simplest all round choice I already said early mains gas is the cheapest . I have no idea of recovery time as I have never run out of hot water with 2 bathrooms- 97 replies
- solar thermal
- wood burner
yep,mains pressure DHW ecodan ASHP and a plumbed cylinder +controller package --does UFH +DHW . ashp runs high temp for DHW only when it needs for anti legionella -all automatic you set temps for both UFH +DHW on controller- 97 replies
- solar thermal
- wood burner
funny how my ecodan plumbed unit works fine -heats DHwater to 55c - or you telling me mitsubishi don,t know what they are doing ?- 97 replies
- solar thermal
- wood burner
NO. Ive had LPG and it is worse or sometimes better than oil,depending on world pricing and deal you can get --but both are so much worse than mains gas. so spending more on the insulation level should be first goal as that will drop your energy usage now and forever doing that is the first and best thing you can do for your house ,how you heat it is secondary . anyway --look at getting insulation better and look very hard at ASHP +RHI payments you can get -use that to heat UFH and a thermal store for dhw. as already stated getting multiple heat sources will only work well if you are into serious control systems- 97 replies
- solar thermal
- wood burner
1,6 kw prhr x 24hr =38kw that is real worse case scenario as not many days inyear when you see -10c average winter temp here from epc calcs is +3c. ok another question --total energy used in last year for heating ?- 97 replies
- solar thermal
- wood burner
yes it was you JS so actual heat input for 24hrs is around 38-40 kw that's fine thank you- 97 replies
- solar thermal
- wood burner
srtaight away even before i go check the rad level will be more than where i am --so that will alter things and at what cost per kw you calculated the savings.- 97 replies
- solar thermal
- wood burner
well that what the last quotes i got was working out at when fitted by MCS , why would you think i,m just trying to argumentative if i could see a gain in my pocket . I have no system at this time --no axe to grind -nothing fixed in stone so that is why i ask where in uk (rad level) and is that fitted price by MCS --cos the er will be no government money unless it is- 97 replies
- solar thermal
- wood burner
Is that fitted by MCS and where in uk- 97 replies
- solar thermal
- wood burner
so tell me how many kw,s do you need per day to heat your house with a floor temp of 24 c- 97 replies
- solar thermal
- wood burner
retro fits are always going to be problems . from new you just wouldn,t do that- 97 replies
- solar thermal
- wood burner
you guys have comfirmed what i thought --leave wet room floor 100 mm down and make it up later when she has decided on fittings
- 44 replies
- wet room
- dimensions
yes the first system i was supplied had that ,but i changed it for an auto air bleed unit and a little running soon bleeds out the air ,very little actual volume of water in the system- 97 replies
- solar thermal
- wood burner
yes a bad installation by the sound if hiding it all away- 97 replies
- solar thermal
- wood burner
unless its changed it should be ,but yes as you say not for space heating last time i asked I looked at it when i changed to ASHP, but the extra i was going to get OVER that I already got for ASHP made it not worth getting an MCS to fit it . I used plumbed eco dan solar cylinder +controller,but as far as they were concerned no solar was connected. doing it again i would not do it that way as the protocol for DHW on plumbed cylinder would reduce the hours i could get from solar ,when that should be first priority for DHW at all times- 97 replies
- solar thermal
- wood burner
yes solar is eligible for RHI- 97 replies
- solar thermal
- wood burner
Quick bit of help please: which way round?
scottishjohn replied to ToughButterCup's topic in General Construction Issues
left one - -how you fitting drywall on top of this ? direct with screws or batons ? maybe make sure your drywall fixings don,t clash with theses fixings fixings done like left one could break the foil on insulation ? -
thats just your view -- convincing numbers for both the systems from scratch is what is needed -- 97 replies
- solar thermal
- wood burner
like all thse things it comes down to designing the system . but yes a simple non complex system will give you 80%of your hot water needs with 1 panel +heat store . and cost not much to do . and if it is a modern close to passiv house --that will be your biggest heating expense year round I am awaiting someone doing a new spreadsheet on actual costs on PV now grants have gone and pay back time . the fact that no one seems to be pushing selling PV systems anymore ithink gives us the answer the 7year payback is now twice or more . so come boys convince me I,m wrong with figures- 97 replies
- solar thermal
- wood burner
now virtually all grants +FIT gone on PV I do not see how it is viable to start off now with PV even if you can do it and fit it all yourself its still a lot of years just to get a draw +presuming no mechanical expenses like replacement of invertor- 97 replies
- solar thermal
- wood burner
first question must be --how good is build --is it near passiv --or old leaky thing can you get mains gas?- 97 replies
- solar thermal
- wood burner
