Mr Punter
    25
  1. A general builder would be fine for this. It looks like the pipe is 110mm soil pipe. They can reuse the terminal that is there.
  2. Needle nose pliers?
  3. I understand that the Ditra stuff is fine over most stable surfaces. You can see that removing the battens will make a mess, so just let it all dry thoroughly, Ditra and tile away.
  4. If the vent was extended up a couple of feet it might help. Not a difficult or expensive job.
  5. Having seen the extra photos I have not got any useful suggestions I am afraid. Getting a balcony like this, with habitable space below and closed at the front and sides, needs very careful planning and detailed design and specification, which it did not have. If it is left as is there could well be major damage because of water ingress. I think you should get a specialist designer and have it redone.
  6. I got some Zigbee temperature / humidity / monitors and a hub a while ago. You only have interface via their app and I could not work out how to store the data locally. The stuff began to fail and was more of a pain than it was worth, so it is consigned to the "drawer of crap" in the filing cabinet, together with some SONOS stuff that was Emperor's New Clothes a few years ago, but turned out to be his grubby jockstraps. I may be mistaken, and the stuff is actually magic.
  7. Do it after. They will get in the way and make the renderer even more angry.
  8. You might just about squeeze in your soakaway where the tonne bags are. Put in the crate type.
  9. Well the good news is that it looks really good. You have issues with the failed drainage and waterproofing, so I think you need a redesign of these aspects. If it is just the drainage, you may be able to leave the tiles, otherwise, probably strip and start again. You really should have more than one rainwater outlet here or at least have it so any surplus water would run off the front of the balcony rather than into the building. GPR is good on flat roofs and if specified correctly should be ok to tile onto.
  10. No need for an alley to the back as per most mid terrace houses. It is handy sometimes though.
  11. You could do a 2 storey side extension, but I don't think there would be enough area for it to be worthwhile. You would also need additional bin / bike store space.
  12. If there is a new cheapo EPC you may end up with an E rating.
  13. The ridges don't look great. The one on the lower roof looks really dodgy. I would not worry about the colour.
  14. The timber frame will shrink downwards by about 30mm relative to the brickwork.
  15. Unless you are doing this for aesthetic reasons as part of a facade remodel you are wasting your money. You can do a 2 storey rear extension without full PP.
  16. I recently got some quotes for EPS bead insulation in a new build 150mm cavity. 135.8m2 net of wall area, 20.37m3 volume. First quote: £8,890!!!!!!!! Second quote: £4,080 Third quote: £1,453
  17. (expletive deleted) me this is turning into Round Britain Quiz.
  18. You can just run a CAT 5 with the power cable back to the house.
  19. I have some small rental flats that are all electric. If we need to improve the ratings I think gas boilers would be the best bang for buck. @oranjeboom any how much more your electric has gone up since you went all electric? The ASHP should make quite a difference.
  20. Are you doing the whole ground floor the same? Be good to see some pics as it progresses, especially setting out, 1st row etc.
  21. Hits on Google is one of the main drivers for investment and development of the internet. Every company uses it as a metric. In this case it is indicative of the relative popularity of the 2 systems. GSHP looks more likely to become obsolete.
  22. On Google I get 22m hits for ASHP and 500k for GSHP. It looks like ASHP is the way forward. You may find GSHP difficult / impossible to maintain in the future.
  23. Agreed, that really is quite vile.
  24. You warranty provider would want certification, so not DIY. The manufacturer of the blown in cavity wall insulation must operate an approved installer scheme where the installers are approved, registered and regularly reviewed or demonstrate they are competent to carry out installations of the product in accordance with the third party product conformity certificate. Evidence of the installer being approved by the manufacturer should be made available to the Warranty Surveyor upon request.
  25. I would recommend FAAC for the automation kit. Most of the kit knows when there is an obstruction and will stop. I wouldn't get a builder to fit it unless they have done them before. Will you have a keypad and intercom as well?
