Mr Punter
Where to start first board with uneven walls?
Mr Punter replied to Joe87's topic in Wood & Laminate Flooring
Space it so you will cut the first row. Work out where the last row will fall so you can decide how wide to cut the first row. Bank on cutting 2 rows. -
Ignore as I noticed this is for timber frame
Resin fixings would be better as they don't expand. Clean the holes thoroughly before you resin.
It really should not cost a fortune to render an extension in sand and cement. How much was the cheapest quote? Is the BI insisting it is rendered before signoff?
What fixings may I need to stop leaks?
Mr Punter replied to David001's topic in Roofing, Tiling & Slating
I would keep the fixings you have and tighten them a little, so the washer is snug on the sheet. -
Large tree stumps where house will be on the plot- foundation help
Mr Punter replied to Jane W's topic in Foundations
Not strictly on topic but it appears that you are building right up to the boundary on the left. Do you have consent from the adjacent owner to erect scaffolding and possibly construct foundations on their land? -
Opinions please on this quote for substructure & drains.
Mr Punter replied to Tony L's topic in Foundations
Will the water table mean you need to make special provision to for drainage under the slab? @nod had a soggy site on and laid concrete to falls under the beam and block. -
Is that plus fees, prelims, service connections, scaffold, welfare, insurances, warranty etc?
It will be no issue with a packaged pump station.
Low transmittance glass for skylight
Mr Punter replied to Bancroft's topic in General Construction Issues
The condition is a matter for planning, not building regs so it will not affect signoff. It is very unlikely to have any repercussions if you ignore it, as long as you submit details of what you intend to do and have those details approved in writing. -
Unless they condition that the blackout blinds are drawn at night the planning condition is nonsensical. -
OK. Maybe you should prioritise getting the house safe and weathertight. You don't need to inform planning. Once you have commenced you can take as long as you like or choose not to do it at all. If there are structural alterations, like walls taken out and beams inserted, these will need to be given the all clear by Building Control. They should be fine with you reinstating what was there. Get them round and discuss it.
Standing Seam - Cold Roof Ventilation
Mr Punter replied to SelfBuildSmurf's topic in Roofing, Tiling & Slating
- 1 reply
Block and beam for timber frame aiming for passivhaus
Mr Punter replied to Barny's topic in Timber Frame
I don't see how you can have any timber frame where the flush patio doors are, as the frame needs to be 150mm above ground. All you need under the doors is something rot proof with good insulation that is strong enough to support them. -
My word @vik2001 what a situation! It seems you have got planning consent, your neighbour? did some ground works, you had a falling out, you have not got the funds to finish the job? But you are asking questions as if you plan to complete the work? I think if you give us a straight up version of where you are and what you want to achieve you could probably get some sensible answers, otherwise it sounds a bit spammy.
Yes if it is a new build and on the entrance floor building regs require it. Part M
38 x 89 @ 600 ctrs and 9mm OSB is fine. Nail the OSB @ 300 ctrs. Use treated timber if you want it to last.
Is this cable dangerous/or am I just stupid?
Mr Punter replied to Andeh's topic in Electrics - Other
Perhaps a bit silly to cut the wire. I would be pissed off that the timer doesn't work and that seems the main point. Just ask the builder or sparky to get it sorted. No need for WW3. -
@Pocster! Quick! A nibble!
Is there a loft you can get into to inspect?
Robin Clevett the youtube chippy likes to use Cutwrights for this sort of thing. Maybe give them a go. They are well regarded.
Buying a house without a new build warranty
Mr Punter replied to oksleator's topic in New House & Structural Warranties
I think your broker has it right. Although others will say that a warranty is not worth the paper it is written on, the value of a new house can be drastically reduced without one.
