Mr Punter
Getting planning officers to hurry up
Mr Punter replied to Drellingore's topic in Planning Permission
Have you seen any responses from consultees? The planning officer will often wait for all these before they write their report. It may be worth emailing her to establish if she is likely to support your proposal. Forget the 'escalated' bit as it is inflammatory and will just piss her off. Same for the Ombudsman complaint. You need to play nicely. -
The top half of the flashing should be under the tiles, not over them.
How to handle a dispute with a Contractor?
Mr Punter replied to Mulberry View's topic in General Self Build & DIY Discussion
What drawings were you working to? Did Velux supply a detail for the zinc roof covering? -
If that is an uninsulated concrete floor you may want to consider a new insulated floor. Otherwise, some levelling screed.
Allowing for Insulation up to frame in a stone building
Mr Punter replied to mickeych's topic in Windows & Glazing
A drawing may be useful. Is it stone with insulation behind then a frame / blockwork? Is it new build or conversion? -
Renovating 1900 house. What keeps up this landing?
Mr Punter replied to Gina_Violet's topic in General Structural Issues
You can't always tell how something is supported until you dismantle. The spindles at the end are different, suggesting the return balustrade is not original. Nothing insurmountable here. Is the end corner of the landing wobbly? -
Block extension with external floor level above internal
Mr Punter replied to lookseehear's topic in Brick & Block
You will need to treat the room as a basement. -
Would it work if you cut the zinc down a bit and dressed another material to act as a flashing, like a single ply membrane, over the top of the upstand and down over the zinc? -
Well that is a very ambitious project! Good luck.
To bolt or not to bolt into concrete lintel?
Mr Punter replied to Rick734's topic in RSJs, Lintels & Steelwork
I understand you would cut a slot in the mortar bed, clean it out, gun in fresh mortar, dip the tangs of the hanger in the mortar and insert. Masonry hangers don't get nailed down through the top. -
By no means a disastrous sum. Looks the biz.
Could you use some masonry hangers onto the top of the lintel and lose the ledger plate? -
They do look very good though. Dare I ask the price?
Underneath the doors the haunched concrete makes no odds. No water is getting down there at this stage. I sometimes just omit the inner leaf under doors. Where there are not doors, on site the haunched concrete fill gets filled with mortar from the brickies and sometimes bridges the cavity. Looks good on the drawings though!
They tend to be fairly standard but sometimes you may want to include neighbouring buildings for context elevations etc.
Fixings for hardie backer to masonry (concrete) wall
Mr Punter replied to markharro's topic in Wall Tiles & Tiling
You may find it easier to use Wedi / Marmox type board as it is much lighter and easier to cut and fix. -
If there is a warranty try the warranty company.
I could be if they have been leaking and made the soil weaker in that area. Get the vendors consent to roll back the carpet. Check the concrete / screed for damage. Tap it all over to see where there are voids. Double check gutters, downpipes and drains as well as water main.
Water installation quote. Seems excessive.
Mr Punter replied to flanagaj's topic in General Self Build & DIY Discussion
It looks like they could do all the work from your side. -
Open plan conversion - load bearing wall?
Mr Punter replied to Jduncan's topic in General Structural Issues
Standard timber frame kit is studs at 600 centres and no noggins. Top and bottom rail plus connecting plate at the top. The noggins in the pic are for wall or tall units. OSB is for racking and strength. Amazing how a sheet of 9mm OSB stiffens a wall.
