Mr Punter
Taxes! CIL, CGT, VAT
Mr Punter replied to Antz99's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Hello @Antz99 and welcome. If you sell the plots to others you can take the money free of any tax. This is 100% the course I would recommend unless you have lots of experience and funding. If you choose to build yourself or get others to do this for you, you will be a developer and tax will be due on the profit. Setting up a limited company, bank accounts, registering for VAT, CIS, obtaining appropriate insurances etc is a big undertaking and requires a large amount of paperwork. In any event, there is no VAT on new build. -
Feb 13th Insurance, Warranties and Building Regs
Mr Punter commented on LSB's blog entry in Little Stud Barn
Martin Goodall's planning blog has a few references to the 3 year class q rule: http://planninglawblog.blogspot.com/2018/04/class-q-revisited.html -
Yes, with normal planning consent, once you start it is locked in forever. With class q it must be completed within 3 years. Now you have the class q it may be that your council would look favourably at a full planning application, so you could just do the work in your own time. -
Plywood, orientation of maximum strength.
Mr Punter replied to epsilonGreedy's topic in General Self Build & DIY Discussion
The ply orientation will not make any odds. You could use OSB if there is no ply about. Any glue will be OK or none if you don't have any. This is prob mostly a detail that get omitted but your drawing looks fine. Get on with it before someone felt and battens and you can't get to it. -
There are rooflights that do not need an upstand. Velux do them now. There are cheaper ones out there too. As long as the flat roof has a decent fall you will be fine. Framing out larger openings is not too expensive. Just go for what you want and see what the cost is. It normally costs nothing to get quotes.
I am afraid you are mistaken. The approval will not contain a condition on completion as that is taken care of in the law. If you don't believe me, ask a planning officer or planning consultant. With normal planning consent (not class q) you can take as long as you like, which is what your friend did. Please get proper advice on this as it could cause massive pain later. -
Often the planner's arbor person will just look at Google Earth, see there are no trees and not impose any condition. You should be able to deal with this in the Design and Access statement.
It is very important that @LSB understands that their development MUST BE COMPLETED by 7 July 2023. They are suggesting it may take 5 years plus. They may want to contact their planning department to confirm. -
Self Build Quote of the Day
Mr Punter replied to Triassic's topic in General Self Build & DIY Discussion
You offering? -
I have makita dhs680. Very good.
The office to resi pd is the same. You have 3 years to complete it. Here is someone looking at a class q where the time limit has expired: -
https://www.theguardian.com/environment/2021/feb/16/home-wood-burning-biggest-cause-particle-pollution-fires
If this is under class q, the legislation states (my emphasis) "(3) Development under Class Q is permitted subject to the condition that development under Class Q(a), and under Class Q(b), if any, must be completed within a period of 3 years starting with the prior approval date." This is the law, so will not be a planning condition. -
Planning Permission before sale?
Mr Punter replied to Mulberry View's topic in General Self Build & DIY Discussion
I am not convinced that planning consent would add much to the sale value and if the prospective buyer does not like the scheme they may feel they are paying extra for something they don't want. -
Looks really good. The stairs are much bigger than needed. The WC could go back a bit. This would give you a more generous entrance hall. If you don't think you will use the garage much you could just exclude that bit.
Ace Ventura: The Wilderness Years
How to fix a breathable membrane to a block wall
Mr Punter replied to GaryM's topic in Brick & Block
Stainless staples from a staple gun. Don't choose a windy day. Get the cladding on soon after. A lot of the better membranes have tapes to join which will also help keep it in place. -
It looks like it just needs scraping back and filling with something like https://www.toolstation.com/toupret-touprelith-f-exterior-masonry-repair-filler/p35114 Is this from one of your filthy scumbag slum hovels luxury HMOs?
I understand that the real life performance of the multi foil type products is a mile away from the claimed u-values. Also, these products can often be very flammable. Get a sample and try it with a lighter.
We have slam shut doors and recently a neighbour could not get into their house, as the lock failed. The houses are in the middle of a small quiet town. After a couple of hours the locksmith gave up and we broke a rear triple glazed window. to gain access. It was float glass for the outer 2 panes and safety glass internal. We made a significant noise and it was at about 9:00PM. The next door house noticed, but nobody called the police.
If you can get enough ventilation use a 12" petrol disc cutter with hose attached to do the vertical cuts, then SDS to create the pocket. If the foundation is a decent width you could just build some 4" blockwork which would be much simpler.
The likes of Velfac and IdealCombi do trickle vents that are not visible at all outside, and quite neat inside.
If there are only 2 steels you could brush apply or just box in with plasterboard. If it is only a garage I am surprised you need to do this.
Best sliding patio doors - sight lines and integrated blinds
Mr Punter replied to Happy Valley's topic in Windows & Glazing
The lift and slide type doors seem to be really good with large openings / heavy sliders. -
rate my ladder modification
Mr Punter replied to Dave_Watts's topic in Lofts, Dormers & Loft Conversions
I sold the other one as well, just because I did not really have the space to store it. At the end of a project the lockup just fills up with stuff.
