Mr Punter
Swap the latch out. That is not acceptable. It should not put up much resistance to latching. Does the handle have a strong spring?
Where we are UKPN do not like internal meters and they will not accept the supply mounted on a post. The simplest way to deal with this is often to mount a kiosk as above and run ducting to your proposed permanent location to allow you to run SWA from the kiosk. Kiosk just contains service head, meter and switch fuse, to eventually connect the SWA but in the meantime just a site CU. You will need an earth spike when using as a temp supply.
If you run resilient bars at right angles to the joists you will get a nice flat ceiling, vastly improved soundproofing and only lose 18mm ceiling height.
There is a fair amount of work in automatic gates. A specialist firm may be a better bet than DIY.
Is the entrance door a 'first fix" item?
Mr Punter replied to Dreadnaught's topic in Doors & Door Frames
I have installed temporary front doors in the past. 18mm OSB and 100x50 frame. You could add a lock. Leave the permanent until you have finished plastering / rendering. -
You can get polythene temporary downpipes as well. They tend to flap around when it is windy though.
Dealing with hold down straps fixed to studs
Mr Punter replied to Omi's topic in General Construction Issues
What a pain. I have not seen this done on TF before. You will need to put in some extra studs to fix the plasterboards. You could rip down some thin ply or hardboard for the rest of the studs and the top and bottom plate to bring it out level. -
Neighbours soakaway under my driveway
Mr Punter replied to AmKal's topic in Party Wall & Property Legal Issues
You really want the soakaways to be at least 5 metres from the buildings. -
Could you replace with interlocking black clay tiles and in-roof solar panels? The current roof looks knackered.
Inspection chamber
Basement Concrete Pour - Thoughts on this...
Mr Punter replied to Internet Know How's topic in Basements
You have got 24 corners in that basement. That must make the formwork and reinforcement a challenge! I would leave it to the contractor / designer to decide on how many pours are required. -
With a panel you will be into a maintenance contract to get the thing serviced. I have an Aico detector in every habitable room, plus landings, so 11 sensors, plus a sounder on the roof terrace and the TEST/HUSH switch. It is very simple to swap the sensor type over if, for example, you change the use of the room.
re roofing slate hooks Vs nails ?
Mr Punter replied to levelblue's topic in Roofing, Tiling & Slating
I think you need at least 20mm into the batten. I prefer hooks as the slates don't rattle. -
If you have firm proposals for what you want to do it will be possible to spec the steels. I had someone online spec 3 steel beams at a cost of £200 plus VAT. Included bearing details and calcs.
Small claims for metal roofing defects?
Mr Punter replied to DragsterDriver's topic in Party Wall & Property Legal Issues
Get 2 or 3 quotes to replace it. Ask them what they think of the job. Bear in mind worse case you could end up paying twice, plus court fees and expert witness. Best case you get the job done correctly and just a bit out of pocket and ball ache. -
I guess you could finish the insulation then fit some cement board / render carrier to the reveals and render to match existing, or a cavity closer, stainless EML and render onto that.
The lift and slide type seem pretty good and heavy duty.
It certainly isn't pretty and some is decidedly rough. Was the substrate all good? I looks like some cables etc are showing through but the damage may have happened elsewhere. The court will take an age. How annoying! Is there an amount of money you would settle for? -
Sanding concrete slab before 100mm insulation?
Mr Punter replied to ashthekid's topic in Floor Structures
I very much doubt it is 20mm. Try stacking some pound coins in the deepest part of the puddle. A pound coin is 2.8mm thick, so the puddle would need to overtop a stack of 7. -
That is so well detailed. Both the views and the house are inspiring. You should be proud of yourself!
How you have done it looks good.
Anyone identify this door handle manufacturer?
Mr Punter replied to Bemak's topic in Doors & Door Frames
Eurospec
