Everything posted by jack
You can also run UV sterilisation.
This is such an exciting part of the build process. I hope it goes well for you. I think it'll be really satisfying assembling all those blocks - it's like the biggest Lego/Ikea project ever! I hope you'll be disinfecting the water before using it in this application.
You're welcome.
You know they're doing this, right?
You replied to a comment about it becoming cheaper to recycle lithium by saying: That is, you are way off point. Feel free to have the last word - I'm out.
Yes, the way we consume things is unsustainable, but the rest of your post is completely off point.
That's hardly the same thing. Used lithium is still fundamentally lithium. Used nuclear waste is an entirely different set of atoms.
That's the current situation - as you say, it's a finite resource, which means it will ultimately become more difficult and expensive to extract. The rising price will push research into recycling, so that will become cheaper and more efficient. Of course, by then, we may have other storage possibilities that reduce the demand for lithium batteries.
An ASHP is much, much cheaper than ground source. For what you're trying to achieve, you'd be buying the smallest possible unit. You can probably get something for £1700-2000, depending on brand (you might get it cheaper if you're willing to go the ebay route). Installation isn't too hard, and with an installation this size you can probably avoid a manifold + pump (etc) and have the ASHP drive the UFH directly. I do worry that even the smallest ASHP will be so oversized that it will be cycling on and off a lot. Edited to add: ASHPs are fugly, for sure, but usually you can tuck them out of sight. The issue you'll have with your situation is that you can't put it at the back or side of the building, because there's no space. You could put it at the front, but you'll need some form of screen to camouflage it. I wouldn't worry too much about noise: if you're using it, the doors/windows will be closed, and decent inverter-driven ASHPs really don't make very much noise, especially when they aren't being driven very hard (as would be the case with your setup). Given how low your heating requirement will be, I'd really think hard about whether it makes financial sense to go for such an expensive heating option for a space like this. Alternative idea: @TerryE plans to use an ASHP with UFH, but is presently experimenting with a Willis heater to get a feel for how much heating he actually needs. A Willis heater is basically a standard immersion heater in a sleeve, which heats water as it's pumped past. It's incredibly cheap and simple - eg, here's one for less than £50. You'd need to add an UFH pump to this, but it's still a lot cheaper than an ASHP. They're very reliable, and if it breaks you can buy a replacement immersion heater off the shelf for peanuts. In comparison, we had a pump go on our ASHP after less than three years and that cost several hundred quid to replace (had to replace a circuit board and pump together). In your situation, I'd consider a Willis heater driving a radiator or underfloor heating, and wiring up (but not yet fitting) provision for an air conditioning unit that can be retrofitted if you find it regularly getting too hot in summer. You could spend the money you were going to spend on an ASHP on better insulation (as mentioned above, timber frame is definitely your friend given the space constraints), which will further lower your energy requirements. Pay attention to shading so that you maximise gain in winter and reduce it in summer.
Our plumber nearly choked when I told him we were considering a 5-6kW unit for our 290m2 house. He wanted to install a 15kW ASHP as a minimum. His main concern was how cold the house would get during the 1-2 hours that the ASHP would be heating the cylinder early in the morning. In reality, it takes something like 24 hours for the house temperature to drop by any significant amount!
Absolute worst case, some form of resistance heater can always be employed to supplement the ASHP output on the very coldest days of the year. For example, judicious use of a fan heater would be a low capital way of topping up any shortfall. By way of example, we got by through all of last winter with a 1.5kW column heater in our kitchen after our ASHP packed up. I should add that this was the only proper heat source we used to bring the house up to nearly 20 deg C from the 14.5 deg C it reached while we were away for three weeks over Christmas 2017. Sure, I would have preferred parts of the house to be warmer at times, but it wasn't the end of the world.
Comfort cooling MVHR
jack replied to AliG's topic in Mechanical Ventilation with Heat Recovery (MVHR)
We have the same. Wouldn't be without them, although I don't bother with the solar tracking function. As for light, I don't generally close ours fully. You only need to stop the direct light, which is nearly always achieved with the blinds partly closed. Enough reflected light still gets through to light the room. Nothing keeps the heat out better than external barriers in my opinion. Our bedroom faces east, and unfortunately it's the one place we should have specced blinds but didn't. We have thermal fabric up but it gets hot and radiates into the room. I wouldn't rely on it as a way of keeping a room cool if it gets direct sun. -
That was me on the weekend (minus Faye). Great weather to be up in the mountains having a cold one.
Find me a better selfbuild forum on the web. I'll wait...
What is this bit called and where do I buy them?!
jack replied to divorcingjack's topic in Underfloor Heating
That's a child, not a "blending thing" you nutter! It's an odd thing to have on a cylinder though, I agree. -
I hope you don't mind me being honest, but I think it's getting worse rather than better. This looks like three or four houses chopped up and put back together One thing that this revision emphasises is the fact that on the right, the upper storey overhangs, but on the left it's set back. Then the front bit is completely different in style but partly merges in due to the roofline. At the moment, there are random planes at all sorts of depths in the front elevation. Try to think of the design in terms of intersecting volumes - that might help resolve things.
Yes, but it still has the problem of one roof merging into another: I think it looks strange, especially with the lack of symmetry as mentioned by @ultramods I think you may also struggle making it look as neat as this in real life. For example, how will you blend ridge tiles into the merged portion? I think it'd look better if the roof over the atrium were clearly higher or lower than the roof it presently merges with. It's achieving that without fussy joints that may be a challenge, and that's why a flat roof could potentially be a solution. If it's south facing, you really want to be thinking about solar gain control. Fixed or moveable slats might be an option. External would be best from a functionality point of view, but will likely be more expensive and visually intrusive.
Beat me to it, I agree. I do like the way the double-height bit in the middle comes out from the rest of the house, but it doesn't (to my eye) work where its roofline meets the roof to the right. You could also consider whether having a dual pitched roof over the atrium might work - could be a bit fussy getting it to sit with the rest of the roof though. To my eye, the windows under the dormer look like they're too far to the right. It think they might look better moved to the left to leave some space between them and the double-height section. Not sure how that works with the dormer above. I like the mix of materials, although I'm not sure about the cladding to the bottom left. To me, cladding feels lightweight, and shouldn't sit underneath heavier-looking construction. I'm not a huge fan of the wide roof over the dormer on the left. I see why you've done it in terms of pitch-matching, but it draws more attention to itself than I think is ideal. Overall though, it's a great start - fantastic improvement over what you're starting with. Oh, and before you go too far, have you considered solar gain given how many windows are being introduced to this elevation?
Don't forget to pay that bill!
jack replied to epsilonGreedy's topic in General Self Build & DIY Discussion
Bet you a million quid he "unbuilt" a hell of a lot more than he built for £600. I don't care how angry he was or how unreasonably he was treated, what he chose to do was stupid and reckless. -
Warning about MVHR cleaning/maintenance
jack replied to jack's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Ah, same as ours then (I seem to recall reading once that the heat exchanger is common across a lot of these units). I did give it the once over, but I suspect it could do with a more aggressive clean at some point. -
Would you want to be a customer of his though? What an absolute waste over £600. He hasn't hurt the people who actually owe him the money, and now risks a criminal record (assuming he hasn't got one already) and the cost of repairing the damage. -
Whatever you use, it needs to be closed cell. -
I remember reading about that or something similar. It's absolutely critical that these things are maintained. I was surprised to find that the heat exchanger on our Brink unit is riveted to together, so can't be taken apart for cleaning. I'm sure I remember reading about at least one person (@Bitpipe maybe) who was able to take theirs apart and wash all the individual plates. I may look into whether it's possible to do this by drilling out the rivets and replacing them with some other form of fastener.
