Everything posted by jack
Presumably to counter the fall that already exists? We're shortly going to be making the same decision as we have a large EPDM-covered terrace on top of our garage that needs covering. Currently thinking slabs and adjustable pillars - not sure! I won't be starting it until I've finished the balustrade on the main terrace, but sure, I'll take pics as I go along. Thanks Peter, they look good. I'd already found CFS but will look into East Coast as well. For those asking about balustrades, we used Elite Balustrades. There are several mounting options, and it's all DIY. You might want to get your BC officer to confirm he's happy with whatever option you plan. Our BC officer didn't ask for details beyond MBC's engineering drawings. The architect had used Elite's mounting systems before and was asked for engineering calcs, which they had done pretty cheaply by an engineer. We have Resitrix (a high-tech EPDM and modified bitumen based covering) on our roof and terrace. Although I believe it's crap installation rather than the product's fault, having been through what we've been through I still wouldn't touch an EPDM-based roof covering with a barge pole. I'd go for fibreglass if I were doing it again. From everything I've read recently, it can be made as robust as you want it to be. The two balconies we plan to fibreglass are quite small, and off bedrooms, so won't get much foot traffic. Thanks for that. Will look into multi-layer costs. From further research, it seems OSB3 is the only recommended substrate for fibreglass.
Hi all Made great progress today on the rails that will hold the frameless glass on our balcony. It's so nice to be actually getting some bits and pieces done after so long! Not long now and I'll be in a position to line and finish the balconies. At the moment, they're just open joists. We've been through several iterations with how the balconies will be finished. At one point, we were just going to put open decking on the joists and allow water to drain through. In the end, I've decided instead to fibreglass them. Very little rain gets in - there's a 1.1m high glass balustrade, an overhang, and sides, plus both balconies face away from the prevailing winds and weather. I've therefore decided to just have a small discreet drain with only the minimum required fall towards it in case we ever have a massive storm from exactly the wrong direction. I was considering buying one of those flat-roof kits you can buy by the square metre. Before I do so, however, I have a couple of questions: - Are such kits much of a muchness in terms of quality? - It seems standard practice to use 18mm OSB3 - any better alternative? - Tips for generating the falls to the drain easily? - Any recommendations for suppliers? - I'm considering using the topcoat as a wear layer. I understand that you need to take this into account by using thicker fabric (600g) or doubling up on the standard stuff (450g), plus for grip I need to add something like slate granules to the topcoat. Again, any thoughts on this approach versus perhaps building decking on top? - Any general tips or tricks I should know about DIYing this? @SteamyTea, am I right in thinking you have some experience in this area? Thanks all
Welcome Dave. What general area are you in?
Dodged a bullet yesterday...Kitchen company ceased trading
jack replied to IanR's topic in Kitchen Units & Worktops
I don't think most people in the UK have any idea of how seriously expert impartiality is taken by the courts, possibly because they assume we have a "gun for hire" situation along the lines of what they see on US TV shows. I've had bits and pieces to do with very large-scale (tens to hundreds of millions) litigation, and the extent that barristers and solicitors go to with their experts to ensure that absolutely no leading or coaching takes place - or even the possibility of this being alleged - is extraordinary. I'm about to go through this with the people that installed my roof and you're right, it's really frustrating how much effort I need to put in knowing I won't get anything for it and the likelihood they'll pay up when faced with the evidence rather than go to court. To try and offset this, I'm now claiming for every penny I think is reasonable, including a price reduction due to repeated failures to fix the same leaks. -
Pretty, but is it efficient?
jack replied to ToughButterCup's topic in Energy Efficient & Sustainable Design Concepts
Oh, and that doesn't include "local transport, foundation and installation". Presumably add another couple of thousand quid, at least, for all that. So it's as good as something that costs less than a third the price? And has a lot more to go wrong with it in the future? Where do I sign up? -
Shame they're going out of business given their attitude. -
Quick and easy securing of MVHR duct
jack replied to RandAbuild's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I used strips of left-over breather membrane in some places. Very strong, but easy to staple-gun. -
How did you get the kitchen? Did they offer to let you take it, knowing they were going down the tubes anyway? -
Our ASHP instructions said that fitting of a bypass valve was compulsory.
Drying Towels in an MVHR fitted bathroom
jack replied to TerryE's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Well clearly it can't be done now, and what's more it's Jan's fault! Good luck with that argument! No. One of the larger errors we made when building. -
Founds in.... and lessons from Buildstore.
jack commented on curlewhouse's blog entry in Sips and stones may break my bones...
What a pain. Do you know why the building society doesn't accept direct applications? -
Well no-one in my house (except me) does anything other than maximise the wetness of the towels and bathroom mat, despite my efforts to get them to stay in the shower for just a few seconds and get the worst of the wet off first. I do the "hand blade" trick you talk about (thought I was the only one!) We've gotten into the habit of hanging our towels on the balustrade outside the bathroom, and they dry completely in short order. I do know that the floor mat gets sodden and really doesn't dry out properly, but that's because it's usually so wet that I need to hang it over the edge of the bath. As I said though, 3 out of 4 occupants do their utmost to saturate it with every use, so your mileage may be different. I'm slightly concerned that the towels won't dry as quickly when they're hung in a more enclosed space inside the bathrooms. Will need to wait and see on that one. -
Exactly. Anchoring with inflated initial price, large reductions in several "one-off" tranches, time-limited offers. I can't stand this kind of crap, and refuse to buy from any company that uses it.
I believe so, yes. It would have been about 15-18(ish) months ago. I don't remember exact pricing, but I was very surprised given what appeared to be the amount of work and materials involved relative to, eg, a kitchen. In fact, I did wonder at one point whether it was feasible to get wardrobes from a kitchen company!
We had the same experience. While made to measure, these are unlikely to be "bespoke" in any real sense. You know that the fitter will be in and out in a day (budget a generous £400 for his/her time, including paying the fitter and profit to the company). You're therefore left with them saying that at full price there's £15k worth of materials and labour in the units themselves? Unless the doors are made of solid gold, this is a joke. Even at nearly £8k, they seem to be suggesting that there's over £7k worth of materials and labour in these units. Crazy. I only wish I could say that this sort of pricing was uncommon. I always said I would never have Ikea furniture in our new house, but we ended up getting wardrobes for the kids' bedrooms from there because the cost of even really basic "bespoke" was 3-4 times higher than Ikea. This is for 2x3.5m straight runs of wardrobes with one set of drawers in each, and absolutely no special materials (eg, exotic veneers). For our bedroom I plan to pay a chippy to come in and do it on a day rate with me supplying materials.
Too late for you, @TerryE, but for others who might be comparing the two, this is my experience as well. We went for the Wilo-based UFH set from Wunda following probably too much research trying to compare it to the Grundfos equivalent, and I'm amazed at how quiet it is. Our house doesn't have a lot of background noise, but even in our small plant room it's hard to tell whether it's operating when I have it running at about 40%. If only our Immersun unit were as quiet at full load!
Que? Are they saying that if you took the fence down, planted the hedge, then put it back, you'd be fine? I can't recall whether you've said, but has your building been signed off?
Controlling underfloor heating in passive house
jack replied to dogman's topic in Underfloor Heating
Feedback from an unintentional experiment: We had a leak in the UFH in one room (downstairs study). The rest of the slab is treated as a single circuit, heated by an ASHP. I haven't managed to find time to repair the leak, so we've had an entire winter with the study effectively unheated. While the study floor was noticeably colder than the rest of the house, subjectively the air temperature hasn't been all that much different. I think part of this is the fact that the house temperature isn't actually all that high - we once reached an accidental peak of around 24.5C when experimenting with heating, but more generally we spent winter drifting between 20-22C. -
If the frame gaps are consistent, why would these all be (badly) hand cut? Surely you'd set a table saw up, or even a circular saw and straight-edge, and spend some time up-front banging out what you need at consistent widths with straight edges? It's difficult to know with this one. "Acceptable" probably means something different to us compared to the average British builder. One trick I did use once or twice where we weren't happy with trades was to go back to the manufacturer's instructions. If they say things like "cut with a straight edge", "leave no gaps" and "interference fit is important", then you have some objective evidence to beat the builder with.
- 30 replies
- 2
- timber frame
- insulation
(and 2 more)
We were lucky(?) - the hotel they were staying at wouldn't serve them breakfast before 7, so they were never at ours before 7:45!
We too had someone from the OS turn up and survey our property.
Do you think that these are the offcuts from the layer behind?
- 30 replies
- timber frame
- insulation
(and 2 more)
Nice casting from what looks like good brass, sharp machining... must be your plumbing skills!
Sorry, is it like this everywhere or just in a couple of sections?
- 30 replies
- timber frame
- insulation
(and 2 more)
Objections: the best invalid objection you've heard
jack replied to ToughButterCup's topic in Planning Permission
We took an almost identical approach, and our result (replacing a tiny bungalow with a large house) was very similar to yours, except that ours didn't end up in committee. We were quite surprised by that given how modern the house is compared to those around it. Of course, had one of the local trouble-making councillors got hold of it, the story could well have been different. I hope we'd have won in the end but I'm not sure whether we'd have had the appetite for another two years in a tiny damp bungalow while we appealed.- 25 replies
- planning
- objections
(and 6 more)
