jack
    41
Everything posted by jack
  1. Well don't keep us in suspense, how much smaller should you make them when there's UFH?
  2. Ours was the same. Point blank refused to accept that a 5kW ASHP would be sufficient. He wanted to install a 14kW unit! From memory, his concern was that the house temperature would drop during the couple of hours that the ASHP would be in DHW mode each morning, and that the ASHP would struggle to catch up with that loss as the day went on.
  3. Has always worked fine for me.
  4. You definitely have the right attitude. I'm not for a moment suggesting you shouldn't research the hell out of things. If nothing else, you'll be better informed when things do go awry!
  5. I truly, truly hope that's the case, but having been there, I can guarantee that there will always be unknown unknowns, no matter how much time you spend researching. I took heart from the fact that professionals who've done this every day of their lives for 20 or 30 years still overlook things or get things wrong. It's all about how you (and they!) bounce back from the inevitable mishaps. And welcome!
  6. If you want to cool the slab, an ASHP is probably the only viable off-the-shelf option. I suppose you could provide the wiring and plumbing for such a unit and decide after you'v lived with it for a while whether you actually need/want slab cooling. In my experience, the only places that I've wanted cooling during the peak of summer is upstairs. Downstairs was always perfectly comfortable, but after long hot spells the bedrooms did get warmer than desirable at times. One thing I'd absolutely build in if I were doing this again is provision for insect screens on bedroom windows. At times last year it was a choice between being too hot and being eaten by mosquitos. Another option would be a fan - I lived in Sydney for years, and found that a simple pedestal fan was fine to make the temperature tolerable enough for sleeping, even during very warm weather.
  7. We have Crosswater Mike taps through a lot of our house. Pretty happy with the quality after ~18 months of use.
  8. Given PH levels of airtightness and insulation, I think it's reasonable to assume that there'll be a short heating period during winter, and an occasional use for cooling during summer (depending on solar gain - we got through last year reasonably comfortably without cooling our house). Between those, there'll be weeks, or more likely months, where the slab doesn't need to be heated or cooled. I'd therefore consider whether to make the system switchable between a summer mode and a winter mode. Given you only need to switch it twice a year, a manual switch would be fine. It might be as a simple as routing a call for <action> to either heating or cooling, depending on the switch setting. To be honest, you might not even need this given the way this sort of house reacts to changes in temperature over the year. Set up properly, I can't see a situation where you'd be calling for (floor) heat and then wanting cooling within hours or even days of that.
  9. I should add, the sinus problems that have plagued me through much of my adult life have largely gone away since moving into a house with MVHR.
  10. I've lived in a house with MVHR for over a year now and would never be without it. In your case, I'd be slightly concerned about how late the decision to add it is being made. Do you have a location in mind for the unit and associated manifolds? Is there space for you to run ducting to all the required inlets and outlets (as a minimum, usually at least one extract in each bathroom, the kitchen, and utility room, and one supply in each bedroom and reception room)? Where would your main inlet and outlet (through the roof or an external wall) go? These are non-trivial questions, but need to be given a fair bit of thought given the point you're at now.
  11. These things work, I believe, by running a match filter on a code output by the laser, and adjusting a time offset until the match filter confirms it's locked. The distance is worked out from the time offset (=the round trip delay) needed to get the match. The high viz won't affect the round trip delay.
  12. As a guide to longevity, Panasonic in the past has offered a 7 year warranty on ASHPs installed by certified Panasonic installers. Not many appliances give you that sort of warranty, and I think it gives some idea of what they expect from their kit in terms of longevity. ASHPs are basically large fridges. There aren't that many moving parts, and they've been around so long that the engineering is generally pretty robust. We went for an ASHP, but that was largely driven by the lack of gas connection and our speculation that we'd need to cool the slab in summer. That didn't really turn out to be the case in the end, as we just don't have that much solar gain. Do consider UFH pipework in the slab though. Running it for a least a few hours a day (especially when sunny) helps distribute heat evening around the slab. I suspect our kitchen would be intolerably hot at times of the year without this.
  13. Size queen.
  14. Yes. Someone with some sort of clue will be able to tell you how low on the tank you should consider fitting it. The Willis-type arrangement would likely be less of a faff.
  15. Might also be a job for a Willis heater. Bit of pipework involved, but a lot cheaper and easier than replacing the cylinder.
  16. Can't you just retrofit an Essex flange to the existing tank?
  17. That sounds barking to me.
  18. I doubt you'd get by on a non-material amendment, but could you apply for a minor material amendment?
  19. Yes, that's the one. There are smaller through-wall units like this one. I'm sure I've seen counterflow exchangers that are more like conventional through-wall extractor fans, but I can't seem to find one right now. Efficiency is low, but they're cheap, and easy to get rid of if and when you ultimately link the buildings and start using the MVHR in the currently separate room.
  20. Do you absolutely need to connect it to the main MVHR unit? Having long U-shaped ducts seems to be begging for problems. I know you'll be insulating them, but I can't help but think of that Belgian (I think) house that was condemned due to infected earth pre-heat tubes following moisture build-up. At the least, you'll need to consider some sort of sump and drain arrangement (again, I think). My personal preference would be to find a way to ventilate it separately. Is it small enough that one of those in-wall counterflow units would work? Or the Viking House fine wire unit?
  21. So not on the "sod it, the bathroom thread is only a million pages long so what's another delay" basis then?
  22. Have a good time. That sounds like my idea of heaven - my wife might even stop looking at her bloody phone!
  23. Good spot, thanks. I've corrected it. My main point was that it isn't a graph of power.
  24. Bit late to this, but I was away on hols last week. 9 April was our best day since late August last year: (Note: the graph shows Wh per 15 min interval. So, for example, between 12 and 1pm we averaged about 5.6kW) Generation started at 6:30 in the morning and was still going after 7:15 that night. The flattening out between 8 and 9:30 is due to shading from trees beside the house.
