nod
Everything posted by nod
Protec won’t care what you do They never bothered inspecting ours Just wrote the certificate out at the end If you haven’t site insurance you need cover for general public liability and fire and criminal damage Basic We used bukldzone for this
The gaps are normal If the ridge tiles are new they need swapping for ones that arnt chipped Also I’m not sure why they have cement hand prints all over But that needs cleaning with brick acid
You would simply apply for planning permission or Retrospective pp
As above easy to trim to a curve Curve walls in showers look great We do lots in high end homes ? Seriously like look fab with mosaic tiles Some pics as you go will be nice Hoping my wife doesn’t follow this thread As I’ll have loads of my own pics to put up
Thanks our son does tinting and wrapping on cars I’ll get him to add a tint to the glass
Yes same here I think they replaced it with something else he’s done on more 4 Perhaps look out for it on 4
Our friends have recently finished there SB and have this full height window South facing and are unsure how to dress this window without spoiling there view Weve sat in this and the solar gain is going to be a problem Which is making us sure that 3g is a must Who has these tall gable window on here Can this be tackled with type of glass we use Can our friends get blinds to sort this out
Your building control should be pretty clear on this ALL Rooms above ground floor will need an escape Bathrooms are exempt I wouldn’t of though the landing would need an escape either I know I didn’t bother
Does anyone know when the above is going to be on ?
You will have a membrane and slip membrane under your But an expansion gap around the perimeter You can seal the skirting to the floor which should make a good air seal In not a plumber but separate manifolds for up and down will allow you to have different temperatures We have UFH on the ground floor and never use the heating on the first floor as it tends to correspond with the large open hallway As the heat rises and has nowhere to go once up there
PIR insulation in very short supply - alternative plan?
nod replied to dnb's topic in Floor Structures
Varleys are bringing everything in from Germany Might not be a such a stretch to send directly to you -
This is one of the reasons we have diced against Sips and TF On our last and next two While companies are manic busy at the moment Many will go bust when the government handouts stop
You could put some 400 mil dpc against the adjoining wall before compacting the hardcore It will isolate the patio from them Then crack on Remember neighbors are always expert on planing permission ?
While thinking about heating I was wondering if there are any grants or incentives fo GSH
Running 25mm mdpe pipe under slab from 15mm pipe.
nod replied to hotnuts21's topic in General Plumbing
Come on Russ You need to say it how it is ? -
Res bar will do
I’ve just finished the bill of quality for a large housing site (180) and noticed the client has speced paper tape in all angles This as gone a full circle for me 30 years ago we moved from hessian to paper Then fibre tape While convenient Not grey for stopping cracks So much so I used paper tape on our build 3 years on no cracks anywhere I think things are sometimes change without any need
It’s probably worth counter battening the underside for plaster boarding This will also stop any twisting and will help stop floorboard creek later
Ply exposed to the elements wouldn’t last long 18 mil would require 400 centres 22 cabba or similar is the flooring of choice on most I boarded ours then sheeted it with plastic It was left exposed for six weeks without any adverse effect
Parting ways with building contractor
nod replied to Gem77's topic in General Self Build & DIY Discussion
If there is no contract in place You can simply part ways If he thinks there is any money owed He will have to go down the legal route No one cane remove any of the building and doing so is criminal damage Even if you hadn’t paid for it There’s nothing to stop you approaching trades directly They are likely to be subcontractors Site insurance can be sorted out over the the phone quite quickly Good luck -
Site insurance question when using 1 main contractor
nod replied to Dan1983's topic in Self Build Insurance
You do need public liability insurance and to cover your new building As soon as you start covering plant and tools your premiums rocket A basic liability and building cover will be much cheaper Let your builder take responsibility for materials and plant I daughter that he’s insurance will cover materials and tools -
If your looking to sell your house It would be money well spent on replacing the roof
