FuerteStu
Everything posted by FuerteStu
  1. People just assume they can plug anything into a socket and it be OK because 'if there's a problem the fuse will blow'. Nope. Manufacturers instructions will always tell you how things should be connected and there are good reasons for it. Even the correct contactors need to be selected to allow for suitable loads.
  2. For the cost of the works, the gain, and devaluation if the property, why not just sell up and move further out.
  3. It doesn't matter about the size and the make up of the foundations. They were designed to take a small load (shallow wall and windows). It's unlikely they will be tied into the original foundations, which building control will insist upon checking all round. If your digging to expose them, may as well put new ones in.
  4. To me this seems like a lot of work for very little gain. More than likely you will have to dig up the original footings for the porch and put better ones in, you'll need to spend a significant amount on planning and building control, demolition and redecorating for a relatively small amount of floorspace.. For the cost and effort you could gain a single story extension at the rear which would be five times bigger.
  5. The bin test for tradesman Provide a metal bin in their work area and give them a day's work, telling them they're is a bin for their rubbish etc.. If the bin is empty at the end of the day, they don't get to come back. I will not tolerate people who leave half full cans of Monster everywhere. Zero respect for the client will haunt you.
  6. Heavens forbid London ever has to change direction.. Same thing will happen.
  7. "why would someone build this here?" Because there is profit in every stage. It doesn't matter if its needed, wanted or objected to.. If someone ticks a box, someone profits. That city is now a busted ol C-max everyone is afraid to turn the key fully off on. Must... Keep... Turning over.. Or we'll never get going again.
  8. That being said.. He might not have been wrong about the best setup for your house. Just had his own reasons for it. Get more quotes. Be sure of the advice.. Not everyone's right, including me
  9. Things that stood out. His reluctance to believe a house was 3 phase. It shows his tendency to only be installing in 'standard' installs rather than modern or commercial. It shouldn't be something he would be surprised about. He gave you a price, and then a deadline. That's a salesman's technique of wanting you to not think and just handover money. The 'excess straight to immersion' option doesn't factor in the complex variables in modern builds. He's probably used to pushing the add ons for retrofitting older houses. Birds don't worry me. Their nests are seasonal. Rats are a bigger problem and chicken wire does not stop them. Chicken wire is ugly, lazy and cheap
  10. Several things there are alarm bells rather than reassurance. And that comes from someone who was an installer who left the market because of the heavy insistence in sales and profit rather than actual green energy. Get several quotes, get several opinions, then trust your gut.
  11. To me there looks like a serious lack of storage space. Where will the Xmas Dec's go? Linen closet? I prefer my kitchens to be south facing. Much better to enjoy the sunrise and sunset there than have them glaring through bedroom windows If it were me I'd consider having the living area in a top heavy T shape with the sleeping areas split in two on the north facing sides
  12. I was the main contractor on mine (garage and loft conversion). I did everything but the scaffolding and gas. I wouldn't recommend it if you can afford to hire someone to do it. The stress and extraordinarily exhausting work is not healthy.
  13. Needed more duck tape. And less beer as a primer
  14. I had a dip about the same size that I think developed from a small void where a doorway used to be. Evidently is soaked through where I'd sealed. What I did was mark out the low area, 'dink' a rim with a cold chisel so there wouldn't be a seam line, then top up with small amount of self leveling making sure it was smooth into the rim I'd formed with a sponge as it began to set.
  15. Before now I did a jedi mind trick of reducing the width of the panels each one by 10mm to gain the 70mm shortage. Wasn't noticeable from either end 😂
  16. Rather than relatively expensive microgeneration, wouldn't decentralised storage be a better option? With cheaper alternatives to lithium? https://www.euronews.com/green/2024/03/10/sand-batteries-could-be-key-breakthrough-in-storing-solar-and-wind-energy-year-round#:~:text=The hot air is then,container through a heat exchanger.&text=The sand can store heat,in the district heating network.
  17. I think it falls more under the category of 'why would you not?' in terms of regulations. The letter of the law is inconsequential if the risk is unnecessarily ignored. Other laws could be used to prosecute if your actions went against guidelines and caused harm. Admittedly, the regulations are bizarre at times. Ceiling pendants being one of those areas. Class 2 but metal lampshade fitted to the bayonet, step down to 0.5 flex but no protection other than the 10A mcb.. On a device that is head height that typically an untrained person sticks you their hand up towards in the dark to change the lamp not knowing if its on or off. But that's besides the point. A socket in the bathroom will be used by every teenage girl for hairdryers and the likes. It's an unnecessary risk.
  18. Call me a conspiracy theorist, but there is a alarmingly high number of 'needless estimations' and 'accidental prepay metres installed'.. Its almost as if they are benefiting from the additional cashflow
  19. I've seen three island hobs with extraction reliant upon sucking it back into a filter on the island.. All of them end up with a sticky patch on the ceiling where residue condenses. Nice in your designer pad that is hardly ever cooked in, but I've got a family of 5 and we cook six nights a week. Just not realistic to expect it to be practical.
  20. Like this, but 4 together
  21. I've seen people build 'modular' storage from pallets that look pleasing to the eye. 4 boxes that stack on top of each other, self supporting, they distribute the weight as they act like shelving
  22. I prefer my sinks to be window facing so I can gaze regretfully at all the years going by....
  23. What's the time?..... 30 seconds later. Oh I prefer these https://amzn.eu/d/hvrXIKF Although I really think we need to be bringing back "two thirds past" Instead of 40 minutes past.. I like confusing Americans
  24. They were small soffet boards and a door from an old boiler. Not big really, but I think there was a minimum charge for collection. I'd imagine your roof would be more than 50kg, but less than 100.. Just a guess though.
  25. I would recommend doing it yourself. Very low risk, I did a section of cement board in my house, totalled 22kg and the local authority attached for Biffa to pick it up for £90 so long as it was credible and double wrapped in thick plastic bags.
