FuerteStu
Everything posted by FuerteStu
  1. Just finished my stairs and had a similar issue. I ran an 12mm quadrant of trim on top to cover the gap and distract from the square top to Skirting end. Not entirely happy with it, but it looks better than it did and I'm probably the only person that would ever notice
  2. Send him a bill for putting right his mistakes.. Make that invoice the exact same amount of his.
  3. Under my consumer unit (in a cupboard in the hallway) is a 24 port switch. I've routed twin cat6 cables from there to all TV points, to each corner on the house and several other strategic places. This network has its own WiFi. My ISP plugs into this switch and livens up the outgoing connections, I change my isp, I just change their router and there's zero changes to my home network, no swapping WiFi passwords etc. The only thing I've done different to others is my so called 'turn it off and on again' Radial 240 circuit. Next to my switch. It's a spur that supplies the tactical sockets in places that supply. CCTV, router, switch, doorbell, alarm and WiFi. This way, one switch can reboot the entire house. Which makes it soooo much easier if there are any glitches or issues.
  4. In this scenario, I'd question if you actually need it to be done on one ring? What's wrong with doing this in a couple of radials? You could commission them as you go, extend them if needed. Much more flexibility and easier for testing. Rings are a hangup from the days when we only had 4 fuses in the board.
  5. The reason they use a rig rather than a normal drill is the potential for it to lock up and kick. I've seen people seriously hurt themselves with core drilling. You need to keep your drill straight and a firm grip. Use water to minimise dust and cool the cutting.. Use a low speed. I great trick I was showed once was a bottle of water with a slit from a knife carved into it next to the hole. It trickle feeds next to your drill
  6. Or, as @ProDave mentioned.. The permanent live for a smart fitting. Or like my fittings in the hallway and above my consumer unit, an emergency fitting that charges the battery up and when the permanent live drops out, allows an exit route, or lighting over the fuse board to flick the breaker back on
  7. It allows for 2 different switched lives and a neutral (plus earth) in the same cable this can then be bounced to the start of each string of switched fittings, or along all of them and just picking your fittings depending on choice. My living room has two central fittings on a dimmer and perimeter spots along the back and window walls. This gives 3 different moods from the same cable
  8. Second reason is for multiple switching of banks of lights. You can have two rows of spots switched separately from one cable. Helps reduce the number of wires if youre looping in the switch! Just gives you options for an almost identical amount of work and cost
  9. Worked on a job where the plasterer wasn't paid. He turned up a month later after several failed attempts to get his money... And wrote "CNUT" on all the walls with diesel and a paint brush. No matter what they tried to paint over it with, it still showed through. They ended up having to gun it off and reskim.
  10. My experience with this type of trady is to cut your losses and get someone better to finish the job. You'll only end up with more bad work if he's the one left to put his own work right.
  11. Looking at your other posts I strongly suggest you do not attempt something without giving us more information. It sounds like you're trying to do something potentially very dangerous.
  12. What's the circuit? Load?
  13. Depends on the amount of room you have. Could use a Henley Block? https://www.screwfix.com/p/greenbrook-100a-2-x-5-ways-25mm-connector-block/48024?kpid=48024&cm_mmc=Google-_-Datafeed-_-Electrical and Lighting?kpid=KINASEKPID&cm_mmc=Google-_-TOKEN1-_-TOKEN2&gad_source=1&gclid=CjwKCAjwte-vBhBFEiwAQSv_xUAVhV7n_WOmweBhWOWkHzvYnz7pANrZp9MtNGUKJyCp2dLF-kSUTxoCUHcQAvD_BwE&gclsrc=aw.ds
  14. If they are just earth cables could you not use an MET block? (main earth terminal) https://www.screwfix.com/p/ced-4-way-earth-block/12386
  15. As a commercial/industrial spark who spends most of his days working on armoured.. Sleeving (identifying) the cores is just part of the job. Many multi core (more than 5) armoured cables are white core only and numbered. It's always grey (blue sleeved) used for neutral. The phrase 'deneutralise the black'. Was just a way of making people remember. Modern apprentices just say "black is cpc, just like the armour". Heat shrink the damage, live and learn. If you need to bend the cores in future, use the handles if the pliers, not the metal ends.
  16. Have you factored in the protruding nut and plate either side?
  17. Just out of curiosity. You mentioned having speakers fitted, would it be possible to rig up a noise cancelling system? 🤔😂
  18. Delay adds bigger burden. If there was a blanket policy that you couldn't argue or protest against,, things would be very speedy. Making up for a large portion of the cost.
  19. This is exactly what I'm saying though. People are choosing to buy something that is better for the environment (yes I know there are arguments that they aren't better at the moment, but they will be. These are the first steps in the industry and infrastructure) Educated people are changing industry and commerce. Not waiting for it to change. That's how we will change the world, buy buying ethical, but considering the implications of our purchases.
  20. There are bloody good reasons for not wanting to live somewhere which is a very good position for a turbine. It's usually ugly land that is windy! Lol Pylons are a necessary evil. At the minute.. Its why we need more localised generation, rather than national distributions
  21. There is too much 'not in my back yard' accepted in things like turbines. I'd rather see a 50 in one area, and compulsory purchase any houses where people object. If that means a few people upset rather than facing another energy crisis, so be it. As for trump, fingers crossed he'll be in prison before he's elected.
  22. So you'd rather let industry and commerce change your consumption habits, that admittedly will take far too long and do even more damage the planet... Than change your consumption habits that will force industry and commerce to change faster. That's a very selfish and dangerous game of chicken.. What if industry profits its way to destroying the whole human race? What if economics forces everyone into labour camps to feed the rich (more so than it is already)?
  23. Once again you're humblebragging about the fact you've studied the systems that have caused all the problems on this planet. Yet offering no reasonable suggestions about the way forward. Is almost as if those studies have conditioned you to accept them as the only way.. History will tell you that no system stays the same, they will always change. So let's agree that people need educating about the costs of their current consumption and the benefits of a local economies.
  24. I've got the dewalt first fix, which Ive found to be superior to the paslode. Quieter and less time changing the battery and gas cylinders. But I am wondering if you're only fixing 25mm to 25mm a second fix gun with heads that almost disappear might be better?
  25. Are you fixing into battens on the container? How big are they? How are you fixing those? Reason I ask is that I know someone who used 75mm nails to fix 25mm panels to 50mm battens on the side of container, but he didn't allow for the fact that the nail tip protruded out through the batten 5mm.. So by the time he put a dozen nails in, it had pulled the batten off the container.
