FuerteStu
Everything posted by FuerteStu
Containment for fibre... Improvised.
FuerteStu replied to FuerteStu's topic in Networks, AV, Security & Automation
Awesome. Got a draw wire down the length of it that's got a 10mm diameter head with ease. I'll sweep the bend through the outside wall, just chase a section upwards from the penetration. I think this will work way better than 20mm conduit to be honest, as it's a continuous run. Cheers all -
FuerteStu posted a topic in Networks, AV, Security & Automation
So my new fibre line install is going to be 'on a suitable outside wall at the front'.. About 5 metres from my telecoms area with my switch panel. I've spoken to a guy who surveys the install (virgin, not Openreach) and they've said they don't mind a short containment run as long as it's in place in advance with a draw wire. I said I'd do it in 20mm conduit, but I noticed I've got 8 metres of 15 pex Speedfit sitting there doing nothing.. Surely that's a better option right? Smoother interior, no couplers needed? Anyone know of a reason why not? It's going up a boxed in riser that takes my outside tap feed, through 4 metres of loft and down into the IT cupboard. -
All the fun of the TV pattress.
FuerteStu replied to MikeSharp01's topic in Networks, AV, Security & Automation
I've used these in the past for downlighters. They are bloody brilliant as it creates a really solid opening. -
Economics of DIY and Self Building
FuerteStu replied to Gus Potter's topic in General Self Build & DIY Discussion
If you can't swing a few CATs, then we didn't selfbuild big enough! -
7 TVs in the house so far, 5 people.. if only 4 of them are streaming 4k that's one hell of a bottleneck on the WiFi. Hardwired TVs mean less issues with all the other 50 devices. -
I have one 24 port switch in my plant room (cabinet with the consumer unit in the hall).. One day I might get around to labelling it all before I forget what codes I used for all the runs 😂 -
For me it isn't just the immediate benefits and cost savings.. I know that if something goes wrong in 5 or 10 years time, I'll have photos of the work done and a memory of where things are and there's a very good chance I can save myself a bucket in fixing it myself, or at the worst be able to point someone else to exactly where the issue is. -
Doesn't look too unnatural compared to some staircases I've seen.. I built my own because the quotes were coming out insane for mine. But they were an unusual shape and design
I did the garage conversion floor in dry sand and cement mix.. Mixed on the driveway by a volumetric mixer. I calculated I needed 1.8m2, asked for 2 to be safe. Used a laser level and wheelbarrow.. Got it done in about 3 hours. However, the guy must have just emptied his wagon... It was the day before Xmas eve. I had over 2m2 left over on the driveway. Filled up two tonnebags with it and built a ramp to the front door as well.. Had to get a skip in the new year to get rid of it all.. That was the worst part of it all. If you want tips on doing it yourself I worked out a few.
Do we get to name the podcast? I vote for "needs more duck tape"
In my experience, over tightening of bolts is the main issue in metal failure. Not only can it damage the thread on the bolt and cause it to fail, but the abrasion of over tightening can remove the protective layer around it causing another weak point. Torque wrenches are as much about preventing over tightening than they are about tightening to a minimum torque. And don't even get me started on split ring washers and them actually increasing the failure rate of bolts.
Door linings: narrower than the opening
FuerteStu replied to Post and beam's topic in Doors & Door Frames
Ah, so you mean wall thickness.. Mine was a couple of mm either side when I offered up the lining in the garage conversion, and I was tempted to fit it, then Architrave and caulk the gap.. I ended up trimming 5mm off the lining. Much better job -
3/4" to 1" Adapter on outside tap problem
FuerteStu replied to machtucker's topic in General Plumbing
I've got an irrigation setup with similar timer. I used a splitter on mine, which allows me to still use the tap without disconnecting the system! -
Starting my upstairs shower room and toilet.. Blank canvas. I've already got a layout that works, what I'm asking for are any tips and 'things that went wrong' or 'we wish we had'. Relatively small budget, expecting most of it to go on tiles to improve the 'look'. Maybe I'm just over thinking it, but thought I'd post in case anyone had any advice. It's in a timber frame loft conversion, pozi joists floor and ceiling. one external wall. My plans are roughly. Marine ply floor tanked, tiled. Tanked Tile backer walls, tiled. Centrally placed 4" humidity sensitive extractor, flexi to wall in ceiling. Tall Towel rad next to shower. Soil stack exits top right next to WC.
Smart thermostats - Nest thermostat losing many features
FuerteStu replied to JohnMo's topic in Other Heating Systems
Undoubtedly. But accountability is something we should be fighting for. Right to repair it's one thing, right to functionality should be in there too. Perhaps a legal precedent case, the public vs Google. Something sold as smart should remain so for the lifetime of the product (20 years seems reasonable) -
Nothing will change as long as people keep spending money and nobody complains. Time to start drafting letters to MPs -
Whilst I understand that companies projects must eventually be discontinued, if you buy a smart thermostat you don't expect it to be bricked by a company that can afford server space to keep it running. Smart devices should be backed up with a service guarantee for at least 20 years. It should be written into consumer rights. -
Density based stud finder recommendations
FuerteStu replied to BotusBuild's topic in Tools & Equipment
Magnetise some iron fillings and dust the wall with them? That will find your screws quickly -
How much should I respect/trust the central roof beam?
FuerteStu replied to Garald's topic in General Structural Issues
I trust the beam more than that hook. (not a structural engineer) At worst there will be 20kg hanging from that, and the beam can take it, that hook maybe not. How fancy does it need to look? I'd trust a plate fixing with a ring in it. 4 screws are better than one.- 1 reply
I love in a very hard water area. It's cheaper to use salt rather than two tablets per wash. Without that the glasses go cloudy
The only decent WiFi feature of ours is the notification that the rinse aid and salt is running low. And being able to check how long they're is left on the wash from the sofa.
