FuerteStu
Everything posted by FuerteStu
Home Protocols to control COVID-19
FuerteStu commented on Ferdinand's blog entry in God is in the Details
Brass door handles and joinery left alone have been shown to be more effective than regularly changed stainless steel. My advice, put the effort into making your body stronger and more resilient, there will always be variants of bacteria and viruses that slip through the nets. Yes diabetes can make common infections worse, but there are also diabetics who run marathons. -
For me the fridge is the key feature that feels in the wrong place. Everybody talks about the oven-hob-sink being together, and rarely thinks about the 5 trips to the fridge to get things to cook, or the loading of the fridge when you get shopping. You'll want a large surface area opposite it if it has twin doors. We had limited space and opted for a peninsular rather than an island.. Narrower. But between the cooking and dining area, makes an excellent buffet area, or plating up area. If I were you, I'd get your spark to fit a smaller distribution board for the kitchen. Any additional circuits or appliances won't have to be taken back to the main board. You'll thank me in 10 years.
Occasional leak as well as gush through tundish?
FuerteStu replied to Andeh's topic in General Plumbing
I also vote pressure release valve, just changed mine. £9 delivered in 48 hours, 15 minutes to drain down change and repressurise. (not suggesting you do it yourself unless you're competent though) -
I know Pocster will probably just say lube is for wimps, but my door handles are only 18 months on and starting to squeak a little. I think it's the lock rather than the handles, maybe a little of both. So what's best? Oil based? Silicone? Grease? Spray or tub? Cheers in advance
Probably relying on leaking wet underfloor heating somewhere to keep resistance low.
It's possible that's enough damage to the cable to trigger nuisance tripping. The only way to be sure is to isolate the cable and see if the problem persists.. But it could just mean you're isolating the problem that's further upstream. It's a multiple test scenario. There was a stage when the grey pvc on twin and earth broke down and left an oily residue. I think they changed the formula. It was rather tasty to our rodent friends, I've seen them strip off metre long sections, leaving only the inner cores. It doesn't take much removal to trip an rcd if there is moisture in the air, opening a section allows capillary action to trigger conductivity through what can barely be seen. If it was in the live it would just vapourise the water, but the neutral to earth allows an alternative path and the rcd doesn't like that. My suggestion, replace.. And see if it's still a problem, then investigate further.
Assuming the circuit holds, but trips when switched on, it either implies the returning 'switched live' is coming in contact with cpc (earth), or the lamp fitting itself. If its recent, my first thought rather than pest related, would be water ingress. Moisture inside the switch, or fitting. There is also the possibility of the lamp itself causing the trip. A picture of the fitting would be handy to diagnose further
How bad is this brickwork & should I start again?
FuerteStu replied to Tony L's topic in Bricklaying, Blockwork & Mortar
Must have been a Friday afternoon job... -
Just a thought.. But surely at some point it goes into a standard sized pipe. Could you not try and joint to that rather than bodge two standard fittings into each other?
Not sure if that drip would stop the whole system from working. But that isolator valve in closed position might. Can we see the whole setup? Maybe a drawing of what is where?
More fun with a thermal camera; what to conclude?
FuerteStu replied to Garald's topic in Heat Insulation
All I know is, if you hear a clicking sound and see a triangle of laser pointer dots... Running won't do you any good. -
Feedback is irrelevant if it falls on deaf ears. Both the planning officer and myself talked to him about the refused application and he still came back with absurd designs rather than listening...
Over a years delay due to his oversight and refusal to listen to the planning officer. When planning said no the first time, (due to his dormer flat roof design being higher than the ridge) he came back with a ludicrous design that was close to a Dutch barn roof that was also refused, he then drew designs for a standard pitched roof on top of the loft conversion so the end had two gables.. I refused to let him submit those to planning and gave him my interpretation of external after a conversation with planning officer. Which was finally accepted. It was then we discovered just how impractical his original drawings were, and the ones thereafter. There were many issues. The whole project was nearly abandoned. Finally found a good SE and a Posi-joists company who managed to make it work. But by then the post-covid building material costs had doubled.
He'd spanned 6.5m with 225x45 joists for upstairs, with a "possible steel needed" in the middle, but his drawing showed the steel on an internal wall that wasn't structural.
What type of pump do plumbers use to pump out water from a pipe?
FuerteStu replied to Adsibob's topic in General Plumbing
I've fitted two outside taps this summer, front and back. Brass ones with no exposed pipework, just the brass head. I've never bothered with outside tap draindowns before. This place had one already but it will be dead soon.. And my previous two houses had them. I never drained them down either. Have I been lucky where I am (East Anglia), or are you all being extra careful? -
If they are in good condition.. Sell them, Buyer collect. It's not worth the sleepless nights using something you know isn't good enough.
I engaged an architect with my renovation. I seriously regretted it in every way. The drawings I gave him from my own design were virtually the same as the ones that were finally approved by planning. After his three stages and ignoring what planning recommended. (his structural engineer quoted 9k for drawings) He threatened additional fees if I no longer used him, I engaged a separate structural engineer through a family friend who looked at the drawings and said they were impossible to construct. He recommended someone else he knew to adapt my drawings. *IN MY PERSONAL EXPERIENCE* And that of many others, most architects are nothing more than money grabbing conceptual designers.. Artistic types who have very little connection or sympathy to construction or planning. If you get a gut feeling your architect is wrong.. Get a second opinion.
The metal fixings are for plasterboard.. They are designed to grip in a minimum of 9mm, usually 12mm thick gypsum wall. Not a 3mm widen fibre board off a door. The fixings from B&Q state that they are designed for exactly that purpose, I strongly suggest if you're going to use a fixing in the door, to use those.
I don't have any pictures, sorry. It was my old house. A thicker screw with thicker thread will 'bite' Better in the thin material if the door, just be careful not to over tighten. The screw is there to clamp the plinth until the glue goes off. With all glues, most of the strength is in the way it's fixed. Two surfaces rested against each other will fail. If they're clamped, the bond is stronger.
On the 3 kids bedroom doors on the old house I fitted a nice plinth on the back of the door. 4"x 18" with no nails and a couple of thick thread wood screws to pull it tight until the glue set. On that plinth I fitted the hooks. Never had any issues at all over the years and it held lots of coats, dressing gowns, and school bags.
Scotland - Ban on stoves in new build houses lifted.
FuerteStu replied to ProDave's topic in Stoves, Fires & Fireplaces
Probably got a sticker on one end that says [plug in this end first] to make it safe... -
Go around the outside and look for cracks or replaced mortar. Check the corners of window frames inside and out. Feel for drafts around door and window frames. If there are no signs of issues, then it just just be the house was built by someone drunk. Drink, and you'll forget about the wonky house.
