FuerteStu
Everything posted by FuerteStu
"are we being sold the wrong things" - yes. The clue is, that you're being 'sold' them. I buy the things I need after doing my own research and asking people who have the products. I don't ever allow a salesperson to give me anything more than the spec.
Wireless Access Points or Mesh?
FuerteStu replied to YorkieSelfBuild's topic in Networks, AV, Security & Automation
I ran twin cat6 cables to all TV points, to areas where I might have a PC/console, external corners for cameras, to the boiler cupboard and several strategic places for a mesh network (like under the stairs and on top of kitchen cupboards) All of these route back to a switch in services cupboard. I've terminated in all sockets myself, and only the rj45 ends when in use. Only thing I would do differently would be an additional twin cables by the front door that could be for alarm keypad to be hardwired. And possibly one external out the front if needed at a later date. TVs have data hardwired and no aerial. I don't regret this at all. I do regret getting a cheap Chinese Mesh, but they are on the list of easy upgrade if I ever get fed up with having to reboot once a month because the scheduled restart seems to lose connectivity with some devices. -
How to get draw cord or wire down underground 25mm flexible conduit
FuerteStu replied to Spinny's topic in Electrics - Other
String with a couple of knots in the end, hoover, switching it on and off. Use gravity and the wave effect of increasing and decreasing pressure.. Usually works. Replace the string with thicker after you've made it through. -
The more I read about specific TMS, the more I see it as future treatments for all kinds of disorders and mental health situations.. It actually works.
Is it time to start getting creative with kitchens?
FuerteStu replied to Bancroft's topic in Kitchen Units & Worktops
I've recently finished my kitchen and did something I've had lots of comments about.. I didn't have any sockets, spurs or Isolators in the splashback. Instead, they are all tucked away under the cabinets in bench trunking. It allows for future adaptations without redecorating (there are conduit drops from inside to below countertop) I was planning a trim along the bottom so it wasn't even in eyeline, but it barely notices as it is. Makes cleaning so much easier -
Deepen backboxes in block wall?
FuerteStu replied to Andeh's topic in General Self Build & DIY Discussion
The box will be fixed at the back. Cutting out the back will likely make a real mess with a multi tool, as with nothing fixing the box, it will shake free of the plaster and fall to pieces -
Actually that isn't the post that discussed dot and dab fail.. Memory fail..
Dot and dab plasterboard should have a continuous line of adhesive at the top and bottom of the board, and around any sockets and windows. There are posts about this on site and discussions about rectifying it.
I think you have two problems here. A large room with a floor like a sponge for absorbing the heat. Once up to temp it might not feel like it drops too much, but it's going to take a while to get up to temp, not having underfloor heating in it. That seems to be the preferred method to most. The detailing around your insulation at the joints seems poor (see picture). Foaming up the gaps like this would have made quite a difference. I'm guessing the cold spots are from gaps like this, From there it will travel down the walls behind the plasterboard, and put through the sockets.
That's a lot of glass.. That's my gut feeling. What's the detailing around them and their spec?
Won't be able to make it this time.. But I'll raise a glass from home. Have a great night folks
Can't see very clearly, but every quooker tap I've seen recently has had a badly designed and usually incorrectly installed pressure release drain and hose. It's supposed to be set 4" higher than the trap it feeds into, but under a sink that's not usually easy. I've seen them leaking bad air, full up with black mold and all sorts. Can you see what the setup is on yours?
If that's a Quooker tap unit on the left, have you got a picture of the pressure release and drain setup? I've seen those badly configured and leaking air from behind the trap
Personally, I've avoided inbuilt usb sockets since having them a few years ago. Most make a either a high pitch noise or a buzzing that gets worse over time (some older folks might not be able to hear it, but I can). Over time, usb charging has changed, and older sockets charge new devices very slowly. This will carry on I believe.. They'll be obsolete or unusable within 5 years I just put in location based additional sockets, strategical ones that make sense for devices (behind coffee tables in the living room, kitchen counter, bedside table etc). And use a good quality charger with lead.
Do you have pictures of the roof? It still might be possible. Pictures from the outside?
New extension - air coming through electrical sockets
FuerteStu replied to S_P's topic in House Extensions & Conservatories
That's quite a substantial amount of airflow.. I was thinking it might not be the airflow around the plasterboard, but if you had your sockets fed with conduit that opened out into the loft. I've seen that being an issue before. In that case there's wasn't a whole lot to do because there was almost no access to the eaves, but we used the foam earplugs around the cables in the conduit entry, and a different brand of socket face plates were more airtight than the screwfix budget brand that was fitted. -
Next door site.. Very handy. You can use the WiFi, keep an eye on things in terms of security. Have home comforts when on site and keep an eye on the trades. Perfect arrangement!
I'd be tempted to core through after they're fitted.. Leaves less room for error
Never hotswap an rcbo having the neutral fly lead connected though.. They carry 230v potential. Can arc and give you a knock even with the breaker OFF.
Our quiz name was "Cupid Stunts" or "Siri what time is it" The second one was great for finding the cheaters In the pub using their phones..
NR34 for me.. But I have 3 kids and still have rooms to complete. Be a while before I could even think about a social life 😂😂
The thing for me is the sliders, it makes the bus bar teeth safe when disengaged, and covers the breaker terminal when engaged. The breakers clip into the board and don't need a neutral or earth fly lead for their rcbo's I've only ever seen one board with a failure, and that was due to terminals being loosely tightened. The metal and plastic seems much better quality than other brands
Ok so I work on the industrial side of things, mainly 3 phase. But the schneider acti9 isobar gear is the ultimate in reliability and safety for my 2p. The 3 phase boards have a link kit so they can be converted to single phase. So an 8 way board becomes 24 ways It's pricey though. But I guess you get what you pay for. Hager are fair, but unless you keep all the breakers perfectly square, the fronts are a bugger to get on and off without tripping breakers.... (but we all shouldn't be taking covers off live anyways)
'housing association contracts' So the cheapest materials available quickest..
Consider sub boards in the kitchen and garage/shed/outbuilding. Don't be reliant on multiple long cable runs. I've seen kitchens fed with a ring and 6 radials, all dragged through the house to a tiny space under the stairs, just whack a sub board in the kitchen and keep the runs short, it also allows for much easier renovations and additions in the future.
