ADLIan
Everything posted by ADLIan
It’s not the R value that should compared as this is thickness dependant - 300mm of woodfibre will have a better (higher) thermal resistance (R value) than 120mm of PUR! Comparator is the thermal conductivity (lambda value) as this is an inherent physical property of the material and is not thickness dependant. The U value refers to the total build up of a wall, floor or roof. The U value of insulation alone is meaningless. it must have been costly obtaining wood fibre with 3x the R value of PUR, approx twice the thickness and twice(?) the price
As above nothing to do with the thickness of the insulation, problem is the screed. Standard sand & cement screed onto insulation should be at least 65mm thick with light mesh reinforcement (or fibre reinforcement mixed in). The kitchen unit legs may have imposed too high a point load on the screed & insulation but this is unlikely.
Wood Fibre Insulation - Pavaflex/Pavatherm
ADLIan replied to Joanna Susskind's topic in Introduce Yourself
+1 @ProDave From BS 5250 vapour resistance of 13mm OSB is approx 7 MNs/g. Compare to vapour resistance of 0.12mm (500g) polyethylene sheet at approx 250 MNs/g. This would be classed as a (A)VCL - the OSB offers little resistance.- 20 replies
- insulation
- woodfibre
- (and 5 more)
Stroma EPC / FSAP software questions
ADLIan replied to Ferdinand's topic in Energy Efficient & Sustainable Design Concepts
The Standard uses -5 Deg C as external winter temp. Not sure what the other conditions are as I'm not directly involved in this sector. Normally the internal classes are low occupancy dwellings and high occupancy dwellings (there are others but not relevant here). A good PUR manufacturer with experience in flat roofing should have this info and work to this Standard. On the positive side I would imagine the construction would be relatively safe looking at the relative thermal performance of the PUR and mineral wool but proceed with caution! Was the calculation done by the manufacturer? I would expect a product name and reference not just ‘PIR’.- 47 replies
Good news. However that calculation is not in line with BS 6229 on flat roofing which uses more extreme external conditions (as my message above). Internal humidity class may need stepping up (dwelling with high occupancy) to cover worst case scenario- 47 replies
Normally there would not be any additional insulation between the roof joists. If adding something for acoustics keep it low density/higher conductivity mineral wool and ask the flat roof insulation manufacturer to run the CRA with specific reference to BS 6229. Ensure the AVCL above the plasterboard is as 'fully sealed' as possible, it will never be perfect!- 47 replies
I doubt you'd get the insulation manufacturers to support the use of hybrid flat roof. Not covered in Appr Docs or BS on condensation risk. BS on flat roofing mentions hybrid roofs but warns against their use requiring full CRA, under specific climatic conditions, and very careful detailing of the air & vapour control layer, it must be 'fully sealed' (not sure how you achieve that in practice!)- 47 replies
The parapet roof/wall junction you refer to is from the Scottish ACDs. (It is not very detail in one sense in that it is showing a hybrid warm roof construction which is generally not recommended). Note it has a layer of insulation internal to the TF (not just between). If you have this construction then download the Scottish ACDs as all the psi-values will be much better. Note also limitations/constraints on rest of construction.- 47 replies
@Moonshine That document (SAP OCDEA nher) is out of date but does give good info on TBs. Download latest SAP conventions (Sept 19) from the BRE SAP website for current advice.- 47 replies
Difficult to tell. TER looks to be in the right ballpark for gas fired heating. Read the SAP document carefully as most answers are in there. Possible errors are air infiltration rate, treatment of linear thermal bridges, thermal mass, boiler efficiency, heating controls...I’ve not used the Stroma software for a long time but would imagine it would give an error message for anything totally out of step with SAP.- 47 replies
The use of a vcl is shown in relevant Bldg Reg Approved Doc & British Standard (and I believe timber frame guidance from TRADA)
First Quote is in - ASHP
ADLIan replied to canalsiderenovation's topic in Air Source Heat Pumps (ASHP)
Existing house, even if extended or planned extension, would have SAP energy rating EPC done by domestic energy assessor (DEA) using rdSAP. On construction (OCDEA) SAP assessor (for design stage/as built SAP) would not normally get involved in this instance. May need rdSAPassessment before and after extension. Different skill sets and different accreditation schemes for full SAP and rdSAP. -
What value was assumed at the design stage SAP assessment to show Part L1A compliance? This, or better, will be your target for the test.
Air pressure test can be avoided for a single house but the SAP assessment must use the default air infiltration rate of 15 - unless accounted for at the design stage this will probably result in Building Reg failure (CO2 emissions and fabric efficiency). Compare this value to some of the numbers achieved by members on here of 3 or lower! I regularly see values of about 7 with masonry construction and standard levels of workmanship/detailing.
I’m aware of that. My reply was more in connection with why use a 100kg/m3 slab when there is no need to. Assuming pricing is linked to density there are probably more cost effective solutions.
For acoustic insulation denser does not equal better - at normal, commercial densities, they all do the same job. Bldg Regs need 100mm thickness at 10kg/m3 as minimum, denser will be more expensive but acoustics will be the same (the ceiling, floor finish and effect of joists has a bigger impact).
Minimum Reasonable wall width for good U values?
ADLIan replied to puntloos's topic in Heat Insulation
I wouldn't use 032 mineral wool between timber studs. Will give little to U-value but at much more cost, 035 product will be OK. -
The U-value table from Black Mountain is meaningless. U-values apply to the whole build up, including all individual elements, of the floor, wall or roof. Additionally with timber frame it does not account for 15% thermal bridging of the insulation - the Kingspan figure does. Looking at insulation in isolation the hemp has a thermal conductivity of 0.039 W/mK compared to 0.018 (?) W/mK for Kingspan. The simple ratio of these 2 values shows you need twice the thickness of hemp to equate to the Kingspan product. Mineral wool is normally the product of choice here for ease of use and robustness of install, has good 'eco' credential and not oil based.
- 26 replies
- hemp
- insulation
internal plastering directly on EPS (ICF house)
ADLIan replied to magnethead's topic in Insulated Concrete Formwork (ICF)
Fire!! EPS will soften/melt, plaster will delaminate leaving eps exposed to add to the fire load. Mechanically fixed metal mesh as carrier may be an answer. -
Do not render on insulation on timber frame. Render should be on carrier board with vent cavity behind. See Bldg Regs and any good document on TF construction (see STA or TRADA guidelines). Wood fibre manufacturers guidance should not be relied on. Some did have BBA certs covering direct render but these all appear to have been withdrawn. -
Have you a photo showing the front elevation of this bump out rather than the side. If only a porch and the main external door is between the house and this area then it’s probably outside the thermal envelope so no insulation required. However it looks to be too long for that and may well include part of a ground floor room ceiling in which it should be insulated with 300mm (min) of quilt insulation. Looks like they did try to prevent the thermal bridge across the steels by packing with insulation - not sure how successful that would be! Run more insulation vertically against wall to minimise thermal bridge through steel. Not sure how you would do this so late in the day, perhaps have to remove roof tiles. Is house still under any warranty?
Fabric and ventilation heat loss calculator
ADLIan replied to Jeremy Harris's topic in Heat Insulation
The area weighted average u-value is the way to go however if the main wall/Uval accounts for at least 90% of the total wall area just use that value- 204 replies
- heat loss
- ventilation
(and 4 more)
Best practice? Please read MIs, BS and BBA certs, no ply/osb above insulation. Lots of fire safety info on internet re torch on systems. Moving to single ply membranes still no need for ply/osb above insulation (it’s in the wrong place!). Normally rubber/PVC single ply membrane is mech fixed or adhered direct to insulation.
Your flat roof is a standard detail apart from the extra layer of ply above the insulation - this is not required. Kingspan, and other PUR manufacturers, have insulation that will accept torch-on membranes and it looks like the fixings are OK. Remember the flame is directed at the roll of felt to melt the bitumen layer on it, not onto the insulation. Torch-on systems seem to have lost favour due to fire risk but if appropriate safety measures are taken it is quite acceptable.
Soundproofing ceiling/internal floors from the top instead.
ADLIan replied to Patrick's topic in Sound Insulation
Also EPS, board or beads, is not used for acoustic insulation.
