Working on reducing mains power by best use of PV (without batteries).
MikeSharp01 commented on Marvin's blog entry in ASHP, MVHR, PV and EV combo
Says the man with water that is softer than a babies bum to start with. So really it's move to the Scottish highlands, build a house, install some PV, design and build a diverter - then fluff any amount of towels for a short time - but only when the sun shines... Sorry I guess you already did😁.- 15 comments
- 2
- pv
- tumble dryer
- (and 7 more)
Filling in with solid insulation between Larsen Truss or I-Beams is a pain, Where we are not having blown in cellulose I made EPS 100 infills which effectively made our I-Beams flush than I could push in the 0.032 insulation batts without the folds around the step and any gaps.
Yes we brought ours as self building is unpredictable. In the past the scaffolders quote for the number of lifts and the estimated time with a weekly / monthly overrun price. Never had one with an under run discount though😁. The thing to avoid is piecemeal call backs - IE small unplanned mods to the scaffold. A late scafolder of my acquaintance said that the most piecemeal changes came at window fitting because people were not clear about where / How high & big they were at the outset and then it was when the groundworkers wanted to dig a new trench because some customer wanted the loo pipe moved.
That is a start but maybe, like weather compensation, you need to get ahead of the activity and the people. So predicting who will be home and what sorts of things they will be upto so you can prepare the best case for the combination. Although that also implies that none of them will be happy if they all prefer it slightly different.
This is another cruncher because the strategy is just one strategy when actually you probably need more than one - I guess that weather compensation was put in to allow a more flexible strategy but it seems a very crude scheme from those that I have looked at and the push up / down idea is something that needs also to be dynamic but relies on humans to adjust it. Its feels like we need some sort of heuristic system (not human) that learns from the responses to the various stimuli and so tunes the scheme to the users and the building.
man after my own heart Recently the more I fiddle with numbers around ASHPs (Despite an innovator / early adopter mindset) the closer I come to just following in the footsteps of @TerryE and using a Willis heater - the only thing it cannot do is cool on the few days a year our PHPP outcome says we might find cooling useful!
If you have a double socket on a ring then a competent electrician can add a switch fused spur to that and you could have that fitted inside the cupboard close to the device with appropriate cable run and protection for the cable, if needed, back to the double socket.
Ecodan standby power consumption
MikeSharp01 replied to LA3222's topic in Air Source Heat Pumps (ASHP)
I was trying to pre-placate the Units police! Yes I did I assumed 6months of heating @ 8 hours a day H+DHW and 6 months of just 4 hours a day DHW. Low figures but was for the place we are building IE Passive standard) -
Just did a back of fag packet thought experiment calculation on the real COP on a 5Kw (COP 3) unit (worst case) with 300W vampire load load and assuming 6 months of heat and DHW and 6 months just DHW comes out at 2.02! -
Also interestingly I was looking at the parasitic loads that we may have in our build and was wondering just how much energy the home automation system was going to burn. -
Interesting read... -
The LG units recently highlighted here have scroll compressors by the looks of it. -
NO - "The moral of that story is when viewing as house, get the current owner to go to the the middle of each room and jump up and down......"
How does this situation work with full filled rafter builds - like ours which are 300mm deep and will very shortly be filled with warmcell then battened over and plaster boarded to create the vaulted ceilings, so none of our rafters will be inspectable either?
Combining Air Con with an ASHP and MVHR system
MikeSharp01 replied to Indy's topic in Air Source Heat Pumps (ASHP)
You could run your ASHP in reverse and feed the cold water around the UFH to cool things down and perhaps add an online cooling battery to the MVHR but you cannot get much cooling at 'MVHR flow rates. JS Harris showed the the UFH cooling was effective in his build. -
Can anyone recommend a small monobloc ASHP and UVC?
MikeSharp01 replied to Dave7338's topic in Air Source Heat Pumps (ASHP)
But there is heat loss so ensure you get a very well insulated one. -
Starting on the path to a self-build
MikeSharp01 replied to KernowKensa's topic in Introduce Yourself
its got a 35% movement factor hence the jelly feel.
LG Therma V mono block Air Source Heat Pump
MikeSharp01 replied to ProDave's topic in Air Source Heat Pumps (ASHP)
Very interesting numbers - Did you get any impression for the average COP of the Heat Pump. -
Your Home Base Load / Background Power Draw
MikeSharp01 replied to MrMagic's topic in Photovoltaics (PV)
I was always told by a famous - now rather late, professor who taught me a thing or two that one should never go into any electronic situation without a pocket full of diodes - 1N4001 is my usual tipple but then I am a bit AC/DC. -
Sounds like a case for some intelligent electronics - surely you can organise a battery management system can deal with these, and other, effects. -
Hi and Welcome to THE forum for people like us.
And we look down on people like you ..... from our vantage point on top of the hill! -
No - it is just about your attitude to risk: No Glycol / No Valve - Can destroy ASHP, no cost now and won't happen very frequently. (Low likelihood / High Impact) Glycol / No Valve - System safe (you can forget), will restart once disturbance is gone, £160 for the Glycol. (Low Likelihood / Low Impact) No Glycol / Valve - System safe (you can almost forget), system won't restart after disturbance as it will need a fill and flush, £????? for the valve version. (Low Likelihood / Moderate impact) Which suits your risk appetite best?
