I appreciate that this perhaps a little extreme but what you don't want is any large load switching / transitions or high frequency power control happening local to sensitive small signal cabling / devices. Having done a lot of work with EMC control, albeit in industrial / academic environment I am aware of just how challenging it can be at times to ensure no interference. So I would not run any thing like rings through the Loxone box and not have them running anywhere close to small signal cables EG networks (unless very well screened), alarm systems, sensor feeds, audio, and Radio Frequency (Aerial cables). Turning a Kettle on for instance puts a current spike on the ring and this leads to spiky magnetic effects emanating from the cable along its length. If the Loxone box is metal you could mount it slightly off the wall and run the cables behind it and provide a good earth to the cabinet but keep the power lines to one side of the large duct shown in your drawing and once they get into the ceiling keep them separate from everything else in 3D space. If it is plastic then put the power cables in metal trunking behind the cabinet and earth the trunking. I suspect that the power into the Loxone box and any power control it does will be set around with some advice from them about running the power lines within the cabinet.
Oh no! what have I done? Although Pocster will be proud of me
MikeSharp01 replied to Thorfun's topic in Tools & Equipment
Sounds fun - did you mean enacted? -
Where have you been this thread is at least 20 posts old -
Where did you find it discounted? I need one in a month or so. -
Friction fit rockwool sagging between rafters
MikeSharp01 replied to daunker's topic in Heat Insulation
PIR is stiff up to its strength limit, interesting Youngs modulus I suspect, then just snaps rather than bend so I would have thought it would do it. Why not try a piece and see - you will need some big plastic washers to hold the PIR in place. To fix the ceiling make sure you measure / know the centers of all your purlins so you can find them again once you have the PIR in place. -
New member - stuck for what to do next to warm the house
MikeSharp01 replied to Sparrowhawk's topic in Introduce Yourself
Really thinking things through can sometimes be mistaken for procrastination but 'no', really thinking things through save heaps of trouble in the long run. -
Architect First Draft - Feedback Appreciated
MikeSharp01 replied to Scoops's topic in New House & Self Build Design
Hi and welcome. 4K/m2 is a good budget even in Dublin. So you should get it into your budget - just so I am clear you are adding about 60m2 to the floor plan across two floors with a mixture of single and double storey? I have struggled to see how the elevations tie up with the plans in places. It feels a bit cramped, lots going on! (I am no architect). I cannot get an idea of the problem your wife has and I am not sure what the covered outside portion does would it not be better to enclose all of that to give you a little more space internally? -
Welcome to THE forum!
Whow / how do you keep the site so 'clear' of everything?
Just read the report on ASHP installs against the grant scheme on the BBC - source of graphic below. It is seems interesting / instructive that the coldest places, where you may think heat pumps would struggle, have the highest take up. While, perhaps the stand out insight is that the UK - despite our proclaimed aspiration for leadership in green technologies is in last place on this list. Given these insights one wonders if we might be approaching the point of being able to say that, in this area, we are becoming something of a joke! Image source: https://www.bbc.co.uk/news/science-environment-66033199
We are getting ready to fit the cladding which is formed of fibre cement slates hung vertically. The ones we have have the holes set for the roof pitch but I can get away with a 25mm smaller headlap when using them vertically, and save myself 200+slates! It means adding some new fixing holes 25mm below the ones in the slate. As far as I can see the old holes won't be visible so I am thinking there is no problem doing this but just in case I am being very stupid and cannot see the obvious I though I would seek the collective wisdom! Is it OK to punch new holes and carry on?
You have come a long way Charlie Brown
Things are getting very bad down your way.
That is 440m2! What thickness are you looking for?
You can always paint the steels with intumescent paint, assuming you can still get to them. We used Envirograf (https://envirograf.com/) not a great finish - you could not leave it exposed IMO but you get the fire protection.
Their Aberdeen Angus burgers are great - they cook wonderfully on the BBQ.
Councils banned from charging for....
MikeSharp01 replied to Gone West's topic in General Self Build & DIY Discussion
Given the amount you save on energy you can afford it as long as you visit infrequently... -
Is it normal for roof membrane to leak like a sieve?
MikeSharp01 replied to Tom's topic in Roofing, Tiling & Slating
Roofers call it weathering - IE it should stand the weather - maybe they didn't count on the rain so had not got it all fully weathered!? -
Help with force / weight units...
MikeSharp01 replied to vcps2021's topic in General Structural Issues
One is basically weight 60Kg or a load at a point. The other is more like spread load. If you imagine 30 2kg bags of flour in a bag that is 60kg. Now mark out a 1m x 1m square and then spread the 30 bags out across the square and that will be 60Kg per square metre. -
Wonder how big your passive house would need to be to stretch this heat pump to its limits: https://www.bbc.co.uk/news/business-65321487 it can boil a whole Olympic swimming pool of water in less than 4 hours.
Did you mean 'on'!!!!
We have our own digger, for a few more weeks. We got is second hand and replaced the motors at the start as one was leaking, and although we have had to re-build one of them since, fit new hoses in places, replace the aux hydraulic connectors - which were jammed, change the oils & filters a couple of times and fit new seals on one of the rams otherwise it has been very cost effective. I hope to sell for about what we paid for it in the summer so although inflation has nibbled away it it will go one for a long time yet.
That's not bad £75K per year, so that is what a one man band would have to clear to equal that.
