So we are going to go for 4mm radial wiring and I was wondering what the practical challenges are. For instance most sockets are specified for 2x4mm in each terminal so spurs are a challenge and squeezing 2x4mm into the back box of the socket looks like a pain. How are these issues best approached and are there any more I should be considering?
Converting into 10 student flats (meters)
MikeSharp01 replied to PropertyOwner1682's topic in Electrics - Other
Have you checked with the college what their metering requirements are? They may be happy to include bills but they may like to know who is using what and if you ever change to an HMO you may then want separate metering yourself. @pocster will be along shortly, not an early riser, I have no doubt he will have an answer. -
A couple of things come to mind: Think through a PV roof as in see if can get a single roof face facing as near south as possible so if the image above has north at the top then try and get the long edge on the south side rather than the North as it is - I can see a tree indicated that might cast some shadow so that may be a deciding factor. It looks like you will need that party wall agreement with or without a basement. To cut the footprint perhaps loose the garage, or a proportion of it, to give you a little more manoeuvring room.
Welcome to the forum. 72mSq is a big Kitchen (9x8m) depending on the slab buildup and the insulation / air tightness of the overall build, you will want to be heating a lot of concrete and lots of insulation, it might be worth looking at the Willis heater option. These are small, a few Kw, water heaters that you can run over night on the cheap rate to warm the slab and let it cool during the day. @TerryE has done this successfully and done the sums, for his house, to show the cost / value outcomes against ASHP anyway.
Its amazing what you can do with photoshop or some AI deep fake system. Oh - I get it that's where the microwave came from as well - respect!
Bonkers or what!
New build in SE - MCS engineer says 22 kWh ASHP required....
MikeSharp01 replied to Navron's topic in Introduce Yourself
Hi - and Welcome to THE forum for people like us.... This may be another one of those occasions where the designer has not understood your build ups correctly. To get an accurate calculation do what @Thorfun suggests. The spreadsheet is here: https://forum.buildhub.org.uk/applications/core/interface/file/attachment.php?id=62325&key=a181232df44762993cdfe81c623c7c47 I think.. -
Looks clear enough to me and it must apply everywhere because it points up what MCS must do and MCS does it. Have a look here: https://mcscertified.com/installers-manufacturers/becoming-certified/ It is very much a close shop there but any other body could set up to do the same thing and be able to certify.
Wylex Combined AFDD/RCD/MCB
MikeSharp01 replied to Onoff's topic in Regulations, Training & Qualifications
This topic seems not have been mentioned much since this initial discussion. The several other places include: and So I thought I would poke it now as I have to decide on which circuits to fit Arc Fault Detection Devices (AFDDs). The 18th regs seem to mandate them on sockets in all buildings not just the tall ones or HMOS etc, as 'recommend' is to be interpreted as 'should' the way I read it. AFDD devices have moved on a bit in the 3-4 years since the OP and you can now get single unit combined double pole with AFDD, RCD and MCB for around £120 (I have been looking at those from LEWDEN but others seem to be similarly priced.) So if I put them on the five radial (we won't be having any rings) 13A socket groups I am into £600 and then I wonder about the 5A lighting sockets, these are sockets after all, but as they are all fed via a DMX dimmer it is not obvious how and AFDD might respond to such a situation. Anyone any thoughts to add to this question and the wider AFDD debate four years on? -
Concrete screw length for installing Upvc windows.
MikeSharp01 replied to Discoeye's topic in Windows & Glazing
Shouldn't you be using frame anchors rather than going directly into the Brick work, you need to avoid splitting the bricks I would have thought! -
Welcome to the FORUM for people like us... except I am no fan, as in I love to see it done but don't enjoy doing it, of painting, decorating and tiling so great to have your wisdom aboard.
Global warming is in fact entirely natural and has already peaked
MikeSharp01 replied to ProDave's topic in Boffin's Corner
Sorry, I get that, no I meant exploit the science for their own ends by being selective, looking down the wrong end of the telescope etc.
