Sprays against the glass like every one should. I'll take a pic later.
All of the mosaic'd area is the sloped former. WC is tight but retrofit so best of what we had room to do things with.
Hot water tanks, Temperature and Legionella
Nickfromwales replied to ProDave's topic in Boilers & Hot Water Tanks
My thoughts, and practices are in line with that thinking tbh. Better safe than sorry. Mitigate against dead legs, eg I routinely promote a HRC if the customer has PV as its 'free' to run and when experienced by the punter they say they never go back to not having a hot return , and I make sure there is a means of 'boiling' the tank either routinely or by purge program. Its very easy to do so needs no speciality plumbing or controls, just an immersion and a cheap ass 7-day time-clock. -
1200mm is the smallest screen you can go for if you have a true wet 'open' area afaic. The ones I'm doing now ( 2 wet rooms same house ) are 1500x740mm ( window called the width ) with a 1200mm glass, open-ednded, and the upstairs will be 1850x850mm again with a 1200mm screen open-ended ( even though I told them to take it back and get a 1400mm to no avail. The 1500mm long downstairs former is mosaic tiled beyond the glass screen but is still part of the sloped floor. Ill take a pic later and that'll explain in seconds. I've set the mixers out away from the shower heads, as frequently mentioned here, and it goes down a treat with the punters.
Room for the table and the other 3 chairs
My company motto for the last 2 decades has been "Grout will save the day". Whatever you think you can see when on your hands and knees, diminishes rapidly when you stand up, but when you grout you'll wonder what the worry was. I STILL, to this day, do exactly the same thing, ( screw eyeballs up and think...."Eeeee, I could get two fag papers in there, shall I cut a new tile"....), but I've already been offered another wet-room off the back of the two I'm doing now so they must look ok to the man.
Get that done sooner than later as that leading edge is now very susceptible to getting chipped Grout float looks good............."You can do it, Deeds!"
CONCRETE POUR ON THURSDAY 9TH AUGUST
Nickfromwales commented on vivienz's blog entry in Blackmore House
Give them a chance lol, they've probably only just boiled the kettle ! -
A Durgo is an AAV. A bit like saying "where is my Stanley knife?" when it's made by Irwin. You don't say "pass me my Irwin knife" .
Thats on my current wetroom job. Right hand 50mm goes to the free standing bath and basin as shown below. The first pic shows the 50mm tee ( for the shower ) with a 32mm branch going off to the new airing cupboard. In there will be a short section of 32mm pipe, a 32mm tee, a 32mm AAV in the top of the tee, and then the boiler condensate into the same tee on a 32x21.5mm reducer. The pipe going down the wall should have been 50mm TBH, as you then get a massive improvement on air break. It'll basically be almost trying to form a syphon as it falls vertically so not the best bit of plumbing TBH. The rule is when dropping like that to oversize to get an air break. Yes, an AAV will allow air in, but not at the tornado rates that you'll be needing.
Very strange. Normally they are user definable. Make / model of UVC? -
Should I switch off the boiler in the summer?
Nickfromwales replied to Mr Punter's topic in Boilers & Hot Water Tanks
Agree, but quite a lump she is ( floorstanding iirc ? ) I go for the Vaillant 938 ( wall-hung ) heat-store combi which does two adequate showers, IF the cold mains will allow it, as all instant hot water heaters instantly die off if not getting cold mains priority. -
Easy. It's just a flag of PB that's one long stilt for the second course and you don't need to affix it / damage the tanking.
"By jove....I think he's got it !" .
A little abrasive, perhaps? Maybe because a hot water system in particular should be specified to meet the needs and requirements of the both the size of dwelling and number of occupants / DHW consumption patterns. Much as I like a good combi, they're less than brilliant at producing hot water. Plus, in a 4-storey house, if the DHW consumption is high then the space heating would not get serviced sufficiently ( as your probably aware, a combi cannot produce heating and DHW simultaneously, so whilst a hot tap is running there is no output to the heating ) so they're not really suitable for anytging bigger than a 2-3 bed ( 2-3 occupant ) dwelling. After you need more than one shower the combi falls flat on its arse. Stored hot water ( cylinder / Sunamp ) is also a means to absorbing excess PV production, whereas a combi just sits there with a daft look on its face as it burns gas not electricity, so again, not suitable in that situation, ( if you like 'free' hot water for eg ). To say that everyone should suffer a combis poor DHW output is where any madness lays IMO. . -
Another £100 down the tubes. ? Give me strength. Use the laser you've already bought !
The only way you'd be able to do that would be if you made stilts to support the second row of tiles as you cant fit a batten with screws unless you screw through the tanking. Also, you may well find that the batten sticks to the tanking and when you remove the battens you'll take a section of tanking with it. As its you were talking about, lets devise a completely long-winded, new, and ingenious method.................. For the wet area and pocket shelves I take it youve worked the pocket cuts so the wall tile is a factory edge against the bottom tile trim leading onto the 3o sloped shelf? Cant grumble, a man after my own heart. So, you cant ( dont want to ) screw through the tanking to fix a batten. How about laying 3 tiles on the floor with the spacers in to get your measurement from the the top factory edge to the bottom factory edge ( or whatever number of tiles gets you to the first grout line etc ), then transfer that to the wall and add 2mm height for the flag of the tile trim, ( go balls out and add 3mm if I were you, as you can just add a bit more adhesive to the 3o tile whereas you cant take it off ). Then get a piece of plasterboard 300mm x ( X ) mm and lay it lengthways on the floor, starting at the 45o wall and running back towards the WC. Get a block and mark the scribe for the fall into the tray. Get that spot on ( like you need telling ) and then, once happy, fire up the laser set at distance X derived from laying the tiles and spacers out. Cut the PB 3mm shy of what you want so if youve accidentally overshot you dont have to pull it all down and re-cut the PB. If you have a deficit in height then its easy you just pack spacers out with stiff cardboard ( cardboard form an empty screw box cut into 1" strips does great, but you could get NASA to laser cut you those out of Unobtanium if you wish ). Once happy that the PB is "in the zone" you then wedge that against the wall ( batten and some deadman studs off the opposite wall? Dont forget to cover the ends with a plastic bag so they dont take to the tanking ), and then you can start tiling up off the PB. STICK TO THE SLOW SET ADHESIVE AS THESE WILL NEED TWEAKING. Use 3 spacers per tile so there is no risk of the weight of the ascending courses pushing the spacers into the PB. Tile 4 tiles wide and go up to meet the pocket shelf. As you complete each horizontal course lay a 1200mm level across to see what needs tweaking to horizontal. It won't be perfect because your off a scribed PB so you really do need to check each course and adjust as your going. VERY IMPORTANT TO GET THE FIRST COURSE OFF THE PB PERFECT ! Once at the shelf reveal, chuck the CliveMaster2000 3o benchsetter against the tile and check with an off cut that you have sufficient clearance ( your tiles are high enough ) and repeat.
Yup. A LOT more. Porcelain is average 0.05% porosity, so basically waterproof. Add tanking into the mix and you can have some really extended set times If you put any Mayonnaise like substance in there I'll flip. Just carry on as you are its fine without any admixes
Justifiable on his timescales TBH
Not with a ceramic tile mate!!
....."I can't believe its not butter.....ed" Laid with a Cobra more like!
Thank you for recommending tile showroom
Nickfromwales replied to Alexphd1's topic in Floor Tiles & Tiling
You should be able to draw / show examples of what you want and then they should produce a draft for you to approve. -
As long as you've got a dry section to work away from then carry on. ?
The Matrix has him now, save the girl !!!!
